Like Tree22Likes
Old 09-27-2011, 09:53 AM
  #7486
dangerwr's Avatar
Originally Posted by Tmachine
Looking into how much this upgrade will be...
Just looking to see what are the part numbers to upgrade the dex410R to the v3... Much appreciated!
~$200
dangerwr is offline
  #7487
Trader Rating: 71 (100%+)
Originally Posted by dangerwr
~$200
thanks... are the parts out?
Tmachine is offline
Old 09-27-2011, 10:01 AM
  #7488
dangerwr's Avatar
http://www.team-durango.com/part-info.p ... o=TD220003
http://www.team-durango.com/part-info.p ... o=TD310145
http://www.team-durango.com/part-info.p ... o=TD310208
Here are most of them. Do not forget the big bore shocks and the new wheel hexes. A-main has most everything but you will need to add the "R" to the part #. E.g., TD220003 = TDR22003 on A-Main.
dangerwr is offline
Old 09-27-2011, 10:24 AM
  #7489
TAMAK's Avatar
Trader Rating: 28 (100%+)
Okay, I get the concept of the Flex brace system. But has anyone had any experience with it? And what were your thoughts?
TAMAK is offline
Old 09-27-2011, 10:52 AM
  #7490
Trader Rating: 49 (100%+)
So when is the V3 supposed to be released?
Apex is offline
Old 09-27-2011, 10:57 AM
  #7491
t8rtot's Avatar
Trader Rating: 14 (94%+)
just like i said on the last 3 pages its been available.. plz look around
in there featured product section
http://www.losipartshouse.com/servlet/StoreFront
and i just called, they're in
t8rtot is offline
Old 09-27-2011, 11:25 AM
  #7492
Konich's Avatar
Originally Posted by rx7ttlm
I don't know the reason for those. I have broken 2 front arms (trying to figure out how to make a technical triple jump) and stripped rear wheels (lrp 6.5 son!) But other than that no issues. I would be curious to hear the rational for them...
They keep the drivetrain in line with less flex. This helps with less ring gear problems a pinion gear wear issue's. It takes the flex out of the center driveline.
Danger, you wouldn't have a clue as you can't get your car to even run a 6min heat
Konich is offline
Old 09-27-2011, 12:10 PM
  #7493
dangerwr's Avatar
Is this coming from a guy whjo is scared to race 8th scale and has been running his Rango all by himself @ MHOR? No??
dangerwr is offline
Old 09-27-2011, 03:14 PM
  #7494
tobamiester's Avatar
Trader Rating: 359 (100%+)
Still running my DEX410R getting on for the best part of a year and still loving how it drives. Not dumping it on the Sale forum just yet...
Recently put ceramics in it to lesson mechanical friction etc to try and bring down temps in the ESC/motor. Went down from an 8.5 to a 10.5 and its just as fast and runs cooler (I think the 8.5 was just tired anyways).
The car has started to make a horrific noise. It sounds like the mesh is bad but I just replaced the spur and I know thats all good. If i hold the car off the ground it sounds pretty normal, but as soon as their is resistance on the ground, it just sounds nasty. Anyone have this experience and a remedy ? I've pulled the front Diff apart to see if its anything, but don't see any excess wear....
tobamiester is offline
Old 09-27-2011, 03:21 PM
  #7495
TAMAK's Avatar
Look at the set screw that holds the drive shaft axle to the Bevel Gear. Make sure it push all the way in and has lock tight.
TAMAK is offline
Old 09-27-2011, 03:39 PM
  #7496
Learn't the hard way on thread locking the Rango. She's all red-threadlocked up the wazo... Like I mentioned, it sounds normal if I hold it off the ground and blip the throttle...
Old 09-27-2011, 05:22 PM
  #7497
Trader Rating: 94 (100%+)
just bought one from them (losipartshouse) thanks for the tip
redracerd is offline
Old 09-27-2011, 05:24 PM
  #7498
Briguy's Avatar
Trader Rating: 125 (100%+)
Looks like you just bought the last one too .
Briguy is offline
Old 09-27-2011, 06:42 PM
  #7499
ASH93A's Avatar
Default DEX210
Hey, just noticed losiparts house lists the DEX210 as 3 in stock!! is this correct??
ASH93A is offline
Old 09-27-2011, 06:45 PM
  #7500
Team Tekin
Randy_Pike's Avatar
Doubtful since they still have their "pre order" note up.
Randy_Pike is offline
