Like Tree22Likes
Old 10-22-2011, 03:31 PM
  #7801
Trader Rating: 75 (100%+)
Default dex410r-2010 spec
Have mine forsale if anyone is looking.
http://www.rctech.net/forum/r-c-item...ml#post9815909
gixxer420 is offline
Old 10-23-2011, 08:30 PM
  #7802
dangerwr's Avatar
Guys how much larger are the BB shocks over the original? Looks like 2mm on the diameter. They look really cool but did not see that they were much larger . . .
dangerwr is offline
Old 10-23-2011, 08:39 PM
  #7803
Slash and Burn's Avatar
Trader Rating: 24 (100%+)
Percentage wise, it's a huge difference, and oh what a difference on the track!
Slash and Burn is offline
Old 10-23-2011, 09:12 PM
  #7804
dangerwr's Avatar
Well what is the percentage then? All one has to do is divide the diameter of the originals by they diameter of the BB and multiply by 100. So . . .
dangerwr is offline
Old 10-24-2011, 02:27 PM
  #7805
getpip's Avatar
Default My 410 ellectrics.
I wired up my 410 over the weekend.
I put a couple of pics on my blog for anyone thats interested.
See here... Clicky
getpip is offline
Old 10-24-2011, 02:35 PM
  #7806
See here... Clicky
Hi mate, prob neatest I have seen, fancy doing mine! Lol
See you Sunday
mikeyscott is offline
Old 10-24-2011, 02:43 PM
  #7807
dangerwr's Avatar
See here... Clicky
Perfect! Thanks for the ideas.
dangerwr is offline
Old 10-25-2011, 03:46 PM
  #7808
Default Bladders
Tested bladders this weekend in original (non-bb) with positive results. Used the HPI Blitz bladders which fit perfectly. Was told it can make the car feel as it is floating over the dirt and doesn't allow it to dig in. Can't disprove that since I went 180 from my usual set up to try a few things. Interested to see if anyone else tried it or will in the future for comparison.
Seeds is offline
Old 10-25-2011, 05:27 PM
  #7809
Trader Rating: 44 (100%+)
getpip - nice install. re wiring of battery. I noticed that you have trimmed the wires to specific length. FYI - unfortunately not all batteries hve the +ve and -ve plugs oriented the same way. My TrackPower and IP batts have the plugs the other way around which meant that i have to hve both wires equally long. if you are just sticking to a single brand, then you'll be OK.
wyl03 is offline
Old 10-25-2011, 06:16 PM
  #7810
littlejohn's Avatar
Easy fix Yung.. Just drill the casing of the saddle packs so you can flip them and plug the bullets in from the other side.
littlejohn is offline
Old 10-25-2011, 07:16 PM
  #7811
LJ - thanks for the bit of lateral thinking
is it as easy as that?
never opened a saddle lipo case before. never seen if the plugs go through to the other end (they probably do, just like the stick pack)
a bit reluctant to drill anything into a case keeping in mind what happened to my saddle pack recently, you can understand my reservations!
wyl03 is offline
Old 10-25-2011, 07:53 PM
  #7812
Has the V3 fixed most of the V2 problems? Like leaking diffs and ball cup, etc...
Also what parts are recommended having in the tool box?
Thanks in advance
The Colonel01 is offline
Old 10-25-2011, 08:16 PM
  #7813
Thanks in advance
They included o-rings instead of the x-rings and the kit also includes the HD ball cups.
My kit went together well, although I know others who were missing parts, so quality control isn't what it should be as far as getting all the parts in every box. The V3 kit is definitely better than my DESC kit was.
Some of my favorite aspects of the V3 kit are the price and I slightly augmented Randy Pikes setup and put it on the track and it is handling well. The cons are: no parts available yet, no front wheels, shock towers, HD ball cups. You'd think a company would have an ounce of sense!
Old 10-25-2011, 08:30 PM
  #7814
Trader Rating: 16 (100%+)
Default Motor question
Ok! I just picked up a used DEX410r The lowest turn 540 motor I have is 13.5. The guys at West Coast raceway are running much lower turns. However, i have a Castle1410 4-pole. My question is will this motor work or will I just be wheeling or even flipping down the straight? I would like to save some dollars but am willing to purchase a better motor. let me know.
A929ryda is offline
Old 10-25-2011, 08:34 PM
  #7815
In my opinion and experience, if you are racing, sensored is a must have.
