Like Tree22Likes
Old 11-21-2010, 02:25 PM
  #3676
Matt Howard's Avatar
Originally Posted by yodace
ran my durango last night in practice tried racing put broke the servo crank arm twice... i think i had the steering end point set wrong...
I liked the buggy but the rear of the car was loose on power. i am running the stock springs, pistons and camber locations. was wondering how to fix this?
Are you running any weight in the rear? That's almost a must, I run the 30g brass skid plate.
Matt Howard is offline
Old 11-21-2010, 02:33 PM
  #3677
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Yodace, soften the car up... green springs, lighter fluid, and 3 hole pistons;
As far as lipo, i run a Venom 45C 5200....
Dlewis4 is offline
Old 11-21-2010, 02:43 PM
  #3678
i strongly suggest that you goggle the hudy set up manual and print it. its for a 1/8 buggy but it has all the theory on everything. its very easy to use track side. it eliminates all the guess work when trying to set your car up. imo its a must for every pit bag, especially if you run a car that doesnt have 10 pro setups posted that have been worked on and refined for years.
cbrociuos is offline
Old 11-21-2010, 02:51 PM
  #3679
yodace's Avatar
I have the racers edge lipo...
I have the 3 hole pistons in the rear shocks with 30w oil. In the front i have the 2 hole pistons drilled 1.34mm, with 35w oil. I bought the wrong springs. I have the dark green for the rear and the light green for the front...
I also have 5000 oil in the front diff and 2000 oil in the rear...
yodace is offline
Old 11-21-2010, 04:40 PM
  #3680
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
What kind of surface are you running on? I too recommending starting with the 30g weight if it's tail happy. From what I've seen and experienced, it's almost a requirement when running mod motors.
t0p_sh0tta is offline
Old 11-21-2010, 04:47 PM
  #3681
Briguy's Avatar
Trader Rating: 125 (100%+)
Don`t waste $40 on the brass weights . You can achieve the same thing for $5 using lead weights under the diff housing and chassis brace .
Briguy is offline
  #3682
yodace's Avatar
i run on a high traction top soil track...
Hopefully i get a full run in without breaking the servo crank arm... i broke it 2 times before setting the steering end points..
yodace is offline
Old 11-21-2010, 05:19 PM
  #3683
Dlewis4's Avatar
DING DING DING!!!
And yodace, light green rear, dark green front
37.5/30 weight, 2 hole pistons, and i have my shocks leaned in pretty good.
Dlewis4 is offline
Old 11-21-2010, 05:33 PM
  #3684
TraxxasPeter's Avatar
Trader Rating: 21 (100%+)
ok im wanting a durango 410r for chrismas. a couple questions.
does it come with wheels. the 410r version
what electronics work good with it
TraxxasPeter is offline
Old 11-21-2010, 05:41 PM
  #3685
t0p_sh0tta's Avatar
Yes, and the smaller the better.
Old 11-21-2010, 05:52 PM
  #3686
yodace's Avatar
DING DING DING!!!
Dlewis are u going to be racing wednesday in KC? LOL to bad i cant send my springs back and get the ones u posted... LOL
yodace is offline
Old 11-21-2010, 05:56 PM
  #3687
Dlewis4's Avatar
Sent you a PM
Dlewis4 is offline
Old 11-21-2010, 10:23 PM
  #3688
makaluch's Avatar
Trader Rating: 36 (100%+)
Anyone have a pic of where they're placing the weight? I get the feeling it's gonna be tail happy at PRCR.
Dlewis4 - I just grabbed a 10.5 Murfdogg and an RS Pro. How you likin those cans? Best gearing for a small track?
makaluch is offline
Old 11-21-2010, 10:48 PM
  #3689
Dlewis4's Avatar
These motors are balls to the wall. Yes, I am sponsored by Murfdogg, but take this as it came from a racer. These motors are truly faster than the rest-I get asked on a weekly basis what I am running, and if it's legal lol
I am running 24/87 for my 13.5 and it's ballistic. So I would say 21/87.
If you need a speedo setup, or any other help with the motor, give myself or rangerjkb a PM. We both run the Rango and the motors
Dlewis4 is offline
Old 11-22-2010, 02:19 AM
  #3690
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool Lipos...
What lipos are the favorites in the dex410 spec? Thanks!
Rideordieguy1 is offline
