Like Tree22Likes
Old 10-29-2009, 07:38 PM
  #421
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
I ran the IP 4200 had trouble with run time. Ran a 8 minute main and the car did not make it with a 8.5
Now with the LRP 4800 runtime is no longer an issue and I now run a 5.5
Crazy Carl is offline
Old 10-30-2009, 03:30 AM
  #422
Blackstring's Avatar
Lrp's site says they are 23.5mm tall, so there is not even 1mm of room left with the LRP packs? Orion's new packs are also 4800 and are 45c. I've used their batteries since they came out with lipos and love them. I had 4 SMC batteries fail on me, 2 red carbon and 2 C-max's. Will never use theirs again, I do like their NIMH though. The LRP sure is pricey for a 4800.
I did read in Oople's article that just about every wheel fits, too. Another question, though. I know lots of people have asked already but not too many has had a good feel for the diffs oils yet it seems. For indoor clay should I be thicker fluids or thinner? I come from 8th scale electric and always ran 5F/3R inside and went up to 7F for larger open tracks. Is 10F/5R a good starting point or is the 20F/10R the norm now? seems a bit stiff for tight indoor.
Blackstring is offline
Old 10-30-2009, 06:27 AM
  #423
Trader Rating: 19 (100%+)
You have a PM
trap121 is offline
Old 10-30-2009, 07:37 AM
  #424
Crazy Carl's Avatar
I am currently running 7000 front and 3000 rear
I run indoors on a clay and top soil mix med. traction hard packed
It working well for me
Old 10-30-2009, 09:50 AM
  #425
kjuliussen's Avatar
I tried 20k front and 10k rear last weekend at a inndoor carpet race. worked really well..
kjuliussen is offline
Old 10-31-2009, 05:23 PM
  #426
I prefer 30f/10r for indoor hard clay. I havent tried anything less than 20 in the front.
What type of conditions would I want a lower oil up front?
trap121 is offline
Old 10-31-2009, 08:26 PM
  #427
Well as far as 8th scale goes, lighter fluid in front will generally give more steering but too light will start to get grabby and inconsistent. If you have more hairpins or tighter course will need a lighter fluid to allow the inner and outer wheels to rotate and different speeds.
Old 11-01-2009, 08:27 PM
  #428
Crazy Carl's Avatar
Blackstring is correct.
A tighter track would require lighter oils for a quicker diff type action
My local track has alot of quick esses and 180's with one sweeper
I like the 7000 in front but the 10,000 is also good not quite as active
Its a matter of feel.
Also a heavier front will pull the car around the turn
Trial is the best way to tell. Preferably on the clock if you can
Old 11-04-2009, 12:40 PM
  #429
FMLinero's Avatar
Questions?? Spare Parts for DEX410
If I buy this car. What spares parts you must have in your toolbox?
FMLinero is offline
Old 11-04-2009, 01:56 PM
  #430
The normal stuff, arms, hubs, I have raced a few times and have not broken anything. The car is very durable. Also get some drive shaft pins. There have been a few people who have had them pop out...including me. Putting heat shrink over the shaft where the pin inserts helps too
trap121 is offline
Old 11-04-2009, 02:07 PM
  #431
FMLinero's Avatar
Thxs
FMLinero is offline
Old 11-04-2009, 03:33 PM
  #432
I didn't even use the pins, instead I had some extra losi ones that fit much nicer. They are slight thicker so they squeeze in place just enough not to pop out. The stock pins just kept falling out during assembly. The losi ones are also longer, as long as the hex is wide. Bonus.
This is the nicest anything I've seen for production quality. Its as if I bought THE prototype that has thousands of hours of refignment into it. A lot of times long run production tends to scale back on tolerences and fit/finish to get the product out the door. I work directly with engineers and prototyping and am shocked at the quality in this car, beyond my expetations.Only issues seem to fall into the packaging as screws and parts were not in bags they were supposed to be in. And that the instruction were slightly vague as far as discriptions, like bleeding the shocks properly or setting the servo saver. Really just small things some may not know how to do.
Old 11-06-2009, 05:42 AM
  #433
Blackstring, Have you had a chance to run your DEX at CRC yet?
trap121 is offline
Old 11-06-2009, 08:04 AM
  #434
msconcepts's Avatar
Trader Rating: 38 (100%+)
thanks again for the killer deal!!!!!!!!!
msconcepts is offline
Old 11-06-2009, 08:11 AM
  #435
grapejuice's Avatar
Trader Rating: 153 (100%+)
So, when can I pick that up today for Junction tomorrow.....
grapejuice is offline
