Like Tree22Likes
Old 09-22-2011, 01:43 PM
  #7411
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by Randy_Pike
Lol. Funny as I will be testing a 4 pole 1/8" shaft in mine here shortly. Braat
Ba ha ha ha, Funny cause my 6.5 has pretty good power... lol. Maybe I should try to find a 5mm shaft 48 pitch 25 tooth lol.
rx7ttlm is offline
Old 09-22-2011, 02:44 PM
  #7412
Originally Posted by damn-yankee
Nice! So they should be here (usa) soon?!
Just got an email from amain, my V3 is here!
Poptartninja is offline
Old 09-22-2011, 04:56 PM
  #7413
grapejuice's Avatar
Trader Rating: 153 (100%+)
I want to see that!!
grapejuice is offline
Old 09-22-2011, 05:32 PM
  #7414
dangerwr's Avatar
GrapeJuice,
I need a setup for MHOR. Will you help? Did you guys go over to the big bore shocks? Thanks,
- Danger
dangerwr is offline
Old 09-22-2011, 07:25 PM
  #7415
Konich's Avatar
We will have big bores in next week to start getting setups for MHOR
Konich is offline
Old 09-22-2011, 10:36 PM
  #7416
Jeauxkor's Avatar
Trader Rating: 29 (100%+)
Me and a buddy are thinking of getting into 1/10 4wd. We have our eye on the this buggy. What are the pros and cons. How is the part availability and cost? I assume they are lipo ready. And lastly, what kind of motor/ esc set ups are popular other than the 300 dollar tekin systems. Battery type? Sorry for all the questions. We are leaning towards this buggy because of the gear diffs.
Jeauxkor is offline
Old 09-22-2011, 10:59 PM
  #7417
V3 should be even stronger than my 410R, especially with the HD ball cups and alloy suspension hangers. The car is also easy to work on.
Early versions with alloy side rails etc were a bit twitchy, but with plastic rear brace and side rails all is good, but still prefers a smoother driving style.
Part supply is good in the UK, and can't see it being any different in the US where the importer is HRP in Utah, and you can get parts direct from them if needed by ordering online. They also show were your latest model shop that supports TD is.
I use an Orca Vritra esc which is good, have also seen a lot of Hobbywings that by all reports are also good, and pretty cheap.
All legal Lipo saddle packs will fit, max height is 25mm.
For more info look at Oople.com, where there is lot of easy to access info.
Badger5 is offline
Old 09-23-2011, 12:14 AM
  #7418
rx7ttlm's Avatar
The pro's are durability(alot of the 4wd buggies are on the fragile side), the gear diffs are great for reduced maintenance, car handles great. Parts so far are rather inexpensive (shock o rings are $1.50 compared to kyosho's that are 7-10)
Cons? Previous cars with the non hd ball cups have ridiculous slop in them. It was the price but now that the v3 is out that is gone. The gear diffs still don't have the corner speed of a properly setup ball diff but the difference is slight. And you may have parts support issues if your LHS doesn't stock parts. But they can be purchased through a hobby shop that has an account with HRP or online retailers like amainhobbies. Overall the only other thing I would say could be better is the overall weight (my car races at 130 grams over min weight) But it takes a beating and keeps going.
The esc/ motor setups depend on your preference. I run LRP SXX TC v2 with lrp 6.5 octa or 7.5. Anything with a motor limit below 4.5 should work fine. Tekin rs pro should work well. They are lipo ready, make sure you get a lipo that is 25.1 mm or shorter.
Overall a great buggy. If you need a starting setup etc shoot me a pm or start with Jörn Neumann's setup from the reedy race. I found kinwalds black spring setup to be great in the corners but lacked support in the technical bumps and step up / step off type situations.
rx7ttlm is offline
Old 09-23-2011, 01:05 PM
  #7419
dangerwr's Avatar
Ok, cool. I thought maybe the big bores would be best on bumpy tracks. Maybe the idea is consistency . . . something I read. Will probably be late October before I start showing up at MHOR.
dangerwr is offline
Old 09-23-2011, 01:31 PM
  #7420
t8rtot's Avatar
Trader Rating: 14 (94%+)
i agree with your complete statement. my opinion on the above:
i have noticed i have been able get the rear to rotate really well with the gear diffs and the have a greater "direct drive" to them.. i also have noticed that you have to drive this car differently than other 4wd.. i've watched Jorn and Lutz wheel these and the corner (drift) speed they carry is crazy. and the durango does pull alot harder (by feel) out of the corners than the others i've driven. i think the smaller the track you run on (point and shoot type tracks), the less these benefits weigh. but on med/larger tracks WOW.
t8rtot is offline
Old 09-23-2011, 01:47 PM
  #7421
t8rtot's Avatar
V3 is up!!!!!
http://www.team-durango.com/race-cars/dex410v3/
t8rtot is offline
Old 09-23-2011, 02:23 PM
  #7422
Briguy's Avatar
Trader Rating: 125 (100%+)
Sweet !!
Briguy is offline
Old 09-23-2011, 02:25 PM
  #7423
grapejuice's Avatar
Originally Posted by dangerwr
GrapeJuice,
- Danger
Yeah, haven't touched my wheeler since April Fools but will be very soon!!
Old 09-23-2011, 05:56 PM
  #7424
CanyonCarverR1's Avatar
Default Batteries
Does this car use 2 1s batteries (1/12 style)?
CanyonCarverR1 is offline
Old 09-23-2011, 06:01 PM
  #7425
Briguy's Avatar
The guys that are running the big bores , did you change anything on your setups ? I`m gonna order the V3 and curious about any setup changes .
Briguy is offline
