Like Tree22Likes
Old 12-21-2010, 04:25 AM
  #4516
Maxxingout's Avatar
Trader Rating: 17 (100%+)
Depending on which reciever you're running and type of setup, the losi servo horn will not clear the reciever. At least that's what i found on mine. I've got the specktrum reciever (not the mini) and the losi horn is 1mm thicker than the stock plastic one. that 1mm is about all the clearance you get. just something to check before you order.
Maxxingout is offline
Old 12-21-2010, 06:12 AM
  #4517
The hudy servo horn is very thin and nice and strong I use one in my 808E and will be getting one for my 410
Eric 1972 is offline
Old 12-21-2010, 06:47 AM
  #4518
Maxxingout's Avatar
Do you by any chance know if the hudy is the same thickness as the stock plastic horn?
Old 12-21-2010, 07:02 AM
  #4519
Trader Rating: 54 (100%+)
just my opinion but if your breaking Team Durango plastic servo horns or saver arms your servo saver is to tight and if you dont adjust when you beef up the steering system your servo or servo gears could be the next to go ...
rkhess is offline
Old 12-21-2010, 07:16 AM
  #4520
Maxxingout's Avatar
I have not broken anything yet. I'm just looking into possible fixes per other 410 users problems they have had.
Old 12-21-2010, 07:36 AM
  #4521
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Mines the opposite. My losi horn is way thinner than the Rangos. I had to add a spacer (2mm) to compensate for the thinner losi horn...
Bman's 3XNT is offline
Old 12-21-2010, 07:55 AM
  #4522
Maxxingout's Avatar
hmmm..I bought the one linkerd to a-mains from someone here. I guess it's kind of hard to get all the right measurements all the time. which losi version did you get?
Old 12-21-2010, 08:14 AM
  #4523
R-E-A-P-E-R-'s Avatar
I used one spacer on mine and it could use 1 more. But it is working fine and I do not feel like messing with it.
R-E-A-P-E-R- is offline
Old 12-21-2010, 09:01 AM
  #4524
This one as well...........
Old 12-21-2010, 09:07 AM
  #4525
Great picture. I think the reason the servo savers are breaking, is because you see where the rub mark is on his servo? Mines the same way. I think that every once in a while the servo saver work likes its supposed to, but when it seperates it whacks the ear/case on the servo. When it releases, it drops down even further.Therefore snapping..........Just a thought I had all along.........
Old 12-21-2010, 09:32 AM
  #4526
All I know is with the aluminum servo arm and saver I do not worry about anything breaking.
Old 12-21-2010, 09:33 AM
  #4527
yes the Hudy one is way thiner then the stock one but I see now it might have to be shimmed out
Old 12-21-2010, 09:42 AM
  #4528
Maxxingout's Avatar
I see, well i've got my rs and reciever opposite of how reaper has his. then again even if it was like his i still think i would have a issues hitting the esc then. I just think that the regular reciever is a bit to big, I should have got the mini. I guess i'll she how it does today at practice since this will be my first time out with it.
Old 12-21-2010, 09:47 AM
  #4529
Maxxingout's Avatar
http://www.amainhobbies.com/advanced...99032&x=11&y=8
Reaper is this the same servo horn you have on your buggy?
Old 12-21-2010, 09:48 AM
  #4530
I agree that that is a problem with the stock servo saver. The aluminum one has clearance through the full range if steering. Picture taken with wheels full left turn.
Maxxingout
I am actually running the full sized RX. I just stood it up on its side. Just an idea for you.
