Like Tree22Likes
Old 10-26-2011, 04:41 AM
  #7816
t8rtot's Avatar
Trader Rating: 14 (94%+)
Originally Posted by A929ryda
Ok! I just picked up a used DEX410r The lowest turn 540 motor I have is 13.5. The guys at West Coast raceway are running much lower turns. However, i have a Castle1410 4-pole. My question is will this motor work or will I just be wheeling or even flipping down the straight? I would like to save some dollars but am willing to purchase a better motor. let me know.
Boost the hell out of that 13.5 you could probably get it to run like a 9/8.5 if you max it out, just watch temps
t8rtot is offline
Old 10-27-2011, 03:06 AM
  #7817
getpip's Avatar
Default Paint
The 'Rango is now painted up and ready to roll.. cant wait to run it.
Some pics of my paint job ... HERE
getpip is offline
Old 10-28-2011, 03:37 PM
  #7818
Subscribe
MickSz is offline
Old 10-29-2011, 01:33 AM
  #7819
getpip's Avatar
Originally Posted by wyl03
getpip - nice install. re wiring of battery. I noticed that you have trimmed the wires to specific length. FYI - unfortunately not all batteries hve the +ve and -ve plugs oriented the same way. My TrackPower and IP batts have the plugs the other way around which meant that i have to hve both wires equally long. if you are just sticking to a single brand, then you'll be OK.
Thanks... hadn't even thought of that but I have a couple of sets of IP I'll be using.
Or I can always route them the othe side of the spur gear.
Something to look out for if I buy more cells though.
getpip is offline
Old 10-29-2011, 08:26 AM
  #7820
tobamiester's Avatar
Trader Rating: 360 (100%+)
Up until 2 weeks ago I had two Venom Saddle packs with reverse polarity on the bullets, which meant I had to have equal length wires. I fried a Tekin RS last spring so have been VERY careful when I plug stuff in to make sure I got them the right way around.
However I did accidentally attempt to plug them in back-to-front 2 weeks ago - I don't have a switch on my RSPro and as soon as I attempted to plug them in, the wires & bullet got super hot (I actually burnt myself) and I pulled them out. I was amazed I didn't fry my RSPro - Anyways, Lesson learned, I sold one of the packs the very next day and brought another one with the same polarity and cut the wires so I can't physically plug them in wrong.
It just ain't worth the risk of making that human failure, and destroying the electronics and your evening of racing etc.
tobamiester is offline
Old 10-29-2011, 08:41 AM
  #7821
wallot's Avatar
it was a wiring nightmare.
i cannot shorten any servo wires as sometimes I need the electronics in other cars.
need bit smaller pinion so the ESC will move a bit.
why pink? it is probably the most easily recognizable color on the track
first race on saturday. will see how it handles.
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex1.jpg
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex2.jpg
wallot is offline
Old 10-29-2011, 09:09 AM
  #7822
Attachment 826649
Attachment 826650
This thread is worth a look, quite a few tekin installs on there: http://www.oople.com/forums/showthread.php?t=31939
Chris-s is offline
Old 10-29-2011, 07:47 PM
  #7823
ABBOTT's Avatar
Attachment 826649
Attachment 826650
There really isnt a nice way to this, fix that mess! You are asking for trouble.
NOthing wrong with the pink though.
ABBOTT is offline
Old 10-29-2011, 10:52 PM
  #7824
MaTt 93's Avatar
Is anyone have problems with the hd ball caups popping off? Just wondering because i need to get new ball caps for my dex410r.
MaTt 93 is offline
Old 10-29-2011, 11:06 PM
  #7825
dangerwr's Avatar
Yes. This is a well known issue with many. Supposedly the new HD ball cups help with this but many have been using RPMs.
dangerwr is offline
Old 10-30-2011, 12:58 AM
  #7826
MaTt 93's Avatar
Will i need to get new ball studs if i get the rpm ball cups?
And are these the ones they are useing? http://www.amainhobbies.com/product_...Ends-Purple-12
MaTt 93 is offline
Old 10-30-2011, 05:55 AM
  #7827
Get the TC5 ball studs for use with RPM Long shank cups. Mine barely ever come off.
Old 10-30-2011, 08:27 AM
  #7828
Hi.... Just a quick question. I've been waiting for the V3 to come off back-order, but I got an offer to buy the original kit for not much more in price. Think I should grab it while I can, or wait it out for the V3?
CRF311 is offline
Old 10-30-2011, 08:41 AM
  #7829
dangerwr's Avatar
I would get it if I were you. I think the V3 option parts are between the DEX410R and the 2010 Spec kit--minus the BB shocks of course. And the BB shocks are not that much bigger bit have been told they are super smooth. Cheers!
dangerwr is offline
Old 10-30-2011, 08:44 AM
  #7830
dangerwr's Avatar
Default V3 14mm wheel hex
Guys,
Anyone know where I can get the 14mm wheel hexes--either aluminum or plastic? I sheared 2 of those roll pins last night causing me a qualifier and the main . Thanks!
Otherwise, does anyone have the P/N for the plastic?
dangerwr is offline
