Like Tree22Likes
Old 01-22-2010, 11:32 AM
  #526
bustabo's Avatar
Trader Rating: 15 (83%+)
Battery has to he shorter than 24mm
bustabo is offline
Old 01-22-2010, 12:21 PM
  #527
ok thanks
Colts is offline
Old 01-22-2010, 01:13 PM
  #528
rdeppen's Avatar
colts shop for EFRA legal cells. like this one from amain
http://www.amainhobbies.com/product_...5C-74V-4200mAh
most roar legal saddle pack are to tall
rdeppen is offline
Old 01-22-2010, 04:30 PM
  #529
annonymous's Avatar
Trader Rating: 21 (100%+)
can the cars strap be raised or cut to make taller packs fit? i am currently looking at packs that are 31mm tall....
annonymous is offline
Old 01-22-2010, 05:38 PM
  #530
Trader Rating: 19 (100%+)
I wouldent suggest it, you would have to shim quite a few things. Just go with the shorter packs and and you wont have to worry about it. The epic 4200's, LRP 4800's, Flight power dark series 4650's and there are quite a few more.
trap121 is offline
Old 01-22-2010, 09:59 PM
  #531
HyperFX's Avatar
31mm is too tall.
The max height is not limited by the battery strap. It's limited by the height of the center shaft, and slipper. The batts must fit below them.
HyperFX is offline
Old 01-23-2010, 04:28 PM
  #532
fifi's Avatar
can have a look there.
post#92 ...
http://www.oople.com/forums/showthre...t=31939&page=5
or there
http://www.oople.com/forums/showthread.php?t=37078
fifi is offline
Old 01-24-2010, 05:13 PM
  #533
Order my Durango up can't wait to get it
Colts is offline
Old 01-24-2010, 05:50 PM
  #534
H0LESH0T's Avatar
Congrats, whay motor/esc you plan on running?
H0LESH0T is offline
Old 01-24-2010, 06:07 PM
  #535
HanIce's Avatar
Trader Rating: 12 (93%+)
Originally Posted by Poinas2
It's same thing as with 1/8 scale. Thinner oil in more slippery conditions and more turn-in, thicker when there is more traction or you need more pull.
In general on indoor / high traction you can use 15-25k front and 10.15k rear without any issues. Outdoor you might go to 10-15k front 5-10k rear. In Durango the oil has less effect than in 1/8 scale so don't be afraid to test different oils with big change in thickness. Also keep the front/rear ratio reasonable as usikng 20k front and 5k rear would lead to a twitchy/nervous rear and issues on ornering when trasiting from on to off throttle and back.
Thank you
HanIce is offline
Old 01-24-2010, 07:11 PM
  #536
I am going to run a lrp esc and a 7.5 speed passion and on the really big tracks that I race on I am going to put a 4.0 in there just to get some laughs but it will be so much motor
Colts is offline
Old 01-25-2010, 05:02 AM
  #537
rdeppen's Avatar
the low turn brushless motors are not a good choice offroad IMO. They have crazy top end and push featherweight TC's around but they run run really hot off-road. They just don't have the tq to push them around in the dirt. Also you just bought the heaviest 4whl buggy on the market. It's really gonna run hot.
rdeppen is offline
Old 01-25-2010, 05:14 AM
  #538
littlejohn's Avatar
Pffft..... with all due respect. I'm running a 4.5t tekin w/mmp & 17t pinion and the hottest my rango got during the 4hr enduro is 150ish motor & 140ish esc.
The key imo is a heatsink & fan on the esc.
littlejohn is offline
Old 01-25-2010, 04:56 PM
  #539
Does anyone have any front spindles they are willing to part with since i cannot order any (still out of stock!!!!) and can no longer run my car...
Goober9941 is offline
Old 01-25-2010, 05:09 PM
  #540
bustabo's Avatar
The reason why they are out of stock is because they are re-designing them. If u keep an eye on the crunch spacers and do not tighten the wheel nuts very tight ( replace wheel nuts periodically ) you shouldn't have a problem with the inner ring of the spindle coming loose.
Unfourtunately I don't have any more spindles and I don't know where to get them here in the states.
bustabo is offline
