Like Tree22Likes
Old 01-14-2011, 10:25 AM
  #5341
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Xchange
Hey guys,
About servo saver, i discovered his existance just after i ordered all my parts and was bo.
But it's my second DEX410, and i never broke this part, but since few weeks, i i broke frequently my servo arms and wait to put an xray servo arm.
My setup from the pics work not so bad but the car was hard to drive, front was very light and rear to heavier(oils)
Now, i switched to the Kinwald setup with few changes :
-10k Front - 2k Rear
-22.5wt, Black Springs, 2holes stock piston Front - 27.5 Rear, Green Springs 3holes 1.3mm drilled Rear
- No sway bar at all
- Front 2mm hub link location - hole 5 on shock tower front
- Rear External hub link location - hole 2 on shock tower
- Shock Location front : full internal shock tower, external arm
- Shock location Rear : Full External shock tower, full external arm
3degres Camber front and rear.
The car is loose from the rear, i will put 25wt and mid hole on the rear hub to fix the problem.
Can't tell if you run the full weight kit. If not I would give that a try, it really helps locking the rear in. Also 1* rear hubs and #4 rear pivot block.Good Luck!
Bman's 3XNT is offline
Old 01-14-2011, 11:46 AM
  #5342
rangerjkb's Avatar
Trader Rating: 45 (100%+)
After trying the 10k front, 5k rear the car had much more positive traction and did not diff out under hard acceleration than when I ran the lighter fluids 7k-F/3k-R. Car displayed better acceleration throughout, but had twitchyness feel.
rangerjkb is offline
Old 01-14-2011, 11:52 AM
  #5343
Maxxingout's Avatar
Trader Rating: 17 (100%+)
After trying the 10k front, 5k rear the car was much more planted and did not diff out under hard acceleration than when I ran the lighter fluids 7k-F/3k-R. Car had better consistency in handling during cornering/out of corners.
This is very good to know cause those are the weights i'll be trying next.
Maxxingout is offline
Old 01-14-2011, 12:00 PM
  #5344
grapejuice's Avatar
Trader Rating: 153 (100%+)
Thats what I've always run. Tried 15k in the front once, not too bad but 10k feels better.
grapejuice is offline
Old 01-14-2011, 01:24 PM
  #5345
try 10-1 or 10-2 works perfect at bula. you racing tomorrow?
cbrociuos is offline
Old 01-14-2011, 02:00 PM
  #5346
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Glad u like it, I also run the side weights not the brass skid plate though. I feel that may be a bit overkill. Car is dialed and stays down. Tires are also a very important, if not the most important, part. For us the durnagos are stuck to the surface with Suburbs. BKs are a lot looser but they would be quicker through the twisty stuff, I personally want a tire with plenty of grip than have to wonder when the tire will give way. Id rather make the tire "feel" looser with some setup adjustments than to change the tires altogether.
tonyv2382 is offline
Old 01-14-2011, 02:47 PM
  #5347
rangerjkb's Avatar
We're using the JConcepts Bar Codes (blue) F&R on a smooth hardpacked topsoil/clay mix track. Tried the M3 Holeshots and work great (safe/stable tire) but lost about .5 seconds per lap???probably driver related, lol! On a more (clay) track, guys are recommending the Bar Codes, but to use orange compound up front, which I plan to use at SmacTrac in St. Louis in early Feb. When I raced at TRCR in WA, on a very hard/dry track, the owner recommended the Bar Codes gold compound and worked fantastic. I'd definitely recommend both the Proline Suburbs and JConcepts Bar Codes for being fast tires to run on a smooth track.
Old 01-14-2011, 03:49 PM
  #5348
Trader Rating: 101 (99%+)
Default 410
My new 410R for the Reedy Race. I have my setup sheet from testing with Kinwald Wednesday night. Our track is damp/clay and there was some little tweaks that made a big difference. He was generous with sharing information and let me take his car back to my pit space to go through it...
PM me if you want me to send you the newest BK setup sheet... I tried saving it as an attachment, but I got a message saying it exceeds the limit?
*** Tresrey 30g Traction weight available!!! I have one that has one run on it... $15 (shipped)!!!
desertracerdad is offline
Old 01-14-2011, 03:50 PM
  #5349
Maxxingout's Avatar
Yea I'll be there. Second time racing so hopefully I'll get better this time. I changed a couple of things from last sat so hopefully it'll help. I just wish that pro line would come out with there front foams for the 4wd buggies already.
Old 01-14-2011, 04:00 PM
  #5350
R-E-A-P-E-R-'s Avatar
PM Sent
R-E-A-P-E-R- is offline
Old 01-14-2011, 04:08 PM
  #5351
rangerjkb's Avatar
desertracerdad, awesome looking car and sent you a 'pm' for the latest setup tweeks applied. Thanks for sharing for all to benifit!
Old 01-14-2011, 04:39 PM
  #5352
Konich's Avatar
Originally Posted by grapejuice
You need a lot more help then just fresh shocks!
You mad I didn't fill your mom's water dish or something?
Konich is offline
Old 01-14-2011, 04:40 PM
  #5353
Konich's Avatar
I ordered a few spares of the Tresrey servo saver. If you need or want one let me know. $18 plus shipping and I should have them this Friday. PM me and I'll get you squared away.
I also have a deal pending on some Azarashi bodies (I've ran one for months and love it). If your're looking for one let me know as I'm getting some pricing sent my way soon on those as well.
Konich is offline
Old 01-14-2011, 04:56 PM
  #5354
ABBOTT's Avatar
Let us know I may take one.
ABBOTT is offline
Old 01-14-2011, 04:59 PM
  #5355
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
Got pm about the body
turboxrayt1fk05 is offline
