Like Tree22Likes
Old 07-06-2011, 11:40 PM
  #6841
Has anyone tried running bladders in their shocks?
Chris-s is offline
Old 07-07-2011, 01:00 AM
  #6842
R/C Tech Elite Member
DavidR's Avatar
Trader Rating: 97 (100%+)
Originally Posted by ABBOTT
Nice job Dave, too bad you ditched it a while ago, lots of setups will work in thes cars if people would just put some thought into it. Kids these days dont really have the DOY skills that where once needed in this hobby. Race rollers suck,period and are a disgrace to the hobby. Any decent car should come in a kit! These days if you pull out a dremel to try something new you get somebody talking smack! Ask any losi guy! People use to respect it when people tried something new.
Yeah... I have my moments every now and then in the creativity department. As for the dremel... LOL... Take a look at my B4 sometime! That things got more custom work on the chassis than even the most hacked up Losi I've seen... But it freakin' worked! I let Moose and some of the others guys drive it and they said it was the best B4 they'd ever driven.
As for the Durango car... I actually think I'm going to give it another shot this winter.
I was faster down here at the Barn with the Durango than I was with the B44... But I couldn't find a setup that worked for the Durango in 3 weeks I was at Smac. I guess I probably gave up on it too quick. I know it really screwed me for the JConcepts race going back and forth from the B44 to the Durango and then back to a borrowed B44.
As a matter of fact I still have a 2009 Spec car that Mikes got in his posession right now thats just rotting away...
From what I hear the 2011 Spec car is on the way... So I'm gonna hold out for it, and then probably give it another shot.
Seeing as Randy, our team manager for Tekin has been picked up by Durango... I'm hoping I can pick his brain a bit about setup this time around.
DavidR is offline
Old 07-07-2011, 08:52 AM
  #6843
Team Tekin
Randy_Pike's Avatar
Originally Posted by DavidR
Obviously I'm not Randy...
But here's how I put a fan on one of my Durangos....
Essentially take this photo and rotate the esc 90' clockwise, mount the fan low on the chassis right next to the posts....the receiver is tucked in between the motor and esc directly under the center drive shaft.
We're using the plastic side pods so I actually use a 2nd layer of tape to lift the esc/fan and mount it out further on the chassis...
Randy_Pike is offline
Old 07-07-2011, 12:27 PM
  #6844
Anyone?
I run the front block holes up (i think it shows +2 on the up side) and the rear +2 block on both my dex and desc. As far as what to expect i couldnt tell you if thats your only change. I like the roll center higher because it feels more planted on power coming out of the turns. The only downside ive seen is a tendency to pick up the inside rear wheel if you brake too late going into a turn, especially a berm turn, though it doesnt ever traction roll like you might expect.
I dont know if my setup would work well for anyone else, i leave the rear pretty loose with the grip focused on the exit to the turn and drive through the turns as opposed to a lot of people with 4wd buggy and SCT that i see power braking into the turns and burping it around the corner. I find it better to drive it like a touring car and nail every turn at the apex. Both ways seem to produce the same lap times among our top 4wd SCT class drivers but in the buggy is where this really shines, especially with the rango being so well balanced. My only personal exception to this is if there is a sharp flat hairpin turn in which case ill drift it and already be sideways long before entering the turn. VIDEO link here, this is an older vid of my first desc410r but kinda shows the difference between the corner types as loose vs throwing it sideways on the end of the straight. Buggy drives pretty much the same.
Culetto is offline
Old 07-07-2011, 02:07 PM
  #6845
Wow, very slick layout there. Giving me some ideas, thanks!
kommando98 is offline
Old 07-07-2011, 10:15 PM
  #6846
Hey guys...I just bought the Racers Edge 5200 mAh saddle pack for my DEX and it doesn't seem to fit. I bought the car used and thought it was a 2010 spec and therefore would fit lipos up to 25mm tall (the Racers Edge pack measures out at ~24.5mm) but it appears that it is the older spec car .
Can somebody let me know what I need to change out to allow for the taller Lipos as per the 2010 spec car? Is it just motor mount and slipper mount?
Cheers,
Mike
Hyper_Mike is offline
Old 07-07-2011, 10:43 PM
  #6847
SMcD's Avatar
Trader Rating: 61 (100%+)
ingenious.
Thank you
SMcD is offline
Old 07-07-2011, 11:05 PM
  #6848
forja's Avatar
Cheers,
Mike
- Durango DEX410/DEX410R - How to install 25mm in DEX410 -
The DEX410 was originally designed around lipo packs that were 23.5mm tall. This was the maximum height for a legal lipo battery at the time.
Since then there has been a change in the regulations, increasing this maximum height dimension to allow lipos of up to 25mm to be used for racing.
When developing the DEX410R model this change in battery regulations was taken into account and existing parts were revised to allow the fitment of 25mm high lipo packs.
Here we show you what parts are required to fit 25mm high lipos in the original DEX410.
Parts Required:
TD310155 MID DRIVE GEAR PLATE (ALUMINIUM) (25MM)
TD310156 MOTOR MOUNT PLATE (25mm)
TD310039 GEAR BOX SET: FRONT & REAR
TD320005 BATTERY HOLDER SET (LIPO)
The centreline transmission on the DEX410 runs quite close to the battery pack. To use a taller battery the centreline transmission needs to be raised slightly.
Raising the slipper clutch assembly:
To do this there is a new motor mount and mid drive gear plate that raises the slipper assembly, these are part numbers TD310155 and TD310156.
New motor plate (TD310156) on the left mounts the slipper assembly in a higher position
then the original motor plate (TD310009) on the right.
New mid gear plate (TD310155) on the left mounts the slipper assembly in a higher position
then the original mid gear plate (TD310008) on the right.
Increasing the angle of the rear gearbox:
Raising the slipper assembly will give clearance for the battery pack in the middle of the car. It is also necessary to raise the angle of the gearbox to give clearance for the battery back along the length of the driveshaft. To do this we have updated the gearbox holder on TD310039 gear box set. This now holds the rear gear box at a slightly higher angle, giving the driveshaft more clearance over the battery pack.
New gearbox holder on the left holds the rear gearbox at a greater angle than the old gearbox holder.
With these parts fitted there is now clearance under the centre driveshaft for 25mm lipo battery packs.
Fitting the lipo battery holder:
There are two heights at which the lipo battery holder can be mounted. The lower one is for 23.5mm high lipo battery packs and the higher for 25mm high lipo battery packs.
At the hinge end the gearbox holder now has two holes. Use the upper hole for 25mm lipo battery packs.
New gearbox holder has two positions for mounting the battery strap.
We have modified the lipo battery holder, part TD320005, so that the parts tree now includes spacers to raise the front mount for the strap in the middle of the car. When using 25mm lipo batteries these spacers go in-between the front mount for the battery strap and the chassis, slightly longer screws will be required due to the thickness of the spacers.
The two spacers included in TD320005 are for spacing up the front battery mount when using 25mm lipo batteries.
With the spacers under the front battery mount and the battery strap fitted in the upper of the two positions for the hinge end you know have a secure fitting for your 25mm high lipo battery.
Source: Team Durango
forja is offline
Old 07-08-2011, 07:49 AM
  #6849
Forja, thank you very much for that...it's most useful!
Cheers,
Mike
Old 07-08-2011, 10:01 AM
  #6850
majorsmx521's Avatar
Trader Rating: 44 (100%+)
Default wanted-alum side pods
loooking to try the spec side pods?
if anybody has a set they want to part with please pm me
thanks
Rob
majorsmx521 is offline
Old 07-08-2011, 10:17 AM
  #6851
forja's Avatar
You're welcome Mike...
forja is offline
Old 07-09-2011, 06:14 AM
  #6852
Trader Rating: 125 (100%+)
Thought about picking up a 410R to play with. Is there anything I need to know or pick up? Hop up wise for durability? What are weak points and spares I would need to keep? Can you fit AE or Losi wheels on this buggy or is it Durango specific?
kwiksi is offline
Old 07-09-2011, 06:56 AM
  #6853
Looking for a place with all the info on this car.trouble spots mods etc
auto2 is offline
Old 07-09-2011, 07:41 AM
  #6854
avva's Avatar
what is a good motor/pinion setup for the dex410r? will the castle sidewinder sct/3800kv motor combo work for this with a 16t pinion.
avva is offline
Old 07-09-2011, 08:31 AM
  #6855
Is anyone mod the 410 to accept stick type Lipo instead of saddle pack?
mos-leung is offline
