Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#6286
U still a durango guy right dont sell out bro i belive great things r coming i see u r using JC rims no MODS did u just bolt the on thanks
#6288
#6289
I finally took the plunge and ordered myself the 410r, at our track they rule and apart the servo saver seem to be nearly unbreakable. I used to be among the fastest buggies with my tt, but now there are 3 durangos and they turn circles around me. Noone is having any issues with pins or whatever, all probably the newer kits correctly assembled, the only thing is the constant need of ball bearings and front tire wear, though bar codes seem to hold up forever. The fastest guy used to break his k-car fs2 every other run on the rather difficult big jump (brittle front end), now he always finishes his battery back every single time.
As i saw in the last posts there is no common opinion on the rear weights, i'll have to see, doent it nose dive a little without? Furthermore will there be a problem to fit in the standard spektrum receiver next to a lrp tc spec2?
I'm looking forward to the assembly of this little beauty, just need to stock up on ball bearings (any cheap durable ones?)!
#6290
I must be the only guy on the planet who never had an issue with the kit bearings. Mine lasted forever it seemed. As the slowly went out I replaced them with a cheep set of Yeah Racing ones from ebay. Which have alos been outstanding.
I still to this day have a few kit bearings on my car. And they still spin perfectly.
#6291
hey man could u please look at this track video its our home track and was wondering if u could give me a starting setup thanks www.rcgears.net
#6293
yep
#6294
That track is about as opposite as possibly could be from where I have been running mine. I will be playing outside with mine as soon as it warms up but I dont think I could offer much as far as setup goes. At least not on a track like that.
I would always start with the kit setup as a base.
#6295
You can get the 3100 reciever in next to the lrp but you might have to lay the reciever on its side depending on how you do your layout. This is a pretty good thread to look through for ideas.
http://www.oople.com/forums/showthread.php?t=31939
#6298
Lots of set-up sheets to look at, I would look at the "dirt" section and go off weather your track is low, medium or high bit.
#6299
Hey fellow 410 owners can you take a look at the two pics I attached. One is the rear where the diff sits nicely in the round driveshaft retainer thing? In the front, the diff is not seated in the round piece where the driveshaft passes through. Is it supposed to be seated in it? The front diff seems like it is seated fine, but looks of more of an angle upwards. Thanks in advance. Sorry about the pictures not being rotated. They were fine when I took them.
#6300
Yes the front diff casing should sit in the loop - you might need to push on the hoop with a finger or screwdriver at the same time as you push the front diff into place to make sure it sits over correctly.
