Like Tree22Likes
Old 06-30-2011, 09:01 PM
  #6796
Trader Rating: 46 (100%+)
Guys whats a good base set up to put on this car. Thanks for the help
transplantlife is offline
Old 07-01-2011, 10:57 AM
  #6797
Having a desc410r and a dex410r i think TD does a great job with their factory setups. On the buggy all i made was some minor oil and roll center changes. That being said their website has a ton of setups for various tracks around the world from their team drivers so you can find a track that has a similar surface to yours and try that setup as a base also.
Culetto is offline
Old 07-01-2011, 12:13 PM
  #6798
Trader Rating: 31 (100%+)
Default sun gear removal
Originally Posted by cbrociuos
dont break the gear. put the outdrive in a truggy rim, gear side up. to keep outdrive up off the table. take a 3mm hex driver, place on outdrive hex in the center of the gear and hammer it out. all you will need to replace is the e-clip. this is a trick some of us on the thread have been using since page 20 or so. it works every time. if you dont have a truggy rim 2 buggy (1/8) rims work. just use anything to get the outdrive up off the table, but the ring gear needs good support so as not to break it. you will have to hit it pretty hard. hope this helps.
Another way that I have used with success on those that werent properly sanded is to use a spring loaded punch(snap on etc makes them). Hold diff cup with outdrivr facing up. Then use spring loaded punch on center of outdrive on sun gear side and let it pop several times and you will see gear move its way off outdrive. No damage to anything this way and your done in 2 minutes.
here is a link to one
http://www.amazon.com/Pittsburgh-Spr.../dp/B0041VHOMQ
cota4rt is offline
Old 07-01-2011, 12:54 PM
  #6799
Konich's Avatar
Look for the "Grapejuice" setup. Its been a real popular setup and the same setup Justin ran at the Cactus this year.
Konich is offline
Old 07-01-2011, 12:57 PM
  #6800
Konich's Avatar
Originally Posted by burrppp52
any kind DEX410 2010 spec driver care to share wat saddle u guys using .. i hv yet to buy one ... pls help ..
Orion carbon have been working well on our Tresrey Durango's. I did run the Venom packs for a while and they worked well also. Almost anything 25mm in height will take care of you.
Konich is offline
Old 07-01-2011, 08:05 PM
  #6801
G_WORD's Avatar
Trader Rating: 124 (100%+)
guys i'm selling my rango if anybody is looking for one lmk
http://www.rctech.net/forum/r-c-item...separtely.html
G_WORD is offline
Old 07-01-2011, 08:47 PM
  #6802
Can someone post grapjuice's set up..... Thanks guys
Old 07-02-2011, 10:54 PM
  #6803
jdogger1's Avatar
Cool RYAN LUTZ RUNS HIS FIRST RACE!
WE HAVE VIDEO OF RYAN LUTZ RUNNING HIS FIRST RACE WITH THE DURANGO 4WD BUGGY.
www.rcinsider.com
jdogger1 is offline
Old 07-03-2011, 01:00 PM
  #6804
www.rcinsider.com
really? i only saw a link to him running a short course truck.
Gump is offline
Old 07-03-2011, 01:25 PM
  #6805
lots and lots of talk about breakages, overheating and drivetrain noise on here.
i've had my 2010 spec 410 since lat year and have yet to experience they typical noises and breakages everyone is talking about. Hell I haven't even broken the 1st servo saver yet, and I've raced both dirt and carpet quite a bit.
The only problem I had with my original kit was actually kind of weird - all the small plastic ball ends (sway bar) split when the screws were drivin into them.
I think a lot of the overheating problem comes down to people overmotoring (or overgearing) their cars. Since I found mine running a little hot at first, and I didn't want to buy another motor (mamba 5700), I simply ground out my engine mount so the motor could move a little closer to the spur, letting me put on a 15 tooth pinion. I'm hoping they release a couple of larger spurs soon.
As for drivetrain noise, take a good hard look at your spur and pinions. I have replaced 2 spurs for noise, but you also have to look at your pinions. they too can get mangled a little bit and contribute to the noise. I also use a drop of oil on the cv joints when running on carpet (not on dirt), and those diffs have to be properly shimmed and then greased to help with the noise reduction. I still have all the kit bearings in place too.
Gump is offline
Old 07-03-2011, 01:41 PM
  #6806
ABBOTT's Avatar
Looks like he finished 4th behind Brent Thielke. The video of the buggy is down the page.
ABBOTT is offline
Old 07-03-2011, 08:43 PM
  #6807
18SS's Avatar
ok so I saw these pictures of this Durango with this body on it.
Can some one PLEASE PM me with what body this is.
what company makes it?
im looking to get one but cant find them anywhere
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-tresrey-001.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-tresrey-005.jpg
18SS is offline
Old 07-03-2011, 08:47 PM
  #6808
http://www.tresrey-usa.com/
Old 07-04-2011, 12:31 AM
  #6809
DRCRacer299's Avatar
My set-up from the J-Concepts Indoor Nationals is now posted on my website. This was a super high bite indoor clay track and very tight.
Had some bad luck throughout the weekend. Too much to explain it all but in the end my car felt very solid in the main. Was battling for the win with 30 seconds to go and then my bad luck returned. Either way this was my first race with the DEX410 and i'm glad to share my set-up.
-Lutzinator
DRCRacer299 is offline
Old 07-04-2011, 05:42 PM
  #6810
fullsyzz's Avatar
Trader Rating: 119 (100%+)
Great run yesterday Ryan, you would have had those guys if you didn't lose power. Lame. Good meeting you and your brother.
fullsyzz is offline
