Like Tree22Likes
Old 09-26-2011, 06:04 AM
  #7456
jessbens's Avatar
come on someone i need wheels for the v3
jessbens is offline
Old 09-26-2011, 06:31 AM
  #7457
Originally Posted by rx7ttlm
I would stick with the saddle packs. With the new generation of high C lipos and esc's that are configured to use them they actually operate more efficiently and can even lower motor/ esc temp when properly paired (Example R10 esc, orion v4 motor and 90c packs).
Sounds like another R10 and VST pro motor to be ordered. Leaving my existing R10 in my TRF511.
mikeyscott is offline
Old 09-26-2011, 06:36 AM
  #7458
Trader Rating: 86 (99%+)
Forgive the newb questions as I'm very new to 1/10th electric, I've been a long time nitro racer but don't have the time to maintain them in between races and now that my younger children want to get into the hobby I've decided to run 1/10th scale electric. I had a chance to drive a fellow racers durango 4wd buggy and really enjoyed it so I purchased the new V3 buggy. First question I take it since the new v3 buggy has a larger hex standard 1/10 4wd buggy wheels will not fit it and I will have to purchase durango one's specifically for this buggy? Also what would be a good starting setup for the v3, I realize it will need tuned to my driving style but I'm just looking for a good baseline, I run on a large indoor 1/8th sized offroad track with good traction and that is for the most part fairly smooth. Thanks for helping out the newb .
WideOpenThrottle RC is offline
Old 09-26-2011, 06:53 AM
  #7459
TeamDurango's Avatar
Hi, congratulations on the new purchase.
The 14mm hex wheels are, we belive, the future - they are far better than the older mounting methods which have been the 'standard' up until now.
The V3 comes with the hardware required to run regular pin-drive wheels on the rear should you choose to run your old wheels but you'll need to purchase the small hex for the front if you want to run the older wheels:
WHEEL HEX FRONT (2pcs) Part No: TD510001
Like I said however - the new 14mm hex wheels are a really good move - they handle the power of modern brushless systems and big jumps / high traction much better than the old mounting method and provide a really solid mounting method whilst reducing the load on the pin.
Take a look on the Team Durango setup section http://www.team-durango.com/in-the-pits.php - There might be a setup for a track similar to yours on there already which might help.
TeamDurango is offline
Old 09-26-2011, 07:27 AM
  #7460
Briguy's Avatar
Trader Rating: 125 (100%+)
Hopefully my LHS has mine coming this week !
Briguy is offline
Old 09-26-2011, 08:08 AM
  #7461
Thanks for the quick reply, any idea on when the new wheels will be hitting the shelves at hobbyshops in the U.S.?
Old 09-26-2011, 08:49 AM
  #7462
Sorry for the delay on the new 14mm wheels - unfortunately they're still 1, maybe 2 weeks away from hitting the US shops.
Old 09-26-2011, 09:31 AM
  #7463
Briguy's Avatar
Do you have a part number for the wheels ?
Some reason on the website the links to the standard parts and option parts is now gone . Were there the other day .
Briguy is offline
Old 09-26-2011, 10:27 AM
  #7464
TD when will rest of the world get there first 410v3? =)
putte_Rolf is offline
Old 09-26-2011, 10:40 AM
  #7465
Trader Rating: 51 (100%+)
http://www.team-durango.com/race-cars/dex410v3/
Apex is offline
Old 09-26-2011, 11:14 AM
  #7466
Briguy's Avatar
I received an email back from HRP that they will be available in about a month !!!
Briguy is offline
Old 09-26-2011, 12:32 PM
  #7467
t8rtot's Avatar
Trader Rating: 14 (94%+)
there are several companies that have them in stock??
absolutehobbyz is one
t8rtot is offline
Old 09-26-2011, 12:36 PM
  #7468
TAMAK's Avatar
Trader Rating: 29 (100%+)
Nah, check again... The DEX410r is available from that place still
TAMAK is offline
Old 09-26-2011, 12:38 PM
  #7469
Briguy's Avatar
Not according to them .
Briguy is offline
Old 09-26-2011, 02:46 PM
  #7470
Trader Rating: 47 (100%+)
I know when my fiance called and ordered mine it was either the last one they had or next to the last one maybe.
-DC-
smitty2802 is offline
