Like Tree22Likes
Old 12-22-2010, 06:28 PM
  #4576
tonyv2382's Avatar
Trader Rating: 67 (100%+)
True the slop is there in the front end. A lot of it but when I'm running I don't even notice anything that hampers performance.
My fellow durango driver has placed some o-rings in certain spots (not sure where but ill ask) to take out that slop. I will ask him next time I'm out there.
tonyv2382 is offline
Old 12-22-2010, 09:05 PM
  #4577
anyone want to trade a brand new b44.1 for a durango. Assembled this car didn't paint the body really wanted the durango but LHS has none left, and will not get anymore thaks james
hitman72 is offline
Old 12-22-2010, 09:09 PM
  #4578
tonyv2382's Avatar
LoL...Where is that B44 guy who made a big stink about the B44 a few pages back, these things always happen at the wrong time
Try trading it on the for sale thread bro. Im sure you'll get some hits.
Old 12-22-2010, 09:18 PM
  #4579
thanks man thanks
hitman72 is offline
Old 12-22-2010, 09:23 PM
  #4580
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Originally Posted by cbrociuos
+1 i was happy w/ my kit bearings, im still running a lot of them. if you take all the play out of everything the dirt will start to cause drag and binding too. (the ak47 is the most reliable assault rifle the world has ever known because the slop in the action) a little play isnt necessarily a bad thing, just sayin. i do have a complete spare set of avid bearings $1 a piece for almost any size, cant beat it.
+1 on the Avid bearing kit for the Durango..they work awesome and spin seems like forever.
-1 on the AK47........It is the cheapest one to make in the world though with all stamped parts
rangerjkb is offline
Old 12-22-2010, 09:31 PM
  #4581
rangerjkb's Avatar
Originally Posted by Eric 1972
I ran I 22 on a 10.5 on a 40X80 track and temps were 170 so I dont think its a good idea to try that out the right pinion is a 27 like reaper said. I will be running a 23 and my 7.5
Wow...that would be way over geared for the motors I've used, even on a 80 ft. straightaway. Currently run a 24 tooth pinion on a 13.5T Murfdogg Synergy. Truly not wanting to disagree, but to each his own and probably has alot to do with motor brand, ESC programing, track layout and ambient temperature. Motors would never get above 150 degrees and performs exceptionally well.
Old 12-22-2010, 09:38 PM
  #4582
R-E-A-P-E-R-'s Avatar
I think the kv rating is a bit elevated on those murfdog motors. Everything I have read says they need to be geared much more like a mod motor than a superstock. My temps are right around 150-155 after a 6 min race. Geared with the 32 pinion gear. Tekin motor and esc.
R-E-A-P-E-R- is offline
Old 12-22-2010, 09:44 PM
  #4583
ekv
Default pic of kinetic setup?
anyone have a pic of their current setup and wiring who uses a kinetic esc? i've seen plenty of pics of the tekin setups... curious if anyone has a good trick with the kinetic as it is a bit bigger..
thanks!
ekv is offline
Old 12-23-2010, 09:47 AM
  #4584
duckman996's Avatar
Trader Rating: 14 (100%+)
Anyone else having a problem with the pins that hold the front hexes on sticking in the hexes? I'm trying to remove the pins so I can replace a wheel bearing and there is no way these things are coming out. Am I missing something?
duckman996 is offline
Old 12-23-2010, 09:54 AM
  #4585
Team Tekin
Randy_Pike's Avatar
Ok, where is everyone gearing their 13.5 cars for an indoor track say 85ft straight?
I'm looking to hit the track for some quick testing to see what the hype is on this class? I've NEVER ran such a low powered motor in a 4wd car before ! LOL
Randy_Pike is offline
Old 12-23-2010, 10:01 AM
  #4586
tonyv2382's Avatar
Did you use something to keep the pin from falling out?
Old 12-23-2010, 10:06 AM
  #4587
I put a tiny smear of Blue lactate on my front and rear pins.. and I mean tiny-enough to hold them in. But easy to tap out and remove when needed..
Ditch roll pins if people are still using them! they snap..
jamiekerr14 is offline
Old 12-23-2010, 10:24 AM
  #4588
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
That sounds tempting.
Jason Pelletier is offline
Old 12-23-2010, 10:56 AM
  #4589
RS Pro
Redline 13.5
Geared 32/87
Hotwire Settings
boost 45 start 5443 end 20016
Turbo 20 .24 delay Ramp 2.0
Timing adv 14
Break 75
TP 3
CL off
My car is just as fast as any other mod car on the track
Track MHOR RC Raceway, CO 40x80
Old 12-23-2010, 02:00 PM
  #4590
Well I know it was totally wrong gearing but on the tekin website the guy running a 10.5 in his Durango ran it with a 22 so thats what I did made all the settings the same as his and let me tell you what a mistake I am lucky I didnt cook the motor and ESC both came off at 170+. But now I am going to run a 7.5 with a 23 tooth pinion as pure what the site comeseethis says to run and thanks again for the link to that site guys. They are making a new track down here the strait is going to be 120 feet long and its a indoor track It opens on the 28th I am very excited about it it is going to be about 3 times the size of the 1 we have now
Eric 1972 is offline
