Like Tree22Likes
Old 01-10-2011, 08:05 AM
  #5206
Maxxingout's Avatar
Trader Rating: 17 (100%+)
Anyone replace the stock ball joints form the servo horn to the servo saver with another brand? I just looked at mine and it's starting to form a split right on the molded line. I knew i should have rumn my 3mm tap before i attempted to screw in the screw. I was havin ghte same problem with the ball joints on the sway bar links too. I don't really feel like buying the entire set just to gets these since i don't plan on using the stock joints anymore.
Maxxingout is offline
Old 01-10-2011, 08:41 AM
  #5207
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Originally Posted by mccoy
hey guys! i need your help on this call...i'm loocking to upgrade my turnbuckle but i just dont know which ones...b4 rod or hot bodies?? so it would be appreciated if someone can print me which parts with the length! thx a lot!!
I went with the Lunsford Titanium 1 3/4" (LNS1167) and fit perfectly with no issues. Check out Premiere Hobbies for some great deals or pm me if interested for great pricing on 4 pk., the 2 pks are currently out of stock.
rangerjkb is offline
Old 01-10-2011, 08:44 AM
  #5208
rangerjkb's Avatar
Originally Posted by Konich
Anyone else running the rubber shock shaft stoppers? If so where at?font/rear/both?
Any performance advantage disadvantage to running these?
Yes, using the shock rubber stoppers, there is some discussion a few pages back where we discussed. The rubber stoppers also keeps the shock pistion/screw from hitting the inner shock cap when shock is at full upstroke. Boots on the shocks, seem to work well, as in 8th scale and keeps the oil cleaner over longer periods of time.
Old 01-10-2011, 09:56 AM
  #5209
Trader Rating: 42 (100%+)
Originally Posted by ABBOTT
Which ones, I will try most anything once. Not that I think there is anything wrong to start with.
HPI 6814 is the bladders I used. My LHS stocks them.
miket3 is offline
Old 01-10-2011, 10:55 AM
  #5210
rangerjkb's Avatar
Default Diffs
Fianlly going to the 10k/5k diff setup to try this week...I know, I know, what took so long, lol! I like to experiment to find something that may work better and still remain competitive, but way too many have used this setup with tremendous success. Looking forward to Wed racing action and hopefully decreasing lap times.
I've been running 18mm to 19mm ride hight evenly front & rear......Which do you prefer?
Old 01-10-2011, 11:36 AM
  #5211
jdogger1's Avatar
Cool Team Durango at Kyosho Off Road Winter Cup
Check out this report Team Durango sent us today...
It is the fourth story sown on the website...
www.rcinsider.com
jdogger1 is offline
Old 01-10-2011, 01:47 PM
  #5212
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Awesome! Looks like fun!
Dlewis4 is offline
Old 01-10-2011, 03:23 PM
  #5213
Trader Rating: 101 (99%+)
Default Steering Servo?
Does anyone have a recommendation on a servo that fits without any modification to get full throw to the left & right? I installed the Tresrey aluminum saver and have tried two different servos. First was a KO PDS2413 (servo ARM - hits the top of the case). Next was a Team Orion VDS1007 (servo saver - hits the upper right corner of the case)...
I have tried both the plastic & alum versions of the steering sets, hoping I could get clearance using one of them... I would prefer to stick with the aluminum steering set/plate so if anyone has a recommendation without the need of a dremel, I am open to suggestions?
And I have tried different arms of different height/length, etc....
Thanks in advance for any input!
desertracerdad is offline
Old 01-10-2011, 03:24 PM
  #5214
dangerwr's Avatar
Futaba BLS551
dangerwr is offline
Old 01-10-2011, 03:25 PM
  #5215
Dlewis4's Avatar
PM sent on a Savox servo!
1257 and 1258 would be my choice!
Dlewis4 is offline
Old 01-10-2011, 03:50 PM
  #5216
rangerjkb's Avatar
Used to use a BLS352 that worked great and had no issues, but just switched to Savox. Please 'pm' either, Derek (Dlewis4) or I, for a great price on Savox if interested.
Old 01-10-2011, 04:01 PM
  #5217
turboxrayt1fk05's Avatar
Trader Rating: 27 (100%+)
ok fellas i use a savox 1257tg with a racer edge servo horn and it clears the middle shaft atleast by 3mm
turboxrayt1fk05 is offline
Old 01-10-2011, 04:09 PM
  #5218
ABBOTT's Avatar
I use the Savox 1267 running hv as well love that i dont really have to concern myself with the saver with a top notch servo like this.
ABBOTT is offline
Old 01-10-2011, 05:30 PM
  #5219
I use the Savox 1257 running hv as well love that i dont really have to concern myself with the saver with a top notch servo like this.
by hv do you mean your running that servo above 6 volts? if so what voltage and im guessing your adjusting the esc's bec? thanks in advance!
cbrociuos is offline
Old 01-10-2011, 05:55 PM
  #5220
Dlewis4's Avatar
PICS OF THE SERVO SAVER ARM!!!
Dlewis4 is offline
