Like Tree22Likes
Old 09-06-2011, 09:36 PM
  #7306
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Originally Posted by G33Kster
While I'm loading up my shopping cart with a 410R and outdrive boots, which hinge pin holders are most in need of upgrading to aluminum. I know the front one on the front (FF?) is the main concern, but has anyone experienced breakage with the FR or any on the rear ones? I'd like to spend as little as possible while maintaining a durable buggy
I would expect the ff and the rf (2/-2) carriers to be stressed the most. However the only thing I have broken on the car is the front arms.
rx7ttlm is offline
Old 09-06-2011, 09:38 PM
  #7307
Replace all the hinge pin holders, imo.
Then replace the rear gearbox inserts (the R ones are plastic, if you jump a lot you'll break them sooner or later) - TD310007 & TD310006. Again if you jump a lot your rear bulkheads might crack. Mine haven't yet (I've got a 410), but a friend that drives a 410R has broken 2 sets.
greathobbies.com here has one 410 left for $500CDN.. you might be able to talk them down to $400CDN which is what I paid.
Feijai is offline
Old 09-06-2011, 09:42 PM
  #7308
G33Kster's Avatar
Okay, thanks guys. I think I'll just get the aluminum FF holder for now and replace the rest as it is necessary. My local track (NorCal Hobbies) stocks Durango kits, so they ought to have parts as well. I think I'll jump on this soon and click the checkout button. I love building kits so much
G33Kster is offline
Old 09-07-2011, 06:40 AM
  #7309
Does anyone know what is going on with the 410 replacement? If they have discontinued the 410 and are out of stock in most places, shouldn't the new version be imminent? However, I don't see any rumours about it, dates specs etc.
Sorry if I am asking something that has been discussed to death but my searches haven't turned anything up
TongueTied is offline
Old 09-07-2011, 12:04 PM
  #7310
they are working on a new 410 as far as i know
putte_Rolf is offline
Old 09-07-2011, 03:33 PM
  #7311
Default Battery Question
Fellow Racers,
Just finished the 410R build, tried to search for this answer but could not find it. Do you really need to remove the spur to place the batteries in the car or is there a better way to accomplish this. Additionally, does that strap really hold the batteries in or do I need to add something to the chasis to ensure that they do not slide. Your time and attention are greatly appreciated.
Respectfully,
Sean "Airborne" Hicks
sean.hicks.army is offline
Old 09-07-2011, 04:22 PM
  #7312
Team Tekin
Randy_Pike's Avatar
You have to remove the spur/slipper assembly. It takes 5 seconds. One clip on the spur, one clip on the battery door, batteries out.
Randy_Pike is offline
Old 09-07-2011, 05:56 PM
  #7313
jmackani's Avatar
Trader Rating: 14 (100%+)
My LHS received an email today for placing orders on the dex410 v3. So, it must be coming soon.
jmackani is offline
Old 09-07-2011, 06:28 PM
  #7314
Trader Rating: 44 (100%+)
yes, only 2 clips to remove when changing batteries. too easy.
i find some saddle packs doslide within the battery slot. double sided tapes on a few sides will take up any slop.
wyl03 is offline
Old 09-07-2011, 07:45 PM
  #7315
choon meng's Avatar
Default 410 V.3 is out!!
http://www.rcfans.com/brand/store.ph...=good&xid=2898
CHECK THIS OUT!!
choon meng is offline
Old 09-07-2011, 07:53 PM
  #7316
Default battery
Fellow Racers,
Thanks for the answers, did it a couple of times and you are right it was easier than I thought. I am acustomed to dealing with the 44 and thought that I was in for a headache. I will try and not ask a stupid question like that again.
Respectfully,
Sean Hicks
Old 09-07-2011, 08:59 PM
  #7317
Mike Marshall's Avatar
Originally Posted by choon meng
Good find....I have a few customers that are driving me nuts waiting on the new car. I don't know if I should show them this or not. They might start bugging me more then they already do.
Mike Marshall is offline
Old 09-08-2011, 12:04 AM
  #7318
sean - don't worry about it. ask away .. that's why we're all here to learn
just fyi .. taken from Oople.
From TD
"The new features on the DEX410v3 are:-
Big bore shocks - more consistent on rough tracks due to the larger volume of oil.
Gold shock shafts as standard – super smooth Ti Ni coated shock shafts.
New ‘Kuhler’ Body – increased space inside the body and improved air flow to the electronics
New RR suspension arm brace – allows the rear squat to be altered using moulded inserts.
New ‘Fine Tune’ shock towers with finer adjustment for the upper mounting positions and more rear camber link positions on the rear tower.
New HD Ball Ends used throughout – tighter fitting and less likely to pop off during a collision.
Changes from the 2010 kit are:-
Plastic side rails are used in place of the aluminium side rails.
Plastic servo mount is used in place of the machined aluminium one.
Plastic rear gearbox inserts used in place of the machined aluminium parts.
Plastic middle bulkhead used in place of the machined aluminium part.
Moulded upper shock mounts with steel screw.
Revised rear bulkhead and rear gearbox hoop to improve strength in these areas.
Steel turnbuckles used in place of titanium turnbuckles.
Shock and drive shaft boots removed from the kit.
Some of these changes have been made following feedback we received from drivers of the out-going model. After listening to our team drivers and our customers we feel that not all of the machined aluminium parts are required in the kit, so changing these to plastic has helped us bring out a better, but less expensive buggy.
We will still be producing the machined aluminium parts, rubber boots and other option parts for this kit to allow people to upgrade their models should they choose to.
The part number and name for this kit are TD102011 DEX410v3"
wyl03 is offline
Old 09-08-2011, 03:43 AM
  #7319
Good to hear DEX410v3 is going to be out soon. Don't like it when they keep silent on a new product but I can understand why they do it. Hope it wont take too long to get to the stores.
Old 09-08-2011, 04:57 AM
  #7320
Trader Rating: 51 (100%+)
I'm assuming all the new parts will fit on the current 410, right?
Apex is offline
