Like Tree22Likes
Old 07-21-2011, 07:14 AM
  #6991
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Marc0
I already have them but not the tools to drill the pistons as i want to, to have a good setup for my favorite track.
If you have advice on BB setup for very high traction astro track, I am very interested in :-)
Why would you drill them any bigger. I already use the smallest hole pistons and they are almost to big.
Bman's 3XNT is offline
Old 07-21-2011, 07:19 AM
  #6992
In Europe on very high traction carpet or Astro, we don't need pack at all, that's why we are using most of the time, less hole, but bigger, like 2 holes 1.7mm for the rear shocks, and 2x1.8 for the front...
If you have a good setup with the 6 holes pistons for this kind of track, I would test them !
Marc0 is offline
Old 07-21-2011, 08:32 AM
  #6993
I have a 410r ordered along with some extras. What springs are popular. I will be racing on an outdoor fairly packed clay surface with small to med. sized jumps.
Thanks,
Beau
THE GOOCH is offline
Old 07-21-2011, 08:57 AM
  #6994
Team Tekin
Randy_Pike's Avatar
Originally Posted by forja
Can anyone vouch for the strength and durability of the tresrey heavy duty hinge pins vs. the stock set. Does anyone know off hand what materials they are made of?
Jason
They work great. I've yet to bend one. Nitride coated also
Randy_Pike is offline
Old 07-21-2011, 08:58 AM
  #6995
Team Tekin
Randy_Pike's Avatar
Originally Posted by Feijai
My LHS suggested that these are well designed and easy to build.. my sample isn't agreeing.
The all of the a-arm pivot balls are being difficult, they don't want to fit into the retaining aluminum bar. Even with a hammer, they're not really eager to be seated. I've swapped them all around trying for a perfect fit but none seem to want to go in.
Is this typical?
Please make sure you're not trying to seat the ball stud balls. The suspension pivot balls have NO threads and have a raised lip on one side. They should slide right in, no hammer!
Old 07-21-2011, 12:07 PM
  #6996
Originally Posted by Dadaman
I had exactly the same problem. I went back to my importer who gave me a new packet and they all fitted with no issues. I believe that some runs were made a little to big. If they don't fit in nicely, they are faulty. Don't force them in. You will have a very, very hard time trying to get them out. Hopefully you have as good after sales support as we do in Australia.
Curious, how easy should those balls go in/out of the retaining sockets?
Wondering if I should polish the retaining bar or the ball heads..
Yeah, of the 8 ball pivots, 7 of them don't fit into the forward suspension stay holder thing. I'm going back to the LHS today.
Thanks again,
Feijai is offline
Old 07-21-2011, 02:18 PM
  #6997
Dadaman's Avatar
Trader Rating: 20 (100%+)
You should be able to easily push them in with your finger.
Has anyone else had the problem where the pin to hold the front wheel hex won't go into the hole in the axle because the hex won't sit down enough. I only have half a hole showing and the hex is fully pushed down snug up against the bearing.
Dadaman is offline
Old 07-21-2011, 03:54 PM
  #6998
Shadows's Avatar
Trader Rating: 23 (100%+)
have you checked that your axle bearings are seated fully?.. sometimes its hard to tell by eye, but that .5mm makes all the difference..
Shadows is offline
Old 07-21-2011, 04:10 PM
  #6999
jmackani's Avatar
Trader Rating: 14 (100%+)
Thanks again,
That's a problem with the coating on the aluminum holders. I know over on the descr thread guys are using a dremel to remove some of the coating on the hinge pin retainer and they then go in fine.
jmackani is offline
Old 07-21-2011, 05:00 PM
  #7000
Dadaman's Avatar
Yes. Boths side are seated in well. Both bearings are sitting flush with the hub.
I also have found that the rear pin is very loose when inserted into the axle hole. Gone from one extreme to the other.
Dadaman is offline
Old 07-22-2011, 01:47 AM
  #7001
BostonNelson's Avatar
Had the same problem on the 2009 spec. Had to sand them down. Not fun, but you do it once.
BostonNelson is offline
Old 07-22-2011, 02:35 AM
  #7002
Dadaman's Avatar
The part I am having problem with is 310032. Do you really need it in there anyway? I have fitted the pin no worries without it.
Dadaman is offline
Old 07-22-2011, 06:08 AM
  #7003
You'll damage the bearings when tightening the wheels without it.
Old 07-22-2011, 08:59 AM
  #7004
Team Tekin
Randy_Pike's Avatar
You can get away without it but understand that you must pay attention to not over load the bearings side load.
Old 07-22-2011, 09:20 AM
  #7005
tomdav's Avatar
Trader Rating: 44 (100%+)
Maybe you have the axles swapped from the front to the rear. They are different part #'s.
tomdav is offline
