Like Tree22Likes
Old 11-10-2010, 10:04 AM
  #3301
grapejuice's Avatar
Trader Rating: 153 (100%+)
Originally Posted by FatBattery
Hey I know sounded like a stupid question. But I really would after spending so much like to have the lastest one for a good while. It's seems to me that trying to sell a 2010 spec car in 2011 is going to be a bit of a marketing issue and maybe that might compell them to offer some quick updates and call it a 2011 spec Dex410. Any thoughts on that?
They could redesign it for lipo or add the transpondermount.
I seriously doubt they will...
grapejuice is offline
Old 11-10-2010, 03:59 PM
  #3302
yodace's Avatar
Anyone else have the problem with the front wheel hex not sliding over the front axle? Kinda tight.
yodace is offline
Old 11-10-2010, 04:44 PM
  #3303
Konich's Avatar
What are people setting the rebound at for thier shocks? I think this maybe the last detail to finish dialing my Durango in.
Konich is offline
Old 11-10-2010, 05:31 PM
  #3304
dangerwr's Avatar
I have been using the same shock setup as Hupo's Cactus Classic except with Losi 35W in the front and 30W in the rear. Pretty good I'd say--not sure what I would do differently. I was thinking of trying 27.5W in the rear. I believe there is no rebound in the rear and 25% up front.
dangerwr is offline
Old 11-10-2010, 05:37 PM
  #3305
Konich's Avatar
I have mine set at no rebound right now and though that adding some rebound may help the slight bottoming out issue I have.
Konich is offline
Old 11-10-2010, 05:43 PM
  #3306
dangerwr's Avatar
Yeah, that is what I do on my 8th scale--I actually run as close to 100% rebound as possible. I would try it in 25% increments to see how you like it . . .
dangerwr is offline
Old 11-10-2010, 06:21 PM
  #3307
rfleck's Avatar
Trader Rating: 58 (100%+)
Alright, first off not sure you can put a bad setup on this lil beast. Gonna try the Grapejuice setup.
It is actually very close to where I had settled although in the shocks, I had
2 hole (stock) 32w losi with dark greens and
3 hole (stock) 27w losi with light greens
Everything else is the same.
I presume this setup is good for wet/damp clay. Chime in Grape, if not.
rfleck is offline
Old 11-10-2010, 07:07 PM
  #3308
the stock pins are to long, dremel them down a little bit.
cbrociuos is offline
Old 11-10-2010, 09:18 PM
  #3309
Corey Bernardo's Avatar
you guys need to try my setup I posted couple pages back!!! I believe car cant get no better!!! I am using its full potential and its fawking amazing!!!!
Corey Bernardo is offline
Old 11-10-2010, 09:25 PM
  #3310
Trader Rating: 27 (100%+)
your basically using kinwalds setup right?
C_Money is offline
Old 11-10-2010, 09:30 PM
  #3311
its close to his yes . . . but on my setup I use a 4 degree rear block, rear oil is different, pistons, and rear hub spacing... all things suiting for my style... Give it a try... its amazing..
http://www.petitrc.com/setup/durango...CE20101031.pdf
Old 11-10-2010, 09:31 PM
  #3312
yeah I seen it on there, It was berween yours and his for the track I will run on.. I think I might use heavier shock oil though.. What will that do in terms of perfprmance?
C_Money is offline
Old 11-10-2010, 09:35 PM
  #3313
depends where you decide to add that heavier oil..... Car as per my setup I can almost guarantee you will love it.. has plenty of rear traction, aggressive, jumps great and did I mention rotates like a 12thscale car!!! AMAZING
Old 11-10-2010, 09:38 PM
  #3314
I think 40 in front and 30 in rear is what I was gonna try.. the track PRCR is where I will be running, its on youtube, check it out that might help you tell me if yours will be good
C_Money is offline
Old 11-10-2010, 09:40 PM
  #3315
does the 2010 spec come with the 1* hubs?
C_Money is offline
