Like Tree22Likes
Old 11-07-2011, 12:56 PM
  #7966
redron123's Avatar
Trader Rating: 87 (99%+)
Sounds like the 410R is not the one to get. Should i wait till i can get a V3 or a spec?
redron123 is offline
Old 11-07-2011, 01:06 PM
  #7967
ABBOTT's Avatar
They have some spec kits on ebay for $699 get one of those.
ABBOTT is offline
Old 11-07-2011, 01:20 PM
  #7968
redron123's Avatar
The same one that's listed for 399 on their site? Yeah right! Where do they sell the specs at a decent price?
Old 11-07-2011, 01:22 PM
  #7969
t8rtot's Avatar
Trader Rating: 14 (94%+)
i would wait.. an R with about another $200-$300 thrown at it would be about in line with the V3 big bores, springs, carbon brace and few alum upgrades w/ 14mm hexes but definately easier to just buy it in one kit
t8rtot is offline
Old 11-07-2011, 01:42 PM
  #7970
redron123's Avatar
So the V3 is the one to get? That sounds more sensible than upgrading and modding it all. Is there really any more advantage to getting the spec?
Old 11-07-2011, 02:00 PM
  #7971
t8rtot's Avatar
no you'll spend more than the price of the V3 and still not have all the new stuff..
V3 has all of this over the spec:
plastic side pods, big bores, new rear hangers, hexes, new shock towers, Kuhler body, new drive shaft and outdrive..
i would just wait.. trust me, i hate waiting, im way more of an impulse buyer. but waiting it out will save you at least $150-300. $400-600 if you buy the spec.
why not just wait and buy once. and i'm sure your wallet will appreciate it as well
t8rtot is offline
Old 11-07-2011, 02:40 PM
  #7972
Konich's Avatar
I would buy a 410R and upgrade as needed. You can get an R for $250 to your door, buy things as you need them.
HD Ballcups - from what I hear almost worse at popping off than the stock ones
14mm hexes - You'll never find enough supply of wheels.
Some of the smaller things (rear toe block, revised shock towers) aren't really deal braker's in my book. Hell I have a 2009 spec and have upgraded it along the way. There are plenty of people running the 410R's with great success.
Konich is offline
Old 11-07-2011, 02:43 PM
  #7973
dangerwr's Avatar
Good point. I think people will find by the time they are done upgrading for their liking, driving style and track you will have a hybrid of all the versions.
dangerwr is offline
Old 11-07-2011, 08:22 PM
  #7974
Trader Rating: 16 (100%+)
Originally Posted by cota4rt
Make sure your sun gears in your diff slide on to the outdrive Without being forced on! You will prolly have to grind the hex on the outdrive down some to get it to slide on. If you don't you will have two problems-one it will screw uop the tolerances and can cause diff failure. Second it will be very difficult to remove sun gear(prolly will ruin parts trying).
Now most buy the aluminum Treasey diff holders. I have 3 durangos so I didnt want to drop that kinda cash so I Macgyver'd a retainer to hold the top of the ring (epecially in the back diff) from moving forward. Since the battery retainer is held on by diff retainer it all flexes forward especially when braking or lawn darting(happens ) Bad design for sure but with 10 mins in shop you can build retainers.
Also the drive shaft pins seem to love to come out. Do not use durango thread locker-use loctite red or similiar just know u will have to heat it to remove. Clean all parts with contact cleaner(motor spray) and dry before loctiting. Put a slight flat spot on pin where set screw will hit. Make sure set screw hits that during assembly. Finally super glue retainer ring durango supplies over cvd and go drive it!!
I personally like Ryan lutz's setups on Lutzinator.com with heavier diff fluids as it makes car smooth out and less twitchy. Very durable after you fix all the things mentioned in last few posts. Good luck!!
Can you post a pic of your diff retainer fix.
A929ryda is offline
Old 11-07-2011, 08:44 PM
  #7975
Trader Rating: 31 (100%+)
Here is the pics Just used some metal I had and bent and ground a radius around diff ring. I used longer bolts in gear housing
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-photo.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-photo-1-.jpg
cota4rt is offline
Old 11-07-2011, 09:14 PM
  #7976
ABBOTT's Avatar
When V3 parts are ready the new rear hoop is thicker plastic so it will be a cheap fix.
Please remove that pic!
And I am sorry for the earlier statment about the spec kit, I thought it was a obvious joke.
If I do a tips thread, can someone tell me if I am able to delete posts from it once I have added peoples suggestions.
ABBOTT is offline
Old 11-07-2011, 09:51 PM
  #7977
dangerwr's Avatar
Yeah this is less than helpful. I am always amazed at the level of helplessness on this site. Good luck folks! I hope you can tear it up at your local track!
dangerwr is offline
Old 11-07-2011, 10:22 PM
  #7978
ABBOTT's Avatar
http://www.rctech.net/forum/electric...ml#post9883016
Start the info and I will make an effort to give people a go to source for all the basics
It may not be as nice as others but I will give it a shot.
ABBOTT is offline
Old 11-08-2011, 12:21 AM
  #7979
ABBOTT's Avatar
Even sitng some informative post # would be a great help thanks
ABBOTT is offline
Old 11-08-2011, 05:38 AM
  #7980
Are you referring to the pics I posted showing diff ring retainer? If so why do you want it removed?
cota4rt is offline
