Like Tree22Likes
Old 11-09-2010, 08:56 AM
  #3241
grapejuice's Avatar
Trader Rating: 153 (100%+)
Originally Posted by dangerwr
What? I want you to watch me run. Not like I am bouncing off stuff. I generally run smooth lines where I am in control. I give it a bit of wood coming down the back straight and thus the brakes come on pretty strong once in a while--lifting the rear up a little. Other than that the lines I run bring a tear to my eye. "Elegant" might be the term I'd use if I was some kinda weirdo who speaks like that . . .
I still think trying a different servo is worth a shot, never know till you try it
grapejuice is offline
Old 11-09-2010, 09:06 AM
  #3242
dangerwr's Avatar
No, I agree. The problem all started when I used subtrim on the radio to center the steering. I wonder if there is something flaky with this servo under this conition? Tonight I am going to fix this manually. I put my car on a wire diet, rerouted the antenna (I got the idea from Sam Superman) and am ready to start rockin' the Danger paint scheme once I break into the 26 lap or higher pace. But first I have to stop breaking the janky servo saver . . .
dangerwr is offline
Old 11-09-2010, 09:31 AM
  #3243
Originally Posted by Dlewis4
Last sentence. Priceless
Agree...I could not stop laughing for about 10 min...How does he come up with that stuff...
sjracing is offline
Old 11-09-2010, 09:51 AM
  #3244
dangerwr's Avatar
Ha-ha! You should see some of the definitions I have up on UrbanDictionary. I do not want you guys to think any less of me so I will not point you to them. I was not Danger then so no luck finding 'em from that angle!
Anyway, sorry for the derailing the thread with my antics. Rango! Rango!! Rango!!! Time to get derrango'd .
dangerwr is offline
Old 11-09-2010, 01:21 PM
  #3245
dangerwr's Avatar
Here is some fun info from Futaba regarding sub trim:
"Yes, sub-trims are just a way of moving the center of a servo's travel. They should be used as little as possible. Normally, you'd have the sub-trims set to zero and adjust the mechanics of the control linkage to the zero position. Center the servo arm on the output shaft and adjust the length of the push rod to get a neutral on the control surface.
When you alter the center, the ATV will change somewhat, as far as the visible movement of the control surface. The numbers in the transmitter will not change.
When you move the ATV, you're compressing or expanding the total amount of movement, but still using the same number of electronic 'steps' from end-to-end, so the offset the sub-trim has from the electronic center will also be compressed or expanded.
This type of interaction just can't be avoided. That's why it's best to use the sub-trim as little as possible."
Not sure if this is the problem with my Rango but is where it all started when I messed with this setting.
dangerwr is offline
Old 11-09-2010, 02:04 PM
  #3246
sleek's Avatar
got my durango together finally, and this car is so good it added 2 laps to my best bench racing time so far.......LOL seriously this car looks to be a decent car, instructions kinda left some to be desired. Hoping for this Sat. to possibly be the madden voyage as soon as my new batts get here
sleek is offline
Old 11-09-2010, 02:14 PM
  #3247
Corey Bernardo's Avatar
glad you like the car sleek!!! Yes its am amazing piece of machinery!!! I cant believe how good I got mine... Check back a few pages and I posted a link to my setup
Corey Bernardo is offline
Old 11-09-2010, 03:44 PM
  #3248
Team Tekin
Randy_Pike's Avatar
Default Tresrey Parts
Hey guys. I just received a few of the latest Tresrey parts for the Dex410. I will be working with Tresrey for the remainder of 2011 with testing and helping them make it to our US shores. Take a quick read and let me know what you think:
http://tracktimeconsulting.blogspot....esrey-for.html
If you have a parts suggestion PM me and I'll pass it along.
Randy_Pike is offline
Old 11-09-2010, 04:04 PM
  #3249
syllag1969's Avatar
How about that flimsy o-ring/plastic piece for holding the rear diff in position?
I'm sure it would be a good addition, or maybe i'm just picky
Congrats Randy for joining Tresrey
syllag1969 is offline
  #3250
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Nice, are they the ones that produce the onboard brass weight? What about carbon towers (my next upgrade)???
t0p_sh0tta is offline
Old 11-09-2010, 04:06 PM
  #3251
I was looking at that tresrey brass weight, where does it sit?
I have ordered the red centre cvd and alumium servo horn from tresrey.
LiL_JaSoN is offline
Old 11-09-2010, 04:12 PM
  #3252
anyone has anyone tried adding weight to the front right hand side of the chassis to balance out the weight distribution left/right?
the motor sits on the left, so the left side is heavier.
i noticed upon accelerating down the stright, the car leans towards the left a lil, and right wheel lifts up.
thinking of adding weight along the right side of the chassis to balance it out.
Old 11-09-2010, 04:35 PM
  #3253
Briguy's Avatar
Trader Rating: 125 (100%+)
Sounds great Randy ! Can`t wait til those parts are available here in the states .
Briguy is offline
Old 11-09-2010, 04:58 PM
  #3254
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Danger: I am a regular reader here and have been following your problem with the servo saver. I just looked at my car. How high is your servo? If you hold the front wheels and turn the servo arm, so the servo saver expands(twists) maybe when the bottom piece lowers(expands) it hits your servo and breaks the saver every time? I don't know how else to explain this, or if this is the problem but check your car to see if this is possibly the problem. Good Luck!
Bman's 3XNT is offline
Old 11-09-2010, 05:33 PM
  #3255
dangerwr's Avatar
Thanks for the input--this is definitely something I will have to check! I have the Futaba BLS551 which is a "stubby" servo but is of normal height in the direction which you are mentioning. I have an aluminum servo horn I could use to raise the arm up a bit if this indeed is the issue. Cheers!
dangerwr is offline
