Like Tree22Likes
Old 01-10-2011, 05:59 PM
  #5221
Originally Posted by Dlewis4
PICS OF THE SERVO SAVER ARM!!!
that is the bottom one, that is the one that breaks.
cbrociuos is offline
Old 01-10-2011, 06:03 PM
  #5222
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Thanks Derek.
Jason Pelletier is offline
Old 01-10-2011, 06:07 PM
  #5223
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Sorry that took so long to get the pic up, we just received the picture from HRP
Dlewis4 is offline
Old 01-10-2011, 06:13 PM
  #5224
BMenard17's Avatar
Trader Rating: 88 (99%+)
I know this isnt your problem but why dont durango fix the issue with the saver..... It seems to be ok with everyone that they are breaking. Has anyone brought it to there attention that this is happening?
BMenard17 is offline
Old 01-10-2011, 06:19 PM
  #5225
They may but whatever other cars have this same issue. My 8ight 2.0 does as well.
only a 15 dollar fix and it's beefy....
Old 01-10-2011, 06:44 PM
  #5226
its one small issue, and if you can drive w/o hitting a wall or slamming a tube the stock piece is pretty durable. this car is about as close to a tank as you'll find in rc. i only wish my other cars would take half the abuse this kit will. besides you have to let the aftermarket have something. if they were going to redesign something they should start w/ the x-rings! its pretty easy to see why they might not have caught both issues in testing. the diffs were prob. getting fluids changed after every run by the pro testers to see what worked best under different conditions, and they all have mad skills and werent wodding up the car to break the servo saver arm. just my .02.
Old 01-10-2011, 06:45 PM
  #5227
Dlewis4's Avatar
HRP only has 15 of em left. Had 50 this morning.
If you need one... RCE9801 at premierehobbies.com!
Dlewis4 is offline
Old 01-10-2011, 06:52 PM
  #5228
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
Take a gander at my freshly painted body from mikeLdesigns
TraxxasPeter is offline
Old 01-10-2011, 06:53 PM
  #5229
BMenard17's Avatar
good answer.. ill just live with it
Old 01-10-2011, 07:18 PM
  #5230
nice!
Old 01-10-2011, 07:40 PM
  #5231
ABBOTT's Avatar
by hv do you mean your running that servo above 6 volts? if so what voltage and im guessing your adjusting the esc's bec? thanks in advance!
Sorry looking again its the Savox 1267 Im running. I know its way to much and I only set it up hv cause I had never used one this way. (voltage coming directly from lipo)
ABBOTT is offline
Old 01-10-2011, 07:56 PM
  #5232
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Just ordered one!!! No more worries for that part, for when I do tap something!!! Gotta get'em when while they're available!!!
rangerjkb is offline
Old 01-10-2011, 08:00 PM
  #5233
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
That looks excellent TraxxasPeter
Drift_Buggy is offline
Old 01-10-2011, 08:22 PM
  #5234
i have a savox tg, .07 and like 160 on the torque. dont remember the #. id like to try it in the rango, but im about out of room. dont really have a place for a cap. i was thinking if i turn up my bec on the esc to 7.4volts it would drop the amp pull of the servo and i may not need the cap. wasnt sure if the servo would handle it or if the extra voltage would be enough to not need a cap. if it wasnt such a pain in the arse to change the servo id try but im a little on the lazy side cause my airtronics servo works fine. maybe ill throw it in my f.t. sc10 i have on order.
Old 01-10-2011, 10:11 PM
  #5235
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Def one of the nicest bodies Ive seen yet
tonyv2382 is offline
