Like Tree22Likes
Old 06-01-2010, 06:25 PM
  #721
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by O'donnell racer
How's it going all
I put my dex410 on order today for those on here that have had one for awhile should I go head and order the option drive shafts and build with them or are the stock ones fine? I orders the shock spring kits along with extra arms and uprights to have on hand I'll b running the checkpoint sadle pack I don't no the dementions off hand I'm waiting on my backs to arive should be here in a cpl days how much room do I have for battery or if anyone on here has tried these packs did they fit or should I get the 25 mm center mount on order to thanks for the help this looks like a real great car
I run Orion's 4500 45c saddle packs (they are 25mm). I raised the motor, center mount and the rear driveshaft loop. I raised it 1mm. The only thing I did so far is grind the battery strap under the slipper nut a little. Just for added clearence....
Bman's 3XNT is offline
Old 06-01-2010, 06:29 PM
  #722
Guys how does the color spring chart go? I can't understand the sizes to save my life. Thanks..........
Old 06-01-2010, 07:50 PM
  #723
Trader Rating: 21 (100%+)
Thanks for the info
O'donnell racer is offline
Old 06-01-2010, 08:09 PM
  #724
HyperFX's Avatar
Spring Chart
Silver is softest spring rate. Dark Red is stiffest.
HyperFX is offline
Old 06-02-2010, 04:55 AM
  #725
Originally Posted by HyperFX
Spring Chart
Thanks.......
Old 06-02-2010, 06:33 AM
  #726
Originally Posted by TY@TEAMTEKIN
Anyone ever had trouble with their stock servo saver on the DEX10? Mine broke on the first lap ever driving it, didn't even tumble the car. It landed a little on one front wheel and snapped it!
Is there an alloy one?
yep, only part ive broke. i did hit a concrete wall on the strait though. it looks a little weak in the design, but i have yet to break another. its prob. because i have enough parts to build 1 and 1/2 back up cars. if you dont want to break parts buy two or three hundred dollars is spairs, you'll never need them, works for me every time! now when i dont buy spairs i break all the time!
cbrociuos is offline
Old 06-02-2010, 09:17 AM
  #727
HyperFX's Avatar
Ha! Seems the same for me, too. If you don't have a spare, it's gonna break.
Buying spares makes the car bulletproof!
HyperFX is offline
Old 06-02-2010, 09:25 AM
  #728
Team Tekin
TY@TEAMTEKIN's Avatar
Huh. Well I was disappointed to say the least. The rest of the car looks bombproof, I can't believe that's what stopped me from racing it for the first time..
TY@TEAMTEKIN is offline
Old 06-02-2010, 11:19 AM
  #729
grapejuice's Avatar
Trader Rating: 151 (100%+)
That was my one complaint about the car, you barely touch the front end wrong and either the servo horn strips or the servo saver breaks....put an alum. horn on and breaks the servo saver right away. Def. the weak link in the car since everything else is so strong. Was afraid to drive the car hard because if I just barely clip a pipe with the front wheels, something broke with the steering.....
grapejuice is offline
Old 06-02-2010, 11:53 AM
  #730
annonymous's Avatar
This is strange??? this is the only part i have ever heard of breaking, yet i cannot break a single one. No problems at all, and i a running an aluminum servo horn
BTW: i am putting my Rango up for say i a day or so. wanted to give first dibs here - Will have pics when i post in the FS forum
annonymous is offline
Old 06-02-2010, 04:02 PM
  #731
Problem in most of the cases is that the people building the car do not make sure they adjust and build everything correctly. DEX is a heavier car thus it will cause more stress to some parts due to it's exceptionell capabilities of corner speed etc. This applies to driveline where people used to lousy slipping ball diffs do not pay attention to the correct setup of the slipper when the fact is that you need to get it right or things break as you have the power and no slip in diffs.
Also the servosaver holds in normal conditions if it's build up and set up correctly. It will break if you crash a lot or generally drive a lot as it's not designed to be "fool proof". Saying "it broke even I did not crash or anything" is most likely BS though. Anyway you can pretty much break everything man made. So pay attention to it and make sure it works as supposed and keep the dirst out of it so you should be just fine.
Poinas2 is offline
Old 06-02-2010, 07:35 PM
  #732
Ran my Durango for the first time tonight. Made one change from my build setup. Changed the front diff oil to 10K and and the rear camber to -1. First time out with the car and racing 1/10 in months and I was only .4 sec. off the track lap record. A few more changes and the car will be there. But all in all much better than my Kyosho.....
Old 06-07-2010, 10:11 PM
  #733
I'm looking for a back up dex if any one has one they want to sell or trade send me a pm
Old 06-17-2010, 09:14 AM
  #734
R/C Tech Elite Member
Trevor Williams's Avatar
Trader Rating: 207 (100%+)
DEX410 R-spec and DEX210..........any idea when they are going to be released??? I am hoping before Oct. as that's when my 1/10 indoor season starts.
Trevor Williams is offline
Old 06-17-2010, 09:21 AM
  #735
squarehead's Avatar
Trader Rating: 75 (100%+)
Last i heard was the end of this month for the DEX410R, but they have had some parts suppliers change the parts without consent, so they are having a few delays in the production.
There is no known release date of the 210 as far as I know, as they are still in testing of the design and changing things a lot on that car from event to event. Last thing I saw on it, Honigl was running the car as a rear motor layout, so it seems as though they are a bit further from releasing that car to the market it was originally mid motor). Still way early in the prototype phase on that car.
You'll probably see the DEX408 well before the 2wd car.
squarehead is offline
