Like Tree22Likes
Old 08-22-2011, 09:06 PM
  #7231
R-E-A-P-E-R-'s Avatar
Yeah that doesn't look right at all.
R-E-A-P-E-R- is offline
Old 08-22-2011, 10:40 PM
  #7232
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by Lowrance
Yes, the shafts can catch on the outdrive slots. It doesn't really matter which hole on the tower I go to....the result is the same. I guess the only fix other than buying option towers is to add a spacer to the shock shaft to limit upward travel. These towers look the same as the SC tuck parts complete with extra hole on the rear tower for the body mount.
When you built the upper camber links, did you build them stock, ie 20mm between ballcups (are you using stock ball cups btw - looks like it from pic) or did you have to make them shorter ? wondering if there is a problem with the lower rear arms in the kit (i.e they're slightly shorter) making the links needing to be shorter, pushing the Rear 61mm shafts further in the outdrives ?
tobamiester is offline
Old 08-23-2011, 01:37 AM
  #7233
Trader Rating: 30 (100%+)
The drive shafts are printed 61mm and I have double checked this measurement with my calipers. This must be a shock tower issue being to tall or something. I currently have a 2mm spacer along with the supplied rubber bump stop on the shock shaft to limit upward travel. None of the setup sheets I've seen online are like this.
This kit was assembled per instructions and my car building experience dates to 1987. Rear camber is currently set slightly positive at this stage of the build.
Lowrance is offline
Old 08-23-2011, 03:45 AM
  #7234
TeamDurango's Avatar
The DEX410R shock towers are the same as those used on the DESC410R short course truck, and the outer holes are not meant to be used on the buggy. The outer two holes on the rear and the outer on the front are extra holes for the DESC410R truck.
TeamDurango is offline
Old 08-23-2011, 07:31 AM
  #7235
Trader Rating: 29 (100%+)
Any word on the DJoint universals?
Yzlvr is offline
Old 08-23-2011, 08:51 AM
  #7236
t8rtot's Avatar
Trader Rating: 14 (94%+)
+1
t8rtot is offline
Old 08-23-2011, 11:43 AM
  #7237
So the towers are the same....can you tell me if the dimensions are the same from the R tower against the SPEC tower, the inner holes of course. Thanks
Lowrance is offline
Old 08-23-2011, 05:12 PM
  #7238
Dadaman's Avatar
Trader Rating: 20 (100%+)
+3.
Dadaman is offline
Old 08-24-2011, 01:33 PM
  #7239
TAMAK's Avatar
Just finished the build. The GTB2 was the ESC of choice that I had laying around. Only thing I need to watch for is the servo wire binding because its the Low Profile savox. Yes, i do need to secure that switch
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410_1.jpg
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410_2.jpg
Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410_3.jpg
TAMAK is offline
Old 08-24-2011, 03:26 PM
  #7240
gene1219's Avatar
Trader Rating: 16 (100%+)
Lookin' good Tamak! We had a nice solid heat at Streamwood last night. We need some more 'rangos out there (only 2 of the 5 were dex410)
gene1219 is offline
Old 08-25-2011, 09:30 AM
  #7241
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Check this out.......no more leaving screws loose!
http://www.team-durango.com/part-inf...artNo=TD220003
Bman's 3XNT is offline
Old 08-25-2011, 09:49 AM
  #7242
TAMAK's Avatar
Its great to see that they are still developing the 410. Maybe the V3 with still be based on that chassis? Does anyone know?
TAMAK is offline
Old 08-25-2011, 11:10 AM
  #7243
gene1219's Avatar
Here's a pic of my DEX410R wired up. I still have to shorten the servo wire since it's long enough to repel from a building.
gene1219 is offline
Old 08-25-2011, 10:01 PM
  #7244
G33Kster's Avatar
Hey guys, I'm thinking of picking up a DEX410R for some fun at the track and some bashing (no, I'm not throwing it off buildings, I'm running it up and down the street and taking it on some trails at the park). I wish I had the time to read this whole thread but from my search, there's no answer to my question yet: Will the Sidewinder SCT combo work for this, specifically the 3800Kv motor? From what I've seen, it's a good bit lower Kv than what others are running. I know it has the torque to gear it up, but I dunno if there's enough space for a big ol' pinion. If that setup is not suggested, what Kv of Castle motor should I be looking for? 5700Kv? Thanks
G33Kster is offline
Old 08-26-2011, 06:11 AM
  #7245
TAMAK's Avatar
I am not sure why you would want to go sensor-less? Sensored technology is so inexpensive these days. I would suggest a speed passion GT 2.0 lpf, Novak GTB 2, Havoc Pro SC, or even the new Duratrax DE10 (It should fit). And buy a 8.5t for versatility, you can always dial it down. My .02.
TAMAK is offline
