Like Tree22Likes
Old 08-26-2011, 03:27 PM
  #7246
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
durango- With the big bore buggy shocks can you get bladders for these?
rx7ttlm is offline
Old 08-26-2011, 05:55 PM
  #7247
G33Kster's Avatar
Originally Posted by TAMAK
I am not sure why you would want to go sensor-less? Sensored technology is so inexpensive these days. I would suggest a speed passion GT 2.0 lpf, Novak GTB 2, Havoc Pro SC, or even the new Duratrax DE10 (It should fit). And buy a 8.5t for versatility, you can always dial it down. My .02.
I'm leaning toward sensorless because of cost. I may go for a HobbyWing sensored combo, but the Castle Sidewinder SCT remains cheaper at only $90. Would the Xerun 60A be enough?
http://www.hobbypartz.com/07e-c-xerun-60a-sd.html
G33Kster is offline
Old 08-26-2011, 06:12 PM
  #7248
I have the Sidewinder combo in my SC10 4x4 and I like it very much (good performance and great value!) and I also have a DEX410 2010 Spec but I'm not sure you're going to be able to shoe-horn the Sidewinder in the DEX unless you have a really tiny receiver, like a KO or one of the tiny Spektrum ones.
Cheers,
Mike
Hyper_Mike is offline
Old 08-26-2011, 06:24 PM
  #7249
G33Kster's Avatar
Cheers,
Mike
Awesome, good to hear. I have the original Sidewinder in one of my stadium trucks, but I hear the SCT version handles more amperage and the 4-pole motor should have awesome torque and more smoothness than a standard 2-pole. My receiver should be fine, it's the FlySky GT3 Rx: http://www.hobbypartz.com/fs-gtr3c-receiver.html
If need be, I can probably mount it onto the side of the ESC
G33Kster is offline
Old 08-27-2011, 08:04 AM
  #7250
teeforb's Avatar
Trader Rating: 94 (100%+)
Any pics with lrp tc spec?
Thx
teeforb is offline
Old 08-27-2011, 10:59 AM
  #7251
rx7ttlm's Avatar
Thx
My camera link isnt working right now, can upload some tonight. But I put the solder board close to the front driveshaft and motor wires under.
rx7ttlm is offline
Old 08-27-2011, 03:23 PM
  #7252
what's most of you running for a good starter point for diff oil?
thanks
bring it on is offline
Old 08-27-2011, 03:37 PM
  #7253
tobamiester's Avatar
Trader Rating: 360 (100%+)
thanks
Depends what type of track your running on. I primarily run on a tight high-bite clay track, and run 2k front, 1k rear as anything thicker the car didn't want to rotate as well.
tobamiester is offline
Old 08-27-2011, 03:53 PM
  #7254
Indoor clay mid size track
Old 08-27-2011, 04:25 PM
  #7255
yeah Rick, I'd maybe go up one 1k (both fr/rr) on what I run and see how you like it. I'm sure plenty of other DEX drivers can chime in here with their track experiences.
Old 08-27-2011, 05:23 PM
  #7256
ABBOTT's Avatar
Think its really a personal feel type thing, I use 7/3
ABBOTT is offline
Old 08-27-2011, 05:32 PM
  #7257
wow, one person that runs with me runs 7/3 also, so 2/1 or 3/2 sounds lite but that's why i'm seeing what most start with.
Old 08-27-2011, 06:23 PM
  #7258
rx7ttlm's Avatar
It really depends on configuration, grip and driving style. The car rotates great on power with 5/3 for me. The oil is thin enough to change quickly, But I can't say that running 1000 front and rear makes sense. Usually you run thicker oil front for on power steering and braking, also your losing braking ability with ultra light oils. Get 2-20k mugen oils (or whatever you prefer, I use mugen cause I have a lot, it's consistent and it's relatively inexpensive for cst oils). Start out with 7/3 or 5/3 and make changes. The car does need to be close to the setup your going to run. If it's pushing like a ...... all over and your way off no sense in trying to feel the difference in diff oils. If it loops on power drop down to 2k. Keep in mind that if you have a scale you can mix approximate half weights if one step is to much. Keep in mind you can use things like inserts to tune forward bite and side bite which effects which oils you use.
rx7ttlm is offline
Old 08-27-2011, 06:33 PM
  #7259
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I started off with 15/10 and then 10/5 and everything in between. If you like a twitchier car run heavy oil. On my track (hard pack swept) I settled with 5/3. But if your overpowered or heavy finger you will burn the inside tire. If the car pulls to much or doesn't have enough corner entry, lighter front. If it loops around offpower in the corner, heavier rear. You really have to experiment. I would try 15/10 10/5 and then 5/3, and see what you like best, and fine tune from there. That's all I can say. Good Luck and let us know...........
Bman's 3XNT is offline
Old 08-27-2011, 08:48 PM
  #7260
Thank you
