Like Tree22Likes
Old 11-24-2010, 01:08 AM
  #3751
MaTt 93's Avatar
not sure what going on with all these servo saver crank arms and servo horns breaking... i've been running my rango for prob 2 months now and have had zero issues and thats running on a high traction track and a fairly rough track with big jumps. And thats still running the stock plastic parts too. I just followed this http://www.team-durango.com/blog/?p=1017 when i built it.
MaTt 93 is offline
Old 11-24-2010, 01:32 AM
  #3752
yodace's Avatar
I set the savor from whatever it said on the website and it still broke. Don't if the losi rigid ball cups would have anything to do with it. LoL
yodace is offline
Old 11-24-2010, 01:37 AM
  #3753
dangerwr's Avatar
I know what you mean. Some have the issue and some do not. Truly is the craziest thing . . . but I hit the pipe like a crack addict!
dangerwr is offline
Old 11-24-2010, 03:50 AM
  #3754
started installing my tekin rs.
damn everything fits so tight...
LiL_JaSoN is offline
Old 11-24-2010, 03:57 AM
  #3755
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Tekin and a micro RX should drop right in no problemo!!!
Dlewis4 is offline
Old 11-24-2010, 04:16 AM
  #3756
thats what i have.. still gotta solder one more wire, then ill be ready to test it out.
Old 11-24-2010, 04:18 AM
  #3757
Dlewis4's Avatar
I have my RX next to servo and the tabs on the ESC flipped 180 from where you are.
Dlewis4 is offline
Old 11-24-2010, 04:36 AM
  #3758
too late now.. already soldered them on like that.]
guess it looks nice n neat like that lol.
i was going to put the receiver next to the servo, but the wire coming out of the side of the esc pushes up againest the receiver..
Old 11-24-2010, 04:52 AM
  #3759
Dlewis4's Avatar
Which is why mine is turned around and shortened
Dlewis4 is offline
Old 11-24-2010, 06:17 AM
  #3760
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Default Electronics
I had realestate issues at first, then went with the Spektrum Micro Rx and all fits easily. Unfortunately had to change over from the HRS only Tx/Rx, but it all works fantastic. Hope the pics help.
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410-top-open.jpg   Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-dex410-right-front-open.jpg
rangerjkb is offline
Old 11-24-2010, 06:54 AM
  #3761
R-E-A-P-E-R-'s Avatar
I used a standard RX in mine. I just stood it up on end.
R-E-A-P-E-R- is offline
Old 11-24-2010, 07:11 AM
  #3762
Trader Rating: 19 (100%+)
i think the servo arm stripping issues have to do with servo saver spring tension as i never had issues til i tightened the servo saver
minicoop is offline
Old 11-24-2010, 08:13 AM
  #3763
Konich's Avatar
Reap you racing tonight at MHOR?
That new track layout looks killer
Konich is offline
Old 11-24-2010, 08:15 AM
  #3764
makaluch's Avatar
Trader Rating: 36 (100%+)
After looking at close-ups of the servo saver I have some thoughts. Here's my .02 cents:
Maybe it's the angle of attack between the servo arm and the saver, combined with mechanical drag and your particular setup on the saver, are what's causing stress on that part. A tougher part may prevent breakage but not the stress on the bearings and other parts in the assembly. I think the root issue is the angle of attack all the way through the mechanical range.
Could you guys post up the servo and arm you're using?
makaluch is offline
Old 11-24-2010, 08:57 AM
  #3765
I agree that the angle is not ideal but if you have seen one of the broken servo saver parts, you'll notice there is practically no material there. It is in no way a strong part. I tossed all on mine out so I can't take a picture.
Now I didn't have the problems others have had with the parts breaking but I went ahead an upgraded it anyways because it is a weak link. As soon as I put the aluminum Servo Saver on I stripped out the servo arm. Makes that the next weakest link. Put on the aluminum servo arm and haven't had a problem yet.
Now is there a "next" weak link? I honestly don't think so. The linkage is solid now and the servo saver can still do its job like its supposed to do. I run a servo that is up to the task of an 1/8th scale buggy (ACE1015) so I really do not worry about being able to handle a solid linkage.
