Like Tree22Likes
Old 08-01-2011, 08:49 AM
  #7111
R-E-A-P-E-R-'s Avatar
If that is a med sized outdoor track then I have got to see a large one. That track is large for 10th scales.
R-E-A-P-E-R- is offline
Old 08-01-2011, 09:15 AM
  #7112
Team Tekin
Randy_Pike's Avatar
Originally Posted by jzemaxx
I have current limiter turned pretty far down......I don't like alot of punch off the line. Also timing is turned almost as low as I can go. With a 6.5T motor I have more then enough up top. Gearing is 19T pinion with stock spur. Track is medium outdoor size, batts are Pro-Tek and Gens Ace.
Video of the track below....
http://www.youtube.com/watch?v=dvCME...eature=related
Ok that track is large for 1/10 as Reaper suggested. You're under geared. Try a 21-22. I'd like to know the entire list of esc settings most importantly is esc timing.
Randy_Pike is offline
Old 08-01-2011, 09:35 AM
  #7113
Matt Howard's Avatar
Originally Posted by morgoth
I bought 3 sets of these (for me and my friends) but they don't fit? I have the steel turnbuckles from an R.
yeah, same here. they fit the balls but the stock turnbuckles are too small. Sorry, I went off of info that was posted and "confirmed" to work.
Matt Howard is offline
Old 08-01-2011, 09:39 AM
  #7114
morgoth's Avatar
I'll put them online and hope that someone is willing to buy them. Shipping to shop would be too expensive I guess.
morgoth is offline
Old 08-02-2011, 09:02 AM
  #7115
BostonNelson's Avatar
So what do you think about the DEX 210? I have two on pre order
Maybe needs a separate thread?
BostonNelson is offline
Old 08-02-2011, 09:12 AM
  #7116
Jmuck69's Avatar
Trader Rating: 14 (100%+)
http://www.rctech.net/forum/electric...10-thread.html
Jmuck69 is offline
Old 08-02-2011, 10:52 AM
  #7117
Thanks.
Old 08-02-2011, 08:14 PM
  #7118
atl darrick's Avatar
Trader Rating: 36 (100%+)
what would be a good pinion size to start out with on a bigger track with a 13.5 motor?
also are alot of guys running a 13.5 motor and is it enough for a bigger size track?
thanks in advance for any help
oh and one more ?, is 20k good for diff oil
atl darrick is offline
Old 08-02-2011, 09:43 PM
  #7119
It really depends on how big is big and what your skill level is. A 13.5 with some boost can really be a quick ride if you have a larger track that maintains some speed between the corners. I would start somewhere 19-21t and check your temps. Most people i know run an 8.5t or so in just about every 4wd buggy out there but if you can maintain the speed and not have to really punch out of all the turns you should be fine with a 13.5 and maybe a little boost for the straightaway.
Culetto is offline
Old 08-03-2011, 02:11 AM
  #7120
morgoth's Avatar
Does someone has a PDF manual of the 2010 spec? I can only find the R manual on TD's website. I bought the alu diff inserts for my dex410r but it seems that I need different screws.
And another question: A friend bought a dex410r for his son with a 9.5T. Which would be a good pinion to start with? His son is 8 years old and it's his first "real rc" car. He has driven an RC car before but it a brushed Ansmann or something.
EDIT: I found the manual, but they use button head screws in the manual. And on all the pictures I can see cap head screws but I don't know which size I should. Probably M3x10 or M3x12 I guess.
morgoth is offline
Old 08-03-2011, 07:16 AM
  #7121
Team Tekin
Randy_Pike's Avatar
Same screws on the diff inserts, button heads.
Gearing for a 9.5 depends on what esc settings. Anywhere from 25 to 28. Esc settings will really set this motor up on gearing.
Old 08-03-2011, 08:09 AM
  #7122
morgoth's Avatar
Thank you Randy.
I managed to get the button heads in the inserts, but they don't fit really well. I had to push/twist them in.
Anyway, just drove my dex410 on a backyard track where they drive 1/8 so it's a bit too bumpy for 1/10. The dex410 drove fairly good on it, but the was jumping a lot in the bump and ruts in the turns.
If the weather is good, I'm going to a technical 1/10 clay track tomorrow and try to get it dialed
morgoth is offline
Old 08-03-2011, 08:54 AM
  #7123
morgoth's Avatar
Btw, do you guys have the same issue that the shockshaft moves less smoother when you tighten the shockcaps at the bottom? I need to screw caps a little back to get the shaft true the O-ring.
morgoth is offline
Old 08-03-2011, 09:12 AM
  #7124
Team Tekin
Randy_Pike's Avatar
No, should be smooth all the time. Make sure you have all the parts seated fully. Remove ANY burs on the plastic parts. Both the inner and outer alignment washers must seat. If you put the inner one upside down it will not seat all the way down and will cause binding.
Old 08-04-2011, 01:32 AM
  #7125
morgoth's Avatar
Yep, they are build that way. But they feel smoother when I unscrew the shockcap a half turn. Maybe it's because the shocks are still new. I'll take them appart after a few more runs.
I still have a problem with the rear skidplate that likes to eat dirt. After 1 run in moisture dirt, the skidplate is curved with about 3mm of dirt under it and then it's catching all the ruts and bumps. Does anyone have tips to keep it clean?
morgoth is offline
