Like Tree22Likes
Old 11-10-2011, 07:54 AM
  #8041
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by TAMAK
Lack of parts availability
Attachment 832048
nice, but i did see another forum, they've been testing them since beginning of 2011, possibly even end of 2010..
i'll let you guys test them 1st.. i've got other upgrades to take care of first
t8rtot is offline
Old 11-10-2011, 09:22 AM
  #8042
markhat250's Avatar
Trader Rating: 65 (100%+)
I just had to get you all fired up about the parts thing, and nobody has said "yeh it sux", but all the opposite, in that you have plenty. Good news. That was a good enough sign for me. Sorry for stirring the pot, but didn't want to throw down and be screwed. You've convinced me enough this won't be the case . Thanks ya'll.
markhat250 is offline
Old 11-10-2011, 09:36 AM
  #8043
dangerwr's Avatar
I think it is good to have the discussion and believe people were trying to convince you to go Rango. We have all been happy with the car and the support--including parts availability. I just got a notification from A-Main that the front BB are back in stock . . .
dangerwr is offline
Old 11-10-2011, 10:03 AM
  #8044
But seriously, once these puppies get here we are all going to sprint to buy them. So get you cards out. I think they are pricey though? 60 bones?
They are smoother and run cooler than the standard ones, car also seems quieter and rolls through ther corners better.
Chris-s is offline
Old 11-10-2011, 10:23 AM
  #8045
markhat250's Avatar
What parts should I for sure order for the BUILD? I thought I read something about kyosho dif seals? Any part numbers or recommedations when building would be highly appreciated.
Old 11-10-2011, 10:36 AM
  #8046
TAMAK's Avatar
Trader Rating: 29 (100%+)
- http://www.tresrey-usa.com/products/...7D410R%29.html
-TDR330004 and TDR330037
-TDR310118 (not a must)
- TDR330099 for the gear diff seal
- http://www.tresrey-usa.com/products/...TIAL-HOOP.html
Also the rear ALU gearbox inserts when you get a chance, If you can afford.... If not pick up a part tree for the plastic piece and a rear bulkhead set.
TAMAK is offline
Old 11-10-2011, 11:06 AM
  #8047
dangerwr's Avatar
Aluminum gear box inserts? I have not heard of these--do you have a P/N? I will Google as well . . .
Oh yeah, I forgot!
http://www.amainhobbies.com/product_...rce=google_ext
dangerwr is offline
  #8048
t8rtot's Avatar
if your getting a V3 you don't need diff seals, they include them and you don't need the front hangers there in there too.
not needed since the V3 fixed the center rear outdrive and driveshaft legnths..
unless he's pulling an R that wasn't beneficial.
t8rtot is offline
Old 11-10-2011, 11:09 AM
  #8049
t8rtot's Avatar
he means these.. i haven't broken my plastic ones, not to say the won't or can't be a weak point but i wouldn't replace them unless you break.
#TD310006
#TD310007
t8rtot is offline
Old 11-10-2011, 11:13 AM
  #8050
dangerwr's Avatar
#TD310006
#TD310007
Yeah, I have these--when I heard aluminum gearbox inserts I automaticall thought of the ones on my eifff scale which is something the Rango does not have. I did not break my plastic ones but they did get distorted so I bought the aluminum.
dangerwr is offline
Old 11-10-2011, 11:53 AM
  #8051
markhat250's Avatar
So TDR330099 for the gear diff seal just comes from the 408 shocks? Easy enough. So no buying Kyosho seals it sounds like.
Old 11-10-2011, 11:56 AM
  #8052
TAMAK's Avatar
More prone to break with the R version. 1. Longer shock tower hitting 2.) bulkhead breaking 3.) plastic inserts break then as well.
I replaced them after my first bulkhead break, since then i trimmed the shock towers and bought ALU inserts.
TAMAK is offline
Old 11-10-2011, 11:57 AM
  #8053
dangerwr's Avatar
http://www.team-durango.com/blog/201...diff-seal-mod/
dangerwr is offline
Old 11-10-2011, 11:58 AM
  #8054
t8rtot's Avatar
you don't need them! the v3 includes them!
t8rtot is offline
Old 11-10-2011, 12:00 PM
  #8055
dangerwr's Avatar
Which version of the car did you order so people will quit sqawlking about the V3?
dangerwr is offline
