Like Tree22Likes
Old 02-06-2011, 02:54 PM
  #5866
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
paint job by paul robert racing designs
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-2011-02-06_13-22-27_826.jpg
turboxrayt1fk05 is offline
Old 02-06-2011, 03:36 PM
  #5867
jessbens's Avatar
i got mine on track lastnite and all i got to say is wow. this buggy is so smooth.every one at the track was all over it like lil kids.now if i can get Konich to get me hooked up with some parts ill be in there that and some pink beams
jessbens is offline
Old 02-06-2011, 03:41 PM
  #5868
i dont know if you ran it on dirt or carpet but if get to race on carpet then you will really fall in love with this buggy..... ITS FREAKING FAST
Old 02-06-2011, 08:10 PM
  #5869
Hi there,
Just picked up a 410R today. Which optional parts will make the most difference for the least bucks? Are the aluminum side rails at $100 a pair really going to make that much of a difference on the car? If so, might as well just get the 410.
burgerchow is offline
Old 02-06-2011, 08:31 PM
  #5870
Originally Posted by burgerchow
Hi there,
Also, what's the biggest size saddle packs that can fit into this buggy? Will a 5200 Reedy fit?
Old 02-06-2011, 09:44 PM
  #5871
grapejuice's Avatar
Trader Rating: 153 (100%+)
Hi there,
No, don't waste your money on those...car is better with the plastic ones, more flex. Minimum for the 410R is the aluminum front hinge pin brace and pivot balls to use that brace. The rear rear aluminum brace is a good one too and an aluminum servo saver.
Max battery height is 25mm, I have no idea how big the reedy is
grapejuice is offline
Old 02-06-2011, 10:11 PM
  #5872
thanks for the info. I can use the extra 3 bills towards the new durango sc 4x4.
What size saddle packs are you using? I know the Reedy 4200 s fit but was thinking about a 5200.
Old 02-07-2011, 06:24 AM
  #5873
tonyv2382's Avatar
Trader Rating: 67 (100%+)
I think u should save ur 3 bills and invest in a good motor/esc combo and maybe get ALL the ally hinge braces. Maybe the CF shock towers and some P5 o-rings for the diffs which is a MUST. As well as some spare ring gears in case you got stuck with the old batch that chipped. Another smart investment would be some spare steering uprights and caster blocks and a set of 1* rear hubs or a set of rear hubs in general in case you break them. Extra rear axle wheel pins ...personally Im using milwawkee 1/16th black oxide drill bits since the stock wheel pins are garbage and break very easily if you slightly over tighten a wheel.
Buy a ton of diff oil to experiment with different combos, unless u already have. A spare servo saver set or you can get the tresrey or the other version people are buying on here forgot the brand. People seem to be breaking that piece, I personally havent but after all the incidents I got a spare stock set. Get all the spring combos for tuning and if u still have something left over, the aluminum mid drive gear is also a good buy. Its an aluminum mount that replaces the plastic mount that holds up ur spur assembly. You should also invest in some good bearings. Mine got pretty bad after they got a bit dirty. Get a set of yellow seal bocas or something of higher quality to last you for a long time. Because although some will disagree, I believe the stock bearing to be crap.
make sure to use red loctite on your center drive shaft pins and then use shrink wrap to hold them there. Otherwise you may be in for an explosive treat involving your battery pack
So If I were you Id save that money and make this car as good as possible before you move on tot he SC truck.
tonyv2382 is offline
Old 02-07-2011, 06:33 AM
  #5874
Maxxingout's Avatar
Trader Rating: 17 (100%+)
You running the stock configuration?
Maxxingout is offline
Old 02-07-2011, 07:11 AM
  #5875
grapejuice's Avatar
I'm running the Team Orion 4500, check the height of the reedy 5200, I think they might be too big.
Old 02-07-2011, 07:12 AM
  #5876
Briguy's Avatar
Trader Rating: 125 (100%+)
The Reedy packs are to tall .
Briguy is offline
Old 02-07-2011, 08:31 AM
  #5877
jessbens's Avatar
yep didn't get time to mess with my setup. i just added 24g to the rear and it was hooked and i run on clay high bite. it's not carpet but there is alot of bite
jessbens is offline
Old 02-07-2011, 09:00 AM
  #5878
Maxxingout's Avatar
What tires and foams you running?
Old 02-07-2011, 10:00 AM
  #5879
jessbens's Avatar
Fullslot and beams red i need pink stock foams
jessbens is offline
Old 02-07-2011, 10:41 AM
  #5880
Default B44.1
Well I'm finally doing it trading a b44.1 for a dex410r with all the updates. I hope I have made the right choice is it better to wait for the big bore shocks, or get all the springs front and rear now. What would be a good setup for a dusty blown out track with not a hole lot of traction we run mainly 1/8 scale on it. Only time traction is really good is when we water it thanks guys hope I fall in luv with this 4 wheeler Thanks James
hitman72 is offline
