Like Tree22Likes
Old 06-14-2011, 11:00 PM
  #6751
G_WORD's Avatar
Trader Rating: 124 (100%+)
Originally Posted by tobamiester
I used a little bit of good old brute force to get them on, i.e put the tips of need nose pliers over the end of the shaft, on top of the washer, and beat on it with a the end of plastic screwdriver. Its a tight fit for sure...
i was about to call you at 11pm because i was pissed off but i held off.
thanks see you tomorrow.
G_WORD is offline
Old 06-14-2011, 11:34 PM
  #6752
Trader Rating: 46 (98%+)
is there a trick to getting the 14 tooth diff gear out of the diff like its stuck on the outdrive
perez62682 is offline
Old 06-15-2011, 01:52 AM
  #6753
Originally Posted by cbrociuos
my diffs are shimmed correctly. i have never lost a ring gear in the buggy or the sc. this car is a little louder than a b44, partly due to the spur gear and partly due to the all metal gear diffs.
Well for all that have a loud car and correctly shimmed diffs: I took one extra gold washer (the thinnest one) to get the diff further away from the bevel gear and to my surprise the car was then all of a sudden almost B44 quiet. Try it! You might be surprised I also use a tiny bit of Eureka grease instead of the black one. Great stuff!
@Perez: To get out the diff gear just put it upside down for 15 min, gravity will work for you. Give it a little smack and it will fall out nice and easy
Cheers
Kebabkongen is offline
Old 06-15-2011, 04:48 PM
  #6754
Hey all...I just picked up a lightly used DEX410 that came as a BUNCH of NIP parts including a set of Big Bore shocks in addition to the original ones. I'm (slowly) working my way through this thread so I apologize if this particular horse is already beat but is there some "equivalancy" between the original shocks and the big-bores? For example, if I see a setup that used the original shocks, how can I get the big-bores to be equivalent to that setup?
I'm kinda hoping there is a chart or something but even some guidelines on piston/fluid weight/spring changes would be helpful. Thanks in advance for any assistance you could provide!
Cheers,
Mike
Hyper_Mike is offline
Old 06-15-2011, 06:57 PM
  #6755
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Cheers,
Mike
Congrats on the find! I run the same rate springs as the O.E. shocks(dark green/F Lt. green/R) but heavier oil. Right now I use the smallest pistons 6x1.2 F/R and losi oil,35F/25R. The rear is border line light. Good luck with the rango........
Bman's 3XNT is offline
Old 06-15-2011, 10:58 PM
  #6756
Thanks for the quick response Bman!
Yea, it was a smoking deal that included everything NIP to build a 2010 spec car + a bunch of spares + battery + full ceramic bearing kit + NIP Tersery FR/RR hubs/servo saver/driveshafts/weights/Gainabull body . I suspect I'll be asking more (stupid) questions as I get further into the build but I'm assuming key points are as follows:
Proper shimming of diffs
Kyosho P5 o-rings on outdrives
Proper installation of pinion gears into diff cases
Build driveshafts with red locktite and either pin retainers or shrink tubing
Alloy steering arms/servo saver
I'm REALLY stoked to get this thing built and out on the track!
Cheers,
Mike
Old 06-16-2011, 12:15 PM
  #6757
G_WORD's Avatar
what diff oil are most of you using stock 20k ?
G_WORD is offline
Old 06-16-2011, 12:19 PM
  #6758
Trader Rating: 148 (100%+)
Yoooo, last night I ran 20k associated in the front and 10k in the rear.
skyline1015 is offline
Old 06-16-2011, 01:55 PM
  #6759
ABBOTT's Avatar
I run 7k/3K but its all up to you style really!
ABBOTT is offline
Old 06-16-2011, 10:29 PM
  #6760
hi guys this is BRIAN. i'm about to start my build on my rango 410 2010 spec 4x4 buggy . .. for the diff's should i run it with the stuff it came with ,,,,100,000 in front and 5,000 in rear ,,,also what shock oil should i start out with .the kit don't come with a pinion so if im running 10.5 motor with the stock spur gear what pinion or pinions should i get ,,,,
thanks guys ,,brian j
BRIAN77 is offline
Old 06-16-2011, 11:37 PM
  #6761
Depends on the traction level of your track. For higher bite tracks you go higher and looser go lighter. I settled on 7/3 for a medium loose track.
JosephS is offline
Old 06-17-2011, 12:09 AM
  #6762
Cheers
hahaha no man, i meant like the gear attached on the outdrive its like really stuck on there and ive tried everything with no succes
Old 06-17-2011, 12:17 AM
  #6763
hacker's Avatar
Trader Rating: 141 (100%+)
thin screwdriver on both ends and pry it up
hacker is offline
Old 06-17-2011, 12:36 AM
  #6764
I also meant the gear attached to the outdrive, have you tried what I said? Put some oil in it, spin for a few times, then turn it upside down and wait....
Old 06-17-2011, 06:23 AM
  #6765
ABBOTT's Avatar
Perez if you built the car and you had to beat the thing on with a hammer then your not likely to get it off without detroying it. If the outdrive is in good shape and worth saving break the gear off. It sounds to me like who ever built the car did not sand the outdrive hex correctly and forced it on. If that is the case it will not be coming off in reusable shape. Goodluck
ABBOTT is offline
