Like Tree22Likes
Old 10-15-2011, 12:42 PM
  #7696
Konich's Avatar
I ran the Azarashi body when I first got my DEX. The body and undertray itself cost about $75 dollars, if you can even get them anymore. Also the undertray only works with the Azarashi body and you can't get it separately either.
JConcepts chassis tape!
Konich is offline
Old 10-15-2011, 06:47 PM
  #7697
TAMAK's Avatar
Trader Rating: 29 (100%+)
Default S&N Trackside setup
Hey guys,
Working on filling out a setup for S&N Trackside. Car was dialed with big bores, driver just needs to put in consistant laps, was able to get fastest lap in 4wd buggy.
TAMAK is offline
Old 10-16-2011, 04:31 AM
  #7698
slow_jun's Avatar
Trader Rating: 14 (94%+)
Originally Posted by subaru_tech
just bought a dex410v3,unable to find info for a undertray. searching here and google came up with nothing.
is there any difference in the chassis from previous versions to the v3.
or will any 410 undertray fit.
thanx
Oople.com there a guy there that sells undertray for 2010 specs,will fit V3 also.
slow_jun is offline
Old 10-16-2011, 04:37 AM
  #7699
littlejohn's Avatar
thanx
PM Bugle on RCTech..
I'm sure he still makes under trays for the 410.
littlejohn is offline
Old 10-16-2011, 04:40 AM
  #7700
slow_jun's Avatar
Originally Posted by mpv
Hello everyone I have a problem when I put some batteries Orion 4600 can not be swollen to close the Battery Holder what to do?
Battery is relatively new and I do not want to throw it.
Put some spacer under your gearbox loop holder and battery holder.
You'll get some mm and raise the battery holder.
slow_jun is offline
Old 10-16-2011, 06:52 AM
  #7701
Trader Rating: 47 (100%+)
Looks like I will be selling my V3 very soon as this class just sin't big here... It has one race from last night and thats it...
so be on the look out very soon for a used car...
BTW anyone curious about the durability although didn't realy wreck in the main but it out lasted the AE car and Xfactory car... so all the AE guys bashing how pricey the car is over their car thats why...lol
-DC-
smitty2802 is offline
Old 10-16-2011, 12:12 PM
  #7702
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
-DC-
Let them bash, pm me if you want my durango setup for indoor clay. Then they will stop talking smack, it's silly fast and has more steering on or off power than the other cars I have ran with. Also the car only has 2 weak points, the front arms on the aft side of the outer pin, and the rear bulkhead. I only broke parts the first night of the points series and that was when I was lawn darting it after the triple on my first night of offroad in 7 years.
rx7ttlm is offline
Old 10-16-2011, 03:11 PM
  #7703
Has anyone set up their 'rangos for road racing against the touring cars (Open Class)? I'm sorta curious how they'd compare..
Feijai is offline
Old 10-16-2011, 05:19 PM
  #7704
rx7ttlm's Avatar
Are you serious? Given the little bit I have ran my car on asphalt, I wouldn't bother doing that. If the touring car drivers are worth their salt you would be DFL for sure. You are sure to be traction rolling constantly if you get it hooked up...
rx7ttlm is offline
Old 10-16-2011, 11:31 PM
  #7705
Bugle's Avatar
Yep i've still got undertrays, front bumpers, and bodies, here's the oople thread http://www.oople.com/forums/showthread.php?t=62319 pic of the undertray on page 3
Bugle is offline
Old 10-17-2011, 05:26 AM
  #7706
Trader Rating: 51 (100%+)
What are you guys doing to keep the diffs from leaking? They just started to leak after a few practice days. I know Matt Howard posted some different o-rings anyone know the part #?
Apex is offline
Old 10-17-2011, 05:47 AM
  #7707
tobamiester's Avatar
Trader Rating: 360 (100%+)
http://www.team-durango.com/blog/201...diff-seal-mod/
tobamiester is offline
Old 10-17-2011, 06:10 AM
  #7708
Briguy's Avatar
Trader Rating: 125 (100%+)
Kyosho P-5 0-rings work . I have an o-ring kit for work and just found one that would fit and no leaks since .
Briguy is offline
Old 10-17-2011, 07:05 AM
  #7709
Trader Rating: 19 (100%+)
Tresrey-usa.com offers P5 orings as well. They work very well- havent had a leak from them in the buggy or either of our desc trucks in a looong time. Also a friend at the track started using Permatex non drying sealant where the diff cup meets the ring gear and has no leaks there either.
Jonny5 is offline
Old 10-17-2011, 08:55 AM
  #7710
Thanks! Will try the Durango o-rings first.
Apex is offline
