Like Tree22Likes
Old 11-06-2009, 08:15 AM
  #436
Trader Rating: 18 (100%+)
damn i was too late`on that deal. if anyone is selling a dex410 please let me know.
infanterene is offline
Old 11-06-2009, 09:20 AM
  #437
Trader Rating: 19 (100%+)
They have them in stock, you can order them here. It takes about 2-3 days to get to US address's
http://www.team-durango.com/shop/sp/buildOrder.php
trap121 is offline
Old 11-06-2009, 10:28 AM
  #438
msconcepts's Avatar
Trader Rating: 38 (100%+)
Originally Posted by grapejuice
So, when can I pick that up today for Junction tomorrow.....
JUST BRING ME A $2000 DEPOSIT
msconcepts is offline
Old 11-06-2009, 11:28 AM
  #439
grapejuice's Avatar
Trader Rating: 153 (100%+)
Sweet, I'll be right over with a check, and since it's a deposit I get it back when I return the car right? (in better shape of coarse then when matt drove it )
grapejuice is offline
Old 11-06-2009, 01:37 PM
  #440
Blackstring's Avatar
Originally Posted by trap121
Blackstring, Have you had a chance to run your DEX at CRC yet?
No I haven't I was going to run tomorrow but My IP battery hasn't even shipped yet even though I ordered it last friday. Figures that I went with the killer price of 65.00 on ebay coming from hong kong, should have just spent the extra 35.00 and got it from Amain.
Blackstring is offline
Old 11-06-2009, 02:32 PM
  #441
Do I need to order all the springs too or do the stock springs work on US tracks? What about toe plates? Besides spares do i need any other parts.
The track I run on is an 8th scale track. How does it handle big jumps and rough tracks?
Old 11-06-2009, 02:46 PM
  #442
msconcepts's Avatar
ill let you know!!!!!!!! from what i can tell after only one night its not bad but really bouncy. looks like adding weight will calm it down a bit though. ill let you know after i spend some more time with it!!!!!
Old 11-06-2009, 04:33 PM
  #443
Anyone encounter rough mesh with either of the diff's pinion/outer gear? My front had a "spot" about 6 teeth or so that was tighter than the rest of the rotation causing a on off on off grinding noise. I got it to go away by putting the copper shim to the other side of the diff to loosen the mesh. I cleaned and meticulously inspected the outer gear and seemed OK to the naked eye. I also reseated the gear to the diff housing but the spot was still there. Anybody else have this issue? If not I'm gonna contact TD..
Old 11-06-2009, 05:02 PM
  #444
I had a similar issue and contscted them. They gave me alist of things to check. After taking the whole drive train and diffs apart 2 or 3 times I narrowed it down to the shims. I took all the shims off the diff and the spur. Its still a tight drive train but the grinding has stopped
trap121 is offline
Old 11-06-2009, 10:16 PM
  #445
png
what are the list to check? care to share.
png is offline
Old 11-07-2009, 04:16 PM
  #446
DRKSYDE's Avatar
For those that have ordered one of these cars has any one not received a confirmation email? i know it said within 2 hours if not recieved to check the spam/junk file to luck. i know its the weekend but as i cant find my order number anywhere and my card has been drafted i might be out of luck.i am not bashing just get paranoid when ordering from over seas and couldnt use paypal.
DRKSYDE is offline
Old 11-07-2009, 08:18 PM
  #447
I received mine within 20 minutes, and the shipping notice the following day. But it was during the week. Try calling or email them on monday. Be patient, I don't think they are in on the weekends. They're really quick to sorting out problems though.
Old 11-07-2009, 08:26 PM
  #448
Blackstring, did you get the grinding figured out?
trap121 is offline
Old 11-07-2009, 08:40 PM
  #449
yeah, I had moved the brass shim to the other side so both were on the opposite side of the outer gear. This spaced it over a tad to loosen the gear mesh without adding side slop that just removing the shims would do. Also I noticed it got tighter when I inserted it into the bulkheads so I loosened the chassis/bulkhead screws, inserted the diff, then tightened the screws. works fine now.
Still waiting on my batteries though. Le sigh....
Old 11-07-2009, 08:50 PM
  #450
Good to hear. Without the shims your diff slid around?? Mine was so tight that when I let off the throttle the wheels came to an immediate stop...along with making a scary noise. My diff sits perfect w/o any slop....strange buggy.
Let me know once you get that thing on the track. I think I'm going to try lighter diff oils next time I come out there to experiment a little
trap121 is offline
