Like Tree22Likes
Old 12-06-2010, 09:30 PM
  #4036
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Originally Posted by BOLISARIO
Thank you sir. Will send a pm ASAP.
So has anyone tried the IP(Intellect) 5200 45c saddle pack and does it fit well on the buggy?
Anyone have any light green rear springs they want to sell me?
They are like 2-3 bux...?
Dlewis4 is offline
Old 12-06-2010, 09:32 PM
  #4037
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
For the springs, I believe so, it's just that most stores are currently sold out.
BOLISARIO is offline
Old 12-07-2010, 03:26 AM
  #4038
syllag1969's Avatar
That's what i run and it fits very goog. Mine a got a really good hit and i thought they were going bad as the casings started seperating but it only looks like bad glue or something cause power is still there and good number on voltage.
As for the pin coming out of the center drive shaft, a fellow racer had his slide out last sunday and chewed the top of his Yeah Racing soft lipo pack, burst of flames, melted body shell and battery strap! Went for my final, warm up lap, lost the rear traction and found out mine came out loose too on the top of the battery case. That showed me the importance of a had case lipo!
syllag1969 is offline
Old 12-07-2010, 03:36 AM
  #4039
hacker's Avatar
Trader Rating: 141 (100%+)
Default dex410 4 sale
I have a durango dex410 4 sale
hacker is offline
Old 12-07-2010, 07:33 AM
  #4040
rangerjkb's Avatar
Trader Rating: 45 (100%+)
TDR330063 Rear Shock Spring Set (5.5x10.0x1.0mm) (2) @ $3.49. There are 2 sets in stock at www.losipartshouse.com Hope this helps get you set up and on the track soon.
rangerjkb is offline
Old 12-07-2010, 07:56 AM
  #4041
BOLISARIO's Avatar
Awesome, thanks. Just bought the 5200 pack on ebay and was worried they might be too tall. Sometimes manufacturers list inaccurate specs and measurements.
Old 12-07-2010, 08:04 AM
  #4042
BOLISARIO's Avatar
Thanks....and they're somewhat local too.
Old 12-07-2010, 05:00 PM
  #4043
tonyv2382's Avatar
Trader Rating: 67 (100%+)
Dont know if this was addressed, but I noticed today that when my servo horn turns to the left it hits the front drive shaft just a lil bit. Anyone notice that?
tonyv2382 is offline
Old 12-07-2010, 05:01 PM
  #4044
tonyv2382's Avatar
Originally Posted by hacker
BTW..good luck with that...I had mine listed WITH spare parts for way cheaper and no1 bit on it.
Old 12-07-2010, 05:33 PM
  #4045
dangerwr's Avatar
Are you running the stock plastic one? I know the aluminum Racer's Edge needs to be modified. The Losi seems to fit great. Cheers!
dangerwr is offline
Old 12-07-2010, 06:22 PM
  #4046
Matt Howard's Avatar
The Racer's Edge one comes close but I have about 2mm of clearance between the driveshaft and servo arm, I didn't have to modify anything.
Matt Howard is offline
Old 12-07-2010, 06:52 PM
  #4047
dangerwr's Avatar
I wonder then if it is servo dependent? I guess servos are all sized a bit differently and must have the pivot at different heights??
dangerwr is offline
Old 12-07-2010, 06:53 PM
  #4048
Have no clue on that one, I'm running a Savox servo, don't remember what model.
Old 12-07-2010, 07:01 PM
  #4049
ABBOTT's Avatar
Bingo! I had not noticed this before working with the tight spaces in this ride.
ABBOTT is offline
Old 12-07-2010, 07:03 PM
  #4050
Konich's Avatar
If you have 09 spec you'll have to grind down the racer's edge to clear (I did on mine) as the driveshafts are @ 2mm lower. I did buy a hudy and will give that a try as you can barely side a piece of paper in between my servo horn and front driveshaft.
Konich is offline
