Like Tree22Likes
Old 10-21-2011, 08:57 AM
  #7786
dangerwr's Avatar
Originally Posted by grapejuice
Saturday? My car is ready and there was a heat of wheeler Wednesday!
Sweet! I will not be ready for this Saturday but will be by the next. I want to stop by this Saturday evening to get parts from Konich and check out your DEX210. Have you been working on a setup for the Big Bores on the 4-wheeler? I think I am gonna hold off on those and see if people prefer these over the original. Not that you can even find the full set of BB in stock right now.
Does MHOR have wheels in stock? I only have one set from last year . . .
dangerwr is offline
Old 10-21-2011, 11:16 AM
  #7787
grapejuice's Avatar
Trader Rating: 152 (100%+)
Haven't really been "working" on a set-up but running it a little and it feels pretty good, just going try a little heavier oil in the front and try some different springs too. And yes MHOR has wheels instock.
grapejuice is offline
Old 10-21-2011, 11:59 AM
  #7788
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Here is a tip for mod, get a 7.5 and turn it down for indoor and run full tilt outdoor. I on the other hand do the opposite, I run a 6.5 indoor and outdoor at full boogie and just drive it...
rx7ttlm is offline
Old 10-21-2011, 12:26 PM
  #7789
t8rtot's Avatar
Trader Rating: 14 (94%+)
for indoor smaller tracks, i would recommend nothing higher than a 10.5.. if you can't get to full throttle at least once theres no need for these high motors. i run on a track that looks slightly larger than the ones in the vid and i wont use all of the 13.5 that i'm running.
if i do i can always crank her up..
t8rtot is offline
Old 10-21-2011, 01:10 PM
  #7790
Trader Rating: 19 (100%+)
Originally Posted by TAMAK
So it appears that my DEX210 kit came with extra 14mm hex's. Only two. , But that's fine for me. 12mm fronts 14mm backs until someone has 14mm fronts in stock.
Leisure Hours has a ton of 14mm fronts in stock at the track- since you're going tomorrow. I think in yellow only though.
Jonny5 is offline
Old 10-21-2011, 07:07 PM
  #7791
dangerwr's Avatar
I dunno. I like the grunt of the 8.5 in my Rango--even if I only open it up for a second or two down the straight.
dangerwr is offline
Old 10-22-2011, 12:23 AM
  #7792
MooseDrool's Avatar
Trader Rating: 7 (89%+)
But are you saying that you would run a 9.5T in a DEX410 for mod 4-wheeler on arguably the most competitive track in the nation?
I was just goving my input on the new orion motors. Someone mentioned that they wanted an 8.5 but all that was in stock was a 9.5. I simply stated that the new 9.5 runs about as fast as most other companies 8.5's, and a lot cooler too.
I run an orion VST 5.5 in my kyosho FS2, but I have always liked a lot of motor in my cars, and not trying to sound cocky here, but I have no problem handling it on our medium sized indoor high grip track.
MooseDrool is offline
Old 10-22-2011, 03:00 AM
  #7793
rx7ttlm's Avatar
I don't see the point, unless you already have a bunch of motors sitting around. A couple months ago I saw a guy buy 4 motors for touring, 3.5, 4.0, 4.5 and 5.5, when I asked him why he said he wanted to be ready for all the tracks around here. Makes no sense when you can run a 4.5 and turn it down, or for outdoor tracks add timing on the esc. Kinda a waste of almost 400 bucks. Just like in offroad, get a 7.5 and turn down the epa to less than 90% (whatever you can handle and be consistent). The last layout we ran a 8.5 wasn't enough for indoor (shrug). Easier to turn it down than to switch motors, cheaper also. And even with the 6.5 with boost I was full throttle a couple times a lap... car was a blur to spectators
rx7ttlm is offline
Old 10-22-2011, 06:21 AM
  #7794
t8rtot's Avatar
To each there own. However, this is very similar to the 250 vs 600 debates on most sport bike forums..
t8rtot is offline
Old 10-22-2011, 07:39 AM
  #7795
Konich's Avatar
I run a 6.5 and almost never hit full throttle except for about 20' on the front straight. However I like to be able to turn it down. That way I only need to run 1 motor, can turn it down, and it runs cool as adding timing/boost is never an issue.
Plus chicks dig it
Konich is offline
Old 10-22-2011, 07:55 AM
  #7796
suprdave's Avatar
Trader Rating: 22 (100%+)
Hey guys. I'm looking to get a new wheeler but no V3's in stock anywhere. Would it be a bad idea to go ahead and get the older version 410 and upgrade as parts come available or are there too many changes to the new car to make it worth it?
suprdave is offline
Old 10-22-2011, 08:09 AM
  #7797
R-E-A-P-E-R-'s Avatar
The original 410 is still better than any other wheeler on the market. You won't be dissapointed with it. And like you said you can upgrade as you go along.
R-E-A-P-E-R- is offline
Old 10-22-2011, 09:05 AM
  #7798
dangerwr's Avatar
I hear ya' and am really tempted to just get the VST 9.5T and just use a little boost if I need it. My gut keeps telling me to hold out for the 8.5 released in 2 weeks. I have a perfectly healthy Novak Ballastic 8.5 but have since turned my back on them and want to only use this motor as a backup.
dangerwr is offline
Old 10-22-2011, 09:11 AM
  #7799
Konich's Avatar
Danger stop by and check out our V3's
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-tysp003_01__23792_zoom.jpg
Konich is offline
Old 10-22-2011, 09:23 AM
  #7800
dangerwr's Avatar
Nice! That is too much motor for me son!!!
dangerwr is offline
