Like Tree22Likes
Old 02-14-2011, 11:18 PM
  #6091
Dlewis4's Avatar
Trader Rating: 148 (100%+)
You guys are more fun to talk to than the people in the Kyo threads. I miss you guys
Danger, still running the fire hazard also known as Novak?
Dlewis4 is offline
Old 02-15-2011, 12:05 AM
  #6092
SuperEk4's Avatar
Trader Rating: 32 (100%+)
Is this Lipo ok?
http://www3.towerhobbies.com/cgi-bin...?&I=LXYKT4&P=6
SuperEk4 is offline
Old 02-15-2011, 01:58 AM
  #6093
hlb14's Avatar
Trader Rating: 28 (100%+)
yes, its 23mm high, should work
hlb14 is offline
Old 02-15-2011, 02:42 AM
  #6094
littlejohn's Avatar
For those that are interested in an alternate body that gives more room for electrics and cooling, and doesn't cost the earth...
http://www.oople.com/forums/showthread.php?t=63023
cheers
LJ
littlejohn is offline
Old 02-15-2011, 05:12 AM
  #6095
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
cheers
LJ
Truly a bargain shell, he could charge twice the price (like others do anyway) and it would honestly still be worth every cent.
Alot of room for electronics - also the wing is simply awesome - I use them pretty much exclusively now.
Thomas is a great guy - happy to be running his bodies, undertrays and bumpers.
Heres a pic or two of mine - with a quick "rattle can" paint job.
Cheers
Darryn Johnson
RETRO R/C is offline
Old 02-15-2011, 06:29 AM
  #6096
R-E-A-P-E-R-'s Avatar
Originally Posted by tonyv2382
moving on...Reap...what shock oils what diff fluids what ride height...thanks. Also are u running weights?
My shocks have 37.5 Front Blue Springs 32.5 rear Black springs AE shock oils
The diffs are grease filled (been running it like this all winter)
Ride hight Front & Rear 21mm
I have the Tresrey Rear diff weight installed
R-E-A-P-E-R- is offline
Old 02-15-2011, 06:52 AM
  #6097
Suspended
Originally Posted by R-E-A-P-E-R-
Really??? If you cant finish a race in this car you should buy a short bus and bash on
Settle down it's just a joke. I don't even own one. Just watch them break regularly. My cars always finish races. Oh and I have a short bus rc car that I could wheel you around the track in
plack75 is offline
Old 02-15-2011, 06:57 AM
  #6098
Suspended
+1,295,317...
What is that the number of days you havent put that car on the track? I think you been on the track 3 times all season. Come Friday and I'll bet you $100 you don't make it thru the night without a mechanical repair. Not a crash repair
plack75 is offline
Old 02-15-2011, 07:15 AM
  #6099
Reading all this is making me worried about this car seems to have a high breakage rate. Or people driving the suck don't know but not good.
hitman72 is offline
Old 02-15-2011, 07:20 AM
  #6100
If your watching these break all the time then they are not put together correctly. And don't come on here saying your going to beat anyone with a shortbus. Cuz that isn't going to happen and we do not want to hear it.
Go troll around in a different tread...
Old 02-15-2011, 07:28 AM
  #6101
There is nothing wrong with the Durango man. Its 10 times stronger than than any other wheeler I can assure you of that. The car is a very precise and needs to be built as such. If you get this kit and toss it together without taking the time to do it correctly, you'll have issues.
Get the car, ask question during the build if you have any and you'll see why this car is so good. Don't listen to some tool who doesn't even own one.
Old 02-15-2011, 07:34 AM
  #6102
Konich's Avatar
I have a 2009 spec car, I've never really had a problem with anything except the servo saver and servo horn. Both of those have been replaced and right now I'm building cars out of all the spares I bought.
Hell Reaper only has 1 spare part in his whole box, Its a can of Durango kick a$$
Konich is offline
Old 02-15-2011, 07:41 AM
  #6103
grapejuice's Avatar
Trader Rating: 153 (100%+)
Not since speedo number 3 or 4 went up Talk about bad luck...
grapejuice is offline
Old 02-15-2011, 08:01 AM
  #6104
dangerwr's Avatar
No, unfortunately I have put down the 10th scale until next winter. I had 3 Novak Kinetics go up in smoke and was not interested in starting over with something new.
I really, really, really like the Kinetic but is definitely not the speedo for this car. I believe the problems are associated with adjustments via the NovaLink. It is a little too strong out of the box but once I put the computer to it there is a fiery revolt.
Damn you Novak Kinetic for ruining my 2010 Winter racing season. I will be back in full force this Summer in electric 8th scale. Should be fun with others jumping on this band wagon including GrapeJuice here. Watch out because Danger does not play in eiffff scale son!!!
dangerwr is offline
Old 02-15-2011, 09:06 AM
  #6105
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Hey is Rob running 1/8E this year @ the regionals? If so you know what day and you going to run again? Thanks...
Bman's 3XNT is offline
