Like Tree22Likes
Old 11-12-2011, 09:54 PM
  #8101
Trader Rating: 16 (100%+)
Found 2 87T spur gears at Pegasus Hobby in CA. Quite possibly the last two spur gears in the Northern Hemisphere.
Now to move on and quit moaning.
I bought the 410R, and it is time to build it. I have read through most of the threads about tips and suggestions. Here is what I have bought so far to make the car bullet proof:
Aluminum servo saver.
HD ball cups.
Front/front aluminum suspension holder
Aluminum rear gearbox insert
7k front diff fluid, 3k rear
Kyosho P5 o-rings
Anything else?
What about shock oil, pistons, or springs?
Finnaly, does Durango have a "stock" set up sheet for the 410? Trying to mount shocks and match up holes and positions by referring to the manual's pictures is tuff. Do I use the +2 or -2 suspension holder, which one is stock? Is there a base set up sheet that works? I would like to keep it simple and then try a few things later on after I drive the car for a while.
zipperfoot is offline
Old 11-12-2011, 10:15 PM
  #8102
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default petitrc.com
HD ball cups.
Kyosho P5 o-rings
Anything else?
go to petitrc.com there are many set ups for all surfaces
and base setups to start with
enjoy this buggy they are awesome right out of the box
majorsmx521 is offline
Old 11-12-2011, 10:27 PM
  #8103
Trader Rating: 19 (100%+)
HD ball cups.
Kyosho P5 o-rings
Anything else?
If you're running on clay try the Grapejuice setup. We started with it a few months back and with some minor tweaks Cush has been loving it and fast at a variety of tracks. I think its on petit rc under Justin Salerno.
Your list above looks pretty good. If you get the rear diff hoop from Tresrey you can get the P5 o rings there, and within the next week or so they will have good stock of Durango parts too. One stop Durango shopping
Jonny5 is offline
Old 11-13-2011, 06:44 AM
  #8104
Trader Rating: 17 (100%+)
Anyone know what I can use on the outdrive to get them to stop squeeking? My car sounds like it's an old rust bucket sometimes.
bobsavenger is offline
Old 11-13-2011, 08:40 AM
  #8105
dangerwr's Avatar
Huh. Never had that problem but have heard a Rango with squeaky wheels. How do your bearings and diff fluid look? CVDs??
dangerwr is offline
Old 11-13-2011, 09:10 AM
  #8106
dangerwr's Avatar
Default V3 rear hubs?
Guys,
I understand the V3 has different hubs on the rear that use a larger outer bearing. Does anyone know if it is the same hub on the DESC410? Anyone have the P/N? Thanks!
I think I found my answer . . .
http://www.team-durango.com/part-inf...artNo=TD340071
dangerwr is offline
Old 11-13-2011, 11:27 AM
  #8107
Konich's Avatar
Tresrey hubs have a larger outer bearing Danger
Nice run last night, but remember the more Tresrey the more you finish towards the front
Konich is offline
Old 11-13-2011, 11:41 AM
  #8108
dangerwr's Avatar
Haha! You are a pusher son and knew the Tresrey plug was coming! I really like to run as much plastic as I can because if you make your car too stiff the ball cups will pop off too often.
dangerwr is offline
Old 11-13-2011, 11:55 AM
  #8109
scr8pn4205's Avatar
looking at a v3 but wondering what people think of the big bored compared to the standard shock on the 410
scr8pn4205 is offline
Old 11-13-2011, 11:56 AM
  #8110
Diff's have been cleaned out and rebuilt recently. I believe it's the CVD's chattering. What would be the best to clean them out and get them to keep quiet?
The bearings are also in good condition.
Old 11-13-2011, 12:00 PM
  #8111
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Have you noticed any wear in the outdrives or the pins of the dog bones? I know when my b4 outdrives and pins wear out they squeak.
Jmuck69 is offline
Old 11-13-2011, 12:01 PM
  #8112
dangerwr's Avatar
I am sure there will be a lot of good opinions on this one once there are more people out there who have ran both. I understand the BB are smother but also heard the team guys are winning with the standard so I dunno . . .
I have been running the standard with modified pistons and the gold nitride shafts and seem to be fine. I do have the BB on order and am itching to try them and compare.
dangerwr is offline
Old 11-13-2011, 12:06 PM
  #8113
dangerwr's Avatar
Weird. I reluctantly clean mine with WD40 but then wipe them off. A thin layer of Losi Great Grease seems to keep everything quiet. I am not sure if you are running the boots--I never have. I just try to keep the amount of grease to a minimum but is usually not an issue on hard pack indoor clay. In eifff scale I see people use motor cycle chain lube on CVDs to prevent dirt from sticking.
dangerwr is offline
Old 11-13-2011, 03:52 PM
  #8114
I cleaned them with WD40 and wiped them off. I am running the inner boots. After cleaning them out it did seem to make it much quieter. Now if I can just keep it that way.
Thanks for the help.
Old 11-13-2011, 04:07 PM
  #8115
Qwkrn U's Avatar
Trader Rating: 133 (100%+)
Bob,
on my last Dex410 I always cleaned the cvd's and greased them with the associated black grease. then used the inner boots. I havent taken my new one apart yet.
Qwkrn U is offline
