Like Tree22Likes
Old 05-19-2010, 08:49 AM
  #706
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Default 25mm motor plates?
This was listed in the option parts for the 410 and as standard for the 410R. Is this to raise the spur gear up for taller lipos?
Jmuck69 is offline
Old 05-19-2010, 08:56 AM
  #707
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Crazy Carl
If I can help you guys out with setup info I will try
I currently run my car indoors on hard pack top soil clay mix
Often damp and med. bite
I will be running out doors in the near future
You can help me out by hooking me up with some white front rims. Thanks....
Bman's 3XNT is offline
Old 05-19-2010, 06:32 PM
  #708
fifi's Avatar
The 410R will have taller motor plate to accept the new 25mm lipo.
The 25mm motor plate will be an option for the 410. You will also have to take the 25mm mid drive plate. I think that it came in plastic on 410r and they make it has an option in aluminium.
#TD310155 MID DRIVE GEAR PLATE (ALUMINIUM) (25MM)
fifi is offline
Old 05-19-2010, 06:38 PM
  #709
HyperFX's Avatar
Originally Posted by Bman's 3XNT
I ordered some spare parts from Durango yesterday. They where out of all front rims. You wouldn't happen to have a new spare set would you? I would like to get the car running asap. Thanks....
Sorry, can't help with front wheels.
But, the Associated B44, and JConcepts B44 Rulux will work, if you can find them.
HyperFX is offline
Old 05-19-2010, 09:01 PM
  #710
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Ill look around
Pm me an address if I find a set
Crazy Carl is offline
Old 05-20-2010, 03:12 AM
  #711
Ill look around
Are you coming up to RCHR this weekend? If so I will talk with you then. Let me know if you find them, even if they are used but in good shape. Thanks Carl......
Old 05-21-2010, 07:07 AM
  #712
Guys found some front rims. Team Durango has them back in stock.......Thanks
Old 05-25-2010, 07:27 AM
  #713
annonymous's Avatar
Trader Rating: 21 (100%+)
anyone done any testing with the new 2.0 shafts? they have been out for a week or so now. . . .
annonymous is offline
Old 05-25-2010, 08:48 PM
  #714
How's it going all
I put my dex410 on order today for those on here that have had one for awhile should I go head and order the option drive shafts and build with them or are the stock ones fine? I orders the shock spring kits along with extra arms and uprights to have on hand I'll b running the checkpoint sadle pack I don't no the dementions off hand I'm waiting on my backs to arive should be here in a cpl days how much room do I have for battery or if anyone on here has tried these packs did they fit or should I get the 25 mm center mount on order to thanks for the help this looks like a real great car
O'donnell racer is offline
Old 05-26-2010, 04:02 PM
  #715
fifi's Avatar
For diff leaking, I replaced the black o ring with some kyosho
Kyosho Silicone O-Ring Set (P5/Orange) (10) [KYOORG05]
2 races and some practice no leak since.
fifi is offline
Old 05-27-2010, 06:15 PM
  #716
thanks for the tip, ill try that the next time i pull them out.
cbrociuos is offline
Old 05-27-2010, 07:04 PM
  #717
Also try sanding the plastic diff case with some fine grit sandpaper. Do it in a figure 8 motion. This should help seal it better against the gear as well.
Old 05-27-2010, 09:27 PM
  #718
HyperFX's Avatar
I haven't had a diff leak, yet. But I have had the grease that was applied to the ring gear, leak to the outside of the housing.
HyperFX is offline
Old 06-01-2010, 04:15 PM
  #719
fifi's Avatar
Team durango will offer 50% off for 2mm driveshaft.
fifi is offline
Old 06-01-2010, 04:24 PM
  #720
Team Tekin
TY@TEAMTEKIN's Avatar
Anyone ever had trouble with their stock servo saver on the DEX10? Mine broke on the first lap ever driving it, didn't even tumble the car. It landed a little on one front wheel and snapped it!
Is there an alloy one?
TY@TEAMTEKIN is offline
