Like Tree22Likes
Old 10-11-2011, 06:12 PM
  #7666
Trader Rating: 19 (100%+)
Originally Posted by jmackani
I am on my iphone, so i can't get a good picture. If you are referring to the rear hubs, they can go either way. It will either add ir subtract one degree of toe. I recall keeping r on the passenger will decrease rear toe in.
Its a nice touch to be able to do both. We generally do not want to take any toe away, but having the ability to add or subtract without buying a dedicated separate set is a pretty smart design. I imagine the guys over in Europe use that feature more often running on Astroturf with flypaper-like traction to induce some rotation.
Jonny5 is offline
Old 10-11-2011, 09:33 PM
  #7667
dangerwr's Avatar
So I finally dusted this car off today to start getting ready for the winter racing season. The thing still stinks from 3 Novak Kinetic fires! I think I have figured what I need to do to upgrade to the v3 stuff. I have a few questions . . .
Last year I ran black springs up front and light-green in rear--does it make sense to start with the same spring rate on the big bores?
Also, are most people still running the brass weights? I see those were not part of the new v3 package.
Lastly, is Durango going to switch the wheels over to the 14mm hex? Thanks,
- D
dangerwr is offline
Old 10-11-2011, 10:04 PM
  #7668
Originally Posted by omalley72
Anyone have any input? There are too many pages to scan through, figured id just ask.
I use the drive pins from the TC3 (shorter and dia. is slightly larger so there is a sung fit) and run B4 wheels in the rear. Same offset, etc. Since no one in my area carries Durango parts and the AE rims are easier to find...simple solution. Now...anyone know if there is a front rims replacement out there instead of running the TD rims?
Seeds is offline
Old 10-12-2011, 02:22 AM
  #7669
Briguy's Avatar
Trader Rating: 125 (100%+)
- D
When my V3 comes I plan to run the same spring rates . The V3 doesn't come with some things the previous did to keep the price down . I have never ran the weight kit , same effect can be done by placing sticky weights in certain areas on the car . Yes , the V3 has 14mm wheels .
Briguy is offline
Old 10-12-2011, 06:30 AM
  #7670
dangerwr's Avatar
Cool, I will stick with the same spring rates. I really liked how the car handled after adding those crazy brass weights--especially in and out of jumps. I just wonder how long it will be before the 14mm hex wheels will replace the old 12mm stock everywhere.
I cannot find a P/N for the 14mm wheel hexes anywhere . . .
dangerwr is offline
Old 10-12-2011, 06:34 AM
  #7671
Briguy's Avatar
Ya , there are a few things I want to put on mine from the V3 and part numbers seem to not available . Maybe someone who has a V3 could scan and post the list of part numbers in the manual ?
Briguy is offline
Old 10-12-2011, 06:37 AM
  #7672
Jmuck69's Avatar
Trader Rating: 14 (100%+)
http://www.team-durango.com/part-inf...artNo=TD330312 for Plastic
http://www.team-durango.com/part-inf...artNo=TD310226 for aluminum
Jmuck69 is offline
Old 10-12-2011, 07:57 AM
  #7673
dangerwr's Avatar
Much appreciated!
dangerwr is offline
Old 10-12-2011, 10:19 AM
  #7674
grapejuice's Avatar
Trader Rating: 152 (100%+)
Ran my car for the first time last night with the big bores and what a difference!! The one thing I didn't like about the carbon chassis before was it seemed to bounce a little, wasn't as planted when landing jumps as the aluminum chassis (wasn't big deal, just had to hit the down side like you are supposed to ). But now I can send it with no worries, I was over shooting stuff on purpose and it would land perfect, which made it that much better driving it properly! And the new Tresrey 6.5 has got some RIP!!
grapejuice is offline
Old 10-12-2011, 10:35 AM
  #7675
t8rtot's Avatar
Trader Rating: 14 (94%+)
v3 wheels are available on the Durango website
t8rtot is offline
Old 10-12-2011, 12:01 PM
  #7676
dangerwr's Avatar
Very nice! I really have no idea what springs or oil to run in these big bores so will just start with what I ran in the standard bore shocks. I have long forgot what I had in there from the Hupo setup. Any chance you are going to post a setup someday or keep it secret? Maybe just post it on the message board at MHOR?
dangerwr is offline
Old 10-12-2011, 12:07 PM
  #7677
grapejuice's Avatar
I just ran the 6x1.2 pistons front and rear, losi 35wt. front and 30wt. rear and the springs that came with the big bores, dark blue front, light blue rear. I've got some more springs coming to try out.
Old 10-12-2011, 01:10 PM
  #7678
ABBOTT's Avatar
1) their are a couple charts a the TD site for spring rates and the bigbores colors match up close but no exact, the BB come with the same blue/l.blue that the R came with I am starting with Green/L. Green and 6x1.2 pistons
2) wieghts are up to your setup, The guys at our track are working on lighting the car up so I will share once its figured out. They are just on e of the many things that were eliminated to get the pricepoint right.
3) Yes they have new wheels if you have plenty of old ones that work for your track then why change? I think you only have to add the new hexes to update to the new wheels and Al clamp ons should be out some.
ABBOTT is offline
Old 10-12-2011, 02:53 PM
  #7679
getpip's Avatar
I know I'm a little late to the party but I just finished building my V2 DEX410R.
I took some pics and posted them on my website if anyone is interested.
See them here... Clicky
I shall now set about reading some of the 500 preceding pages .. yikes!
getpip is offline
Old 10-12-2011, 05:28 PM
  #7680
R-E-A-P-E-R-'s Avatar
Looks good, I would get an aluminum servo arm. With that it should be bullet proof.
R-E-A-P-E-R- is offline
