Like Tree22Likes
Old 12-19-2009, 05:20 AM
  #511
Originally Posted by HanIce
Hey there guys,
When would I need to use thicker or thinner differential oil for the front and back??
Sorry, I'm not familiar with this concept and I have only driven 4WD a couple of times
Cheers.
It's same thing as with 1/8 scale. Thinner oil in more slippery conditions and more turn-in, thicker when there is more traction or you need more pull.
In general on indoor / high traction you can use 15-25k front and 10.15k rear without any issues. Outdoor you might go to 10-15k front 5-10k rear. In Durango the oil has less effect than in 1/8 scale so don't be afraid to test different oils with big change in thickness. Also keep the front/rear ratio reasonable as usikng 20k front and 5k rear would lead to a twitchy/nervous rear and issues on ornering when trasiting from on to off throttle and back.
Poinas2 is offline
Old 01-15-2010, 02:38 PM
  #512
Trader Rating: 27 (100%+)
So looking at pics and stuff online, looks like TD has a few really cool accessories for there drivers... Anyone know if they will release them.
C_Money is offline
Old 01-15-2010, 02:39 PM
  #513
pic didnt work, but if you go to there site, go there flickr pics page 30 there is a pinion gear holder with there logo.
C_Money is offline
Old 01-21-2010, 05:07 AM
  #514
annonymous's Avatar
Trader Rating: 21 (100%+)
does the DEX410 use associated, losi, or 12mm type rims, or some kind of other unique type? thanks
annonymous is offline
Old 01-21-2010, 05:23 AM
  #515
Trader Rating: 18 (100%+)
I have used jconcepts b44 wheels. They fit fine.
infanterene is offline
Old 01-21-2010, 01:59 PM
  #516
HyperFX's Avatar
Losi, JConcepts, AE. AE fronts can rub the ball cups, unless you shave the rim.
HyperFX is offline
Old 01-21-2010, 04:35 PM
  #517
annonymous's Avatar
so losi and associated fronts are the same and losi and associated rears are the same? please excuse my ignorance
Old 01-21-2010, 04:47 PM
  #518
annonymous's Avatar
sorry. . . . posted three times for some reason
Old 01-21-2010, 05:04 PM
  #519
annonymous's Avatar
Old 01-21-2010, 05:05 PM
  #520
bustabo's Avatar
Trader Rating: 15 (83%+)
the b44 has a wider hex than the losi/durango.
AE wheels rub the turnbuckle at full steering lock but at completely usable.
bustabo is offline
Old 01-21-2010, 07:10 PM
  #521
HyperFX's Avatar
Sorry, I've only used Losi rears on my 410. And, you can shim the AE fronts to keep them from rubbing.
HyperFX is offline
Old 01-21-2010, 07:11 PM
  #522
bustabo's Avatar
i just run the b44 front hexes on my 410 if im using the ae rims.
bustabo is offline
Old 01-21-2010, 08:07 PM
  #523
annonymous's Avatar
all of the wheels (front and rear) are losi, so i am in the clear and will not have to get all new rubber?
stupid questions here but i want TO MAKE SURE i am in the know before i buy one of these things
Old 01-21-2010, 08:08 PM
  #524
bustabo's Avatar
yes.
bustabo is offline
Old 01-22-2010, 11:14 AM
  #525
how tall can the battery be so they will fit.
Thanks, Colts
Colts is offline
