Like Tree22Likes
Old 11-22-2010, 11:13 AM
  #3706
Trader Rating: 27 (100%+)
Just got my Tresrey parts, they look good and that is some scary fast shipping.
C_Money is offline
Old 11-22-2010, 11:32 AM
  #3707
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
Originally Posted by rangerjkb
The DEX410r does come with the bright yellow wheels (no tires). The smallest electronics will work the best, due to the lack of realestate on the chasis. The Spektrum Micro Rx seems to be the way to go and any of the big 3 ESC manufacturers (Tekin, LRP, Novak) will fit well. Hope you have a fantastic Christmas and get the buggy out to the track soon after!
thanks for the reply.
TraxxasPeter is offline
Old 11-22-2010, 11:46 AM
  #3708
rangerjkb's Avatar
Trader Rating: 45 (100%+)
Originally Posted by Photocycler
who else sells parts for our durangos online aside from amainhobbies?
www.stormerhobbies.com and www.losipartshouse.com, also carries Durango parts and have very fast shipping.
rangerjkb is offline
Old 11-22-2010, 11:53 AM
  #3709
rangerjkb's Avatar
Originally Posted by grapejuice
You running any timing advance? I bet those other guys are, when gearing a 13.5 w/ timing advance, you gear it just a little higher then you would with a mod motor.
Yes, running ESC timing advance "Boost" with the Tekin ESC on Murfdogg Motor; Also ran factory recommended ESC timing advance settings on several other top brand motors. Glad to share any ESC/Motor/Buggy setup seeting that I run and definietly welcome any feedback of adjustments that may work better. It's all about having fun and helping each other to do the same...tends to turn out for some great racing on the track and healthy competition.
Old 11-22-2010, 01:20 PM
  #3710
BOLISARIO's Avatar
Trader Rating: 57 (100%+)
So IP's,Venom's, SMC's, Track Power's, Orion's, Racer's Edge, all fit well. I'm glad there's a good selection of packs to choose from.
How about springs? Is it ideal to get the set or are the dark and light green springs work well on most indoor clay tracks? My local tracks are LRH, WCRC, OCRC.
BOLISARIO is offline
Old 11-22-2010, 01:23 PM
  #3711
Briguy's Avatar
Trader Rating: 125 (100%+)
I have been running light green in the rear and black springs up front .
Briguy is offline
Old 11-22-2010, 02:18 PM
  #3712
rangerjkb's Avatar
That seems to be a great question, as I've only had my Durango for a week and absolutely love driving this car..it is so fun to drive! I use Dark green/3 hole/40wt Losi up front and Light green/3 hole/30wt Losi on rear, the car drives exceptionally well on a packed topsoil/clay mix track both in damp and dry conditions. All the setups I've looked at are each a little different. I've even seen a few guys running the blue srings that come with the kit and do extremely well. I'd check out the local track and see how the fast guys have things setup for their track and go from there.
Old 11-22-2010, 03:46 PM
  #3713
makaluch's Avatar
Trader Rating: 36 (100%+)
Is there a colored weight chart for Durango springs? Also, can someone post or reference a pic that shows where they're mounting "home made" weights. There's definitely not much real estate to work with on this chassis.
makaluch is offline
Old 11-22-2010, 03:51 PM
  #3714
dangerwr's Avatar
Attached as a PDF in this post:
http://www.rctech.net/forum/7849098-post1337.html
dangerwr is offline
Old 11-22-2010, 05:14 PM
  #3715
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Get the lead stick on weights and attach them where the actual ones from Durango would bolt to on the rear U Brace
Dlewis4 is offline
Old 11-22-2010, 07:30 PM
  #3716
Strand's Avatar
been racin my durango for a month, stock setup, i could'nt be happier,
i love this thing
Strand is offline
Old 11-22-2010, 09:20 PM
  #3717
makaluch's Avatar
Originally Posted by dangerwr
Danger and Dlewis...thanks for the info. You guys rock!
makaluch is offline
Old 11-23-2010, 07:33 AM
  #3718
makaluch's Avatar
Default Mental notes on the DEX410R
Here's what I got so far with a few questions after some of em:
10.5 gearing- start at 21/87, depends on the track (13.5-start 24/87)
Tekin RS Pro- use boost with reserved mechanical timing on Murfdoggs
Wheels- B44 wheels work if you cut down the pin. Do they change the width (same offset, different spacers required)?
Steering- don't use sub-trims, I understand why. Does standard trim work the same, electronically?
Steering- I saw a collar fix that might extend the life of the stock servo saver. Any feedback?
Steering- at minimum, get the aluminum front/front brace for durability
Springs- start with stock, lighten as necessary for your track.
Weights- to settle the back end use rear weights or 1* rear hubs (r/l marks face forward not back). Track dependent. Taming your servo or smoother driving does too. (9-11 transit and at least 150 torque should be enough)
Diff leaks- replace stock x-rings with Kyosho P5 o-rings.
Drivelines- replace roll pins with solid ones (part#?). Use loctite wisely. Lube, shrink wrap, and use boots.
Drivelines- keep them silky smooth at all times! You will heat up and loose the diff collar.
Slipper- its there to protect the drivetrain. Sensored systems feel safe but do nothing when you land jumps on-power or on the brakes. Use the slipper!
I'm sure there's tons of tips and tricks being used but these ones stand out for me. Sometimes not having parts at the track or coming from the B44 promotes some really creative fixes. I love this stuff!
makaluch is offline
Old 11-23-2010, 07:49 AM
  #3719
Briguy's Avatar
I use subrim on all my cars and never any issues and surely don`t believe that is the cause of the few servo saver problems . I believe there are 8 or 9 Rangos at my track now , which all use subtrim and no issues .
Briguy is offline
Old 11-23-2010, 08:42 AM
  #3720
mgrmek's Avatar
How tight are you guys running your servo saver nut against the spring? Should it be flush?
mgrmek is offline
