Like Tree22Likes
Old 08-21-2011, 02:00 PM
  #7216
morgoth's Avatar
Is it just me or are the stock bearingscrap?
morgoth is offline
Old 08-21-2011, 02:04 PM
  #7217
Trader Rating: 30 (100%+)
Building a new 410R here and was wondering if anyone has had problems with the CVD shafts binding on the diff outdrives at full upward suspension travel. My rears are binding pretty good on the bench....fronts are close. I even used the little rubber bump stops on the shock shafts but still pretty tight on clearance. I'am afraid that the CVD shafts will bend if ran like this.
Lowrance is offline
Old 08-21-2011, 02:09 PM
  #7218
Matt Howard's Avatar
It's not you, they're pretty much junk. I replace mine with Avids as they go bad.
Matt Howard is offline
Old 08-21-2011, 03:32 PM
  #7219
Team Tekin
Randy_Pike's Avatar
Where is the binding actually at? Is it near the diff outdrive or near the cv joint?
Does it go away if you take away the droop in the suspension?
Randy_Pike is offline
Old 08-21-2011, 04:07 PM
  #7220
At the diff outdrive at full suspension compression....extended looks good.
Another question regarding setup sheets....my "R" model has aluminum towers with four mounting positions in the front and five in the rear. How do these additional mounting holes correspond to what I see on the setups. All the setups I see online have only three mounting positions front and rear. I'am guessing I should go from the inside holes outward.....are the "R" buggy towers shared with the SC truck? Thanks
Lowrance is offline
Old 08-21-2011, 10:13 PM
  #7221
Originally Posted by Lowrance
At the diff outdrive at full suspension compression....extended looks good. Thanks
Are the cvd's locking up in the slots on the outdrives? When the suspension fully compresses,do the shafts go into the slots? I noticed mine do that when the shocks are off. I added o-rings to the shock shafts to prevent it...kinda.
Seeds is offline
Old 08-21-2011, 10:50 PM
  #7222
Yes, the shafts can catch on the outdrive slots. It doesn't really matter which hole on the tower I go to....the result is the same. I guess the only fix other than buying option towers is to add a spacer to the shock shaft to limit upward travel. These towers look the same as the SC tuck parts complete with extra hole on the rear tower for the body mount.
Lowrance is offline
Old 08-22-2011, 03:38 AM
  #7223
morgoth's Avatar
Thanks. I drove my car for the second time outdoors on dirt and my wheel locked up after 7 laps :/
I drove it 3 times on carpet and 2 times outdoors.
morgoth is offline
Old 08-22-2011, 04:15 AM
  #7224
Trader Rating: 51 (100%+)
When I put the 410 together I noticed the bearings were really notchy. I was thinking maybe the grease hardened inside of them since the kit may have been sitting for a while. I ended up putting some bearing oil in them and they became real smooth. I'm hoping this will help them last a little longer. Planning to race in couple weeks so we'll see.
Apex is offline
Old 08-22-2011, 05:25 AM
  #7225
Never noticed my 410 shafts catching on the outdrives, but I run the plastic cups as well as dust boots. The cups prevent the shaft from catching the slot.
Dondor is offline
Old 08-22-2011, 07:43 AM
  #7226
racer x 1's Avatar
Trader Rating: 27 (100%+)
soo i got a great deal on a b44 and took it but now that i saw the deals on the 410r i know i should of bought that instead. is there anyone that can offer some good feedback about the dex from switching from the b44? thanks.
racer x 1 is offline
Old 08-22-2011, 03:35 PM
  #7227
I run the cups as well but only helps a little. They can still get caught in there...and yes no matter where you install shocks or links, still can happen. Adding o-rings to shock shafts help. Haven't locked up.
Seeds is offline
Old 08-22-2011, 05:38 PM
  #7228
Dadaman's Avatar
Trader Rating: 20 (100%+)
On my DEX410 the drive shafts don't go in that far and I get no binding. Have they increased the length of these?
Dadaman is offline
Old 08-22-2011, 07:34 PM
  #7229
ABBOTT's Avatar
Something must have changed. My buggy cant be made to do that in any position with the shocks on.
ABBOTT is offline
Old 08-22-2011, 07:53 PM
  #7230
t8rtot's Avatar
Trader Rating: 14 (94%+)
Possibly using the wrong ones?
t8rtot is offline
