Like Tree22Likes
Old 02-26-2011, 07:26 AM
  #6316
Trader Rating: 49 (100%+)
Originally Posted by R-E-A-P-E-R-
I must be the only guy on the planet who never had an issue with the kit bearings. Mine lasted forever it seemed. As the slowly went out I replaced them with a cheep set of Yeah Racing ones from ebay. Which have alos been outstanding.
I still to this day have a few kit bearings on my car. And they still spin perfectly.
Same here, the bearings arrived from china and they're holding up well.
aradaiel is offline
Old 02-26-2011, 09:57 AM
  #6317
Default DEX410r prob.
http://www.rctech.net/forum/electric...ngo-410-a.html
please refer to this sight and see my problem. My cell is 208 521 8651 as well to if you need anything
mattythegreat is offline
Old 02-27-2011, 09:48 AM
  #6318
I'm looking at my setup, versus everyone elses...
I haven't drilled my pistons to 1.3mm like everyone else, but I'm using lighter shock oils.
Will I gain anything going to a larger holed piston and thicker oils, or should I keep doing what I'm doing?
aradaiel is offline
Old 02-27-2011, 02:03 PM
  #6319
grapejuice's Avatar
Trader Rating: 154 (100%+)
Larger hole pistons will give the shocks less pack, will soak up small bumps easier. Smaller hole piston give you more pack, better for tracks with big jumps.
grapejuice is offline
Old 02-27-2011, 03:21 PM
  #6320
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
I tried the larger hole setup front and rear. But since returned to stock at my track. I run 25 front and 27.5 rear losi oil.
Bman's 3XNT is offline
Old 02-27-2011, 04:16 PM
  #6321
Interesting, I'd like to try it just to compare.
I'm running losi 30F, 25R. If I bore them out to 1.3 what oil should I be at, ballpark?
Up about 5 each?
aradaiel is offline
Old 02-27-2011, 07:31 PM
  #6322
grapejuice's Avatar
Up about 5 each?
Yeah, generally about 5 wt. per hole size. With my set up, drilled to 55's (about the same as 1.3mm) I ran losi 35F and 30R.
You run at IR/CR, I'm assuming? What tires are you guys running? I will be there for April's, been the past two years and just ran pinks but the compound lately has changed a bit with the new Cali laws. Looking at running PL MC's.
Old 02-28-2011, 03:27 AM
  #6323
TeamDurango's Avatar
I've PM'd you asking for your details, of course we'll sort this out for you asap.
TeamDurango is offline
Old 02-28-2011, 07:42 AM
  #6324
Trader Rating: 17 (100%+)
Default New to the DEX410
Does anyone out there have a good setup for a Durango DEX410? I just got one on a great deal. Now I want to go through it and set it up to run but have never messed with a 4wd buggy and could use all the pointers I can get. It has a Tekin RS pro ESC with a 7.5T brushless. I'm running a Airtronics M8 with the Spektrum module. I also have a Savox steering servo in it. I am putting Proline Suburbs (Soft) on it for the indoor track I run at.
This is what I'd like to know.
Shock Oil
Spring rate
Ride height
why does it nose down in the air after I hit the jump
Will Stabilizers help? If so, which stabilizer's to use
Any help would be greatly appreciated.
There's not that many of these cars at the local track otherwise I would seek help from them also.
Bob
bobsavenger is offline
Old 02-28-2011, 07:53 AM
  #6325
I ran the DEX410 for the first time this weekend and all I can say is "WOW!!".
The car performed better than I had hoped. After reading in this forum about the possiblity that the car is fragile and also because it was a shake down run, I took it very easy the first race. The car finished the race with no problems. After each race I made a minor setup change and when I went out again I drove a little more aggresively. By the end of the night I was averaging almost a full second per lap faster than I was with my HB D4. Everyone at the track was very interested to see how the car would run (it was the first Durango at our track) and I think after seeing it run a few people are considering getting one.
I had zero failures the whole night and everyone commented on how quiet the car is even thought it is shaft drive with gear diffs. I'm going to pull the diffs out and check to see how well I got them sealed up... other than that I don't seem to need to do anything to it at all maintenance wise.
Two things stand out in my mind as initial impressions about the car...
1. The car responded well to the minor changes I made in the setup during the night. I could make changes to the D4 and usually I couldn't tell for sure if the car responded or not.
2. The car jumped extremely well. I'm sure that's where I lowered my lap times. It was also very easy to control it's attitude while in the air with the throttle.
Excellent car!! Money well spent!!
qwkpony is offline
Old 02-28-2011, 08:17 AM
  #6326
Maxxingout's Avatar
Shock Oil
Spring rate
Ride height
Bob
What type of indoor track? Clay, loose dirt, high bite..? Can't really give you a starting point without knowing what you run on.
Nose down, what springs are on it now? Are the collars in the rear turn way down? Are you letting off to early? I had no issues with the car nosing off jumps even after I would switch between the brass skid and plastic skid.
Spring rates:
http://www.petitrc.com/setup/durango...Comparison.pdf
Setups: Look at a few that match your track and get a base going, then if need be make adjustments.
http://www.petitrc.com/setup/durango...ngoDEX410.html
Maxxingout is offline
Old 02-28-2011, 08:52 AM
  #6327
Spring rates:
Well, the track is hard packed clay. Tire to run at the track is Jconcepts Barcodes in Green and they have to have the tread clipped.
Springs are Blue. I don't believe they are light blue. Spring collars are set High, not at the top but about 3/8" down. It is possible that I am letting off the gas too early.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-2011-02-23-05.57.40.jpg
Old 02-28-2011, 08:56 AM
  #6328
Jackie_W's Avatar
Trader Rating: 16 (100%+)
Wanting to replace the ballstuds on my dex410 and remember some were using the hot bodies.anybody have the part #'s for them?I tried searching but the search didn't bring up anything.I don't have time to search every page in this thread to find the part #'s.My car has the tresrey aluminum hubs if that makes a difference.TIA
Jackie_W is offline
Old 02-28-2011, 09:11 AM
  #6329
Is anyone else having problems with blowing out bearings in the rear hubs? I run on med/high traction track with alot of on power left handers. I seem to always blow the right rear bearings out. I also have the newer black spacer in there as well. The Tresery rear hubs come with larger bearings correct? Lmk what you guys think. Thanks
Old 02-28-2011, 09:17 AM
  #6330
Jackie_W's Avatar
Yes they come with 5x13 instead of the stock 5x10.Should last a lot longer than the originals.
Jackie_W is offline
