Like Tree22Likes
Old 10-13-2011, 03:48 AM
  #7681
getpip's Avatar
Originally Posted by R-E-A-P-E-R-
Looks good, I would get an aluminum servo arm. With that it should be bullet proof.
Cheers reaper...
I will add it to the list that includes the alloy front hinge pin mount.
getpip is offline
Old 10-13-2011, 04:53 AM
  #7682
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Originally Posted by getpip
Cheers reaper...
I think you have it already with the Tresey servo saver arm in red.
Jmuck69 is offline
Old 10-13-2011, 06:35 AM
  #7683
TAMAK's Avatar
Trader Rating: 29 (100%+)
I think he mean the actual steering servo arm with the spline. An ALU one will make it bullet proof matched with the Tresrey piece
TAMAK is offline
Old 10-13-2011, 09:49 AM
  #7684
dangerwr's Avatar
That is exactly what he means! I think most people found that the Losi servo horn worked well--the one from the 8ight. I re-tapped mine for metric threads but is not necessary. Not sure if the ones for the TLR22 will work. Anybody?
dangerwr is offline
Old 10-14-2011, 12:09 AM
  #7685
mpv
Hello everyone I have a problem when I put some batteries Orion 4600 can not be swollen to close the Battery Holder what to do?
Battery is relatively new and I do not want to throw it.
mpv is offline
Old 10-14-2011, 02:15 AM
  #7686
Briguy's Avatar
Trader Rating: 125 (100%+)
I wasn't aware Orion makes a 4600 saddle pack , they make a 4500 that fits with no problems . Batteries with a height of 25mm max will fit .
Briguy is offline
Old 10-14-2011, 06:09 AM
  #7687
dangerwr's Avatar
Yeah, I had a pair of 45C 4500mAh "Carbon Molecular" packs that swelled a little after a vehicle fire and would no longer fit. Any LiPo you get for this car will not likely fit after a little swelling. Everything is so tight and is simply an expensive car/class to run . . .
dangerwr is offline
Old 10-14-2011, 06:19 AM
  #7688
jessbens's Avatar
get some gen ace $28 bucks 25c 4800mam not bad for the price.free shipping on orders over $50.i got two and can't tell the diff from my protech 60c 5100mam.
jessbens is offline
Old 10-14-2011, 06:21 AM
  #7689
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
What position for ackerman has the smoothest steering? Front or back? Thanks...
Bman's 3XNT is offline
Old 10-14-2011, 06:24 AM
  #7690
TAMAK's Avatar
Got some big bores and Alu rear inserts on the DEX410r going V3 bound. I also had a theory, I cracked a rear bulkhead last week and I came to the conclusion that with the DEX410r shock towers add 2 holes because it shares the same shock tower as the short course.
And since its longer it sits up higher and will be more prone to impacts when the car goes upside down. The wings usually assists with the cush but not when the tower adds that much height. Thoughts? Anyone crack bulkheads with carbon towers?
TAMAK is offline
Old 10-14-2011, 11:01 PM
  #7691
........Thoughts? Anyone crack bulkheads with carbon towers?
Yes. But was because I was landed upon...repeatedly. Broke rear bulkhead, etc. Pretty much everything in 2 peices.
Seeds is offline
Old 10-15-2011, 07:21 AM
  #7692
Anybody? Randy? Thanks in advance.......
Old 10-15-2011, 11:03 AM
  #7693
subaru_tech's Avatar
Trader Rating: 106 (100%+)
just bought a dex410v3,unable to find info for a undertray. searching here and google came up with nothing.
is there any difference in the chassis from previous versions to the v3.
or will any 410 undertray fit.
thanx
subaru_tech is offline
Old 10-15-2011, 11:34 AM
  #7694
Any news on when the next batch will get out?
putte_Rolf is offline
Old 10-15-2011, 12:35 PM
  #7695
ABBOTT's Avatar
thanx
No difference in the chassis besides the countersinking. The only under tray I have seen comes with the Team Azarashi body if you can still locate one. Chassis holds up really well and bodies made for this car all fit very close to sides. What purpose would it serve?
ABBOTT is offline
