Like Tree22Likes
Old 10-10-2011, 05:10 PM
  #7636
Briguy's Avatar
Trader Rating: 125 (100%+)
Briguy is offline
Old 10-10-2011, 05:34 PM
  #7637
dangerwr's Avatar
Originally Posted by Briguy
There is a good chance he will not remember as he has fried his brain.
dangerwr is offline
Old 10-10-2011, 05:36 PM
  #7638
Konich's Avatar
I thought he was running a 32 or 33 pinion with that setup? If you search this thread I think he posted it up before.
Konich is offline
Old 10-10-2011, 05:48 PM
  #7639
jmackani's Avatar
Trader Rating: 14 (100%+)
Originally Posted by TAMAK
Has anybody tried this mod? I am debating on giving it a go. http://www.tsrproducts.com/index.php...ed-series.html
I have not tried it yet, but that mod is not necessary if you shim the ring gear properly.
jmackani is offline
Old 10-10-2011, 08:19 PM
  #7640
bronc4now's Avatar
Trader Rating: 43 (100%+)
MY UPDATE V3 KILLER ...
IF U SEE SOME THING OUT OF PLACE HELP A BROTHER OUT !!
I WAS UN SURE ABOUT THE REAR CARRIERS LEFT RIGHT .. THANKS
http://www.youtube.com/watch?v=cWDNQpR4ssQ
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-img_0235-small-pic.jpg
bronc4now is offline
Old 10-10-2011, 08:23 PM
  #7641
Konich's Avatar
Looks good! Especially those red parts
Konich is offline
Old 10-10-2011, 08:25 PM
  #7642
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by t8rtot
looking at multiple different setups, i notice some guys (running big bores) running 3-4 hole pistons. there are only 6-hole pistons available (to my knowledge), are you guys gluing holes closed?
yup, aka tire glue with some kicker does the job nicely.
rx7ttlm is offline
Old 10-10-2011, 08:58 PM
  #7643
Trader Rating: 47 (100%+)
I could be mistaking... but I think you do have them on backwards...
You can see the R 1.0 should be on the right hand side of the car...
from the picture it looks like you have it on the left..
-DC-
smitty2802 is offline
Old 10-10-2011, 09:07 PM
  #7644
Briguy's Avatar
Actually he has them on right . R and L are marked from looking at the front of the car , unlike most others .
Briguy is offline
Old 10-10-2011, 09:22 PM
  #7645
dangerwr's Avatar
Gas huffers.
dangerwr is offline
Old 10-10-2011, 09:30 PM
  #7646
ABBOTT's Avatar
Great that this came up, this is easy to miss and the new V3 owners need to know if they try out different hubs.
I put the caster blocks on the wrong side when I built the first kit and was wondering why it handled a little odd! Turned in great!
ABBOTT is offline
Old 10-10-2011, 10:07 PM
  #7647
TAMAK's Avatar
Trader Rating: 29 (100%+)
Those look like they are on backwards.
TAMAK is offline
Old 10-10-2011, 10:14 PM
  #7648
TAMAK's Avatar
This mod is not meant to be set and forget either, you still have to shim it with this mod. This supplement just makes it more rigid so at higher impacts the bevel gear does not move as much. kinda why they sell it with Alu diff hoops.
Either way I am very dissaponted in the material quality of the ring gear. like I said in myprevious post BNIB ring gear had extreme porosity on the tips of the gears. I think that really is the only draw back of the car.
TAMAK is offline
Old 10-10-2011, 10:40 PM
  #7649
dangerwr's Avatar
Is that why they sell a machined gear? So you do not have to worry about the stock cast??
dangerwr is offline
Old 10-11-2011, 12:06 AM
  #7650
Trader Rating: 18 (100%+)
Is it possible to run the JConcepts B44.1 wheels? I'd like to have some options when it comes to wheels.
omalley72 is offline
