Like Tree22Likes
Old 12-29-2010, 11:43 AM
  #4786
Maxxingout's Avatar
Trader Rating: 17 (100%+)
I used the guide from the durangos home page site with my digital calipers. I set it per factory recommendation. The side that that broke is very thin. If anyone elses saver broke on the other side let us know. My guess is almost will be broken on this side.
Maxxingout is offline
Old 12-29-2010, 11:48 AM
  #4787
uberjeff's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Maxxingout
well after only my second run (partly into actually) i too have become victim of "cheap plastic servo saver junk"! Call it a bad design, cheap plastic, or both i'm not a ahppy little camper. Funny thing is i was weaving in and out of a S type section when i lost my steering. I'm sure that's just the place it decided to let go and was stressed/cracked already but look at these pics, like new!! Anyone want to buy a slightly use servo saver HAHA!
PM sent to see if you are interested in doing a group buy.
uberjeff is offline
Old 12-29-2010, 11:54 AM
  #4788
ABBOTT's Avatar
The ones i have seen were all broken in that same place. The Tresrey parts came very quick, 3 days. My last order however which was in a much larger box (body) took almost 3 weeks cause of customs.
ABBOTT is offline
Old 12-29-2010, 12:00 PM
  #4789
Maxxingout's Avatar
and did you use[email protected] to contact them? Just want to make sure i've got the right info.
Old 12-29-2010, 12:04 PM
  #4790
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Im just sitting by waiting for this to happen to me.
tonyv2382 is offline
Old 12-29-2010, 12:48 PM
  #4791
hlb14's Avatar
Trader Rating: 28 (100%+)
+1
hlb14 is offline
Old 12-29-2010, 01:04 PM
  #4792
Originally Posted by hlb14
well the ups man just came, i'm part of the durango family now... the wife is going to kill me!
lmao, only if you tell her. hopefully you got the spec kit. like i say if your in trouble anyway, might as well make it worth your while!
cbrociuos is offline
Old 12-29-2010, 01:07 PM
  #4793
hogmansp's Avatar
Trader Rating: 47 (100%+)
Default Shock test update
Well ran a few laps with the Shumacher shocks and hate to say it but they really planted the car on our track conditions. Took a look and the vid grapejuice posted and your track conditions are like carpet compaired to our indoor track. Had the shocks setup with 35-35 front rear oil and a 4 in lb spring in front and a 2.5 in the rear. Needed to run a 3.5 in the front and a 3 in the rear but they were unavailable for tested yesterday. Worked with a few durango setups today on the bench and to get the rangos to "feel" like the shumachers I had the fronts set up with dark red spings and 15wt oil and 2 hole pistons drilled to 54. The rears with dark blue and 10wt oil 3 hole pistons drilled to 54. To feel the shumachers yesterday I would have thought they would have been like a pogo stick but I am thinking that we are needing the quick rebound to keep in contact with the track. Car had more than enough steering with the 10-3 diff setup but I am going to try and bump them up a little just to tighten the rear up a little bit. Car rotated very well but was on the verg of being unpredictable. Here is a vid of the track conditions. Its a truggy nitro race but gives you the idea. Track is medium grip at it's best starts out the day very greasy and ends up a little dry. You can see if you look close at the surface it is loaded with hand size pot holes that just might be the reason for the inconsistant reactions of the car. I will post up with an update shortly on the couple of tests I want to run. Scott
http://www.youtube.com/watch?v=ClX_Er-fy9g
hogmansp is offline
Old 12-29-2010, 01:39 PM
  #4794
grapejuice's Avatar
Trader Rating: 153 (100%+)
I am assuming you were using the shuey big bores? With big bores, you run them a lot softer than a standard size shock, which is why to get the durango ones to feel the same on the bench you have to go so light. And yes, my home track is very very high bite, we run losi pink slicks.
grapejuice is offline
Old 12-29-2010, 02:25 PM
  #4795
hogmansp's Avatar
Yes they are the big bores. Very close to the same in. lb. spring ratings but completly different oil weights. Simply made the car planted in our conditions. I will try and post up a couple pics when I get a chance.
hogmansp is offline
Old 12-29-2010, 02:41 PM
  #4796
R-E-A-P-E-R-'s Avatar
How did you mount them on the front without them hitting the CVD's?
R-E-A-P-E-R- is offline
  #4797
hlb14's Avatar
yup got the 2010 spec kit, she'll find out saturday when its spread out all over the kitchen table while i'm building it and watching football all day! i won't get any for a month but from reading about the cars performance it will be worth it
hlb14 is offline
Old 12-29-2010, 02:59 PM
  #4798
ABBOTT's Avatar
Contact Yuji Shiraishi for [email protected] and he will hook you up. Super fast service, just remember they are on the other side of the globe so depending on the time of day it may take several hours to reply.
ABBOTT is offline
Old 12-29-2010, 03:10 PM
  #4799
hogmansp's Avatar
The bottom of the shuey springs narrow down and clear by using a 2mm shim next to the arm on the bottom mounting hole and a 2mm spacer on the top stud. I will get a pic here shortly after dinner.
hogmansp is offline
Old 12-29-2010, 04:02 PM
  #4800
hogmansp's Avatar
Here are a couple of pics. Sorry camera phone and dirty car.
hogmansp is offline
