Like Tree22Likes
Old 11-08-2010, 08:36 AM
  #3196
Corey Bernardo's Avatar
then thats exactly what is happening then!!! hahah.. I guess I'll loosen slipper a tad ahah.. but as far as given throttle in the air, I cant stop doing that... I feel it controls the car better.....
Corey Bernardo is offline
Old 11-08-2010, 08:39 AM
  #3197
R-E-A-P-E-R-'s Avatar
Throttling in the air isn't a problem if your slipper is set correctly. When your wheels make contact with the ground the slipper should take the blow before it reaches your driveline.
R-E-A-P-E-R- is offline
Old 11-08-2010, 09:36 AM
  #3198
I will make a note of that !!! ahah
Old 11-08-2010, 12:54 PM
  #3199
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I set my slipper 3 turns tighter than factory recommendation. Works great
Dlewis4 is offline
Old 11-08-2010, 01:06 PM
  #3200
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Might seem like a dumb question, but three full turns? I set mine three half turns and it still seems alittle loose..........
Bman's 3XNT is offline
Old 11-08-2010, 01:19 PM
  #3201
Dlewis4's Avatar
Yes. Three FuLL turns
Dlewis4 is offline
Old 11-08-2010, 01:45 PM
  #3202
I guess I had my slipper a little to tight huh!!!! ahahahah
Old 11-08-2010, 01:49 PM
  #3203
guess I did have my slipper to tight, now I know why my ring diff gear gets stressed so much ahahha
Attached Thumbnails Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread-photo.jpg
Old 11-08-2010, 02:51 PM
  #3204
Dlewis4's Avatar
Wow....
Dlewis4 is offline
Old 11-08-2010, 03:19 PM
  #3205
grapejuice's Avatar
Trader Rating: 152 (100%+)
Actually....it was too loose and you melted it, I did that when I first got my car, was running it and it felt a little loose, then my friend grabbed the radio and ran the crap out of it and when I he gave it back, it barely moved because it was so hot . Running it like that though basically locks the slipper....
grapejuice is offline
Old 11-08-2010, 03:28 PM
  #3206
savageboy69's Avatar
Trader Rating: 93 (100%+)
hey guys hows it goin, i wanna know if anyone is aware of a easy way to remove the gears inside of the diff? i know on 1/8 scale there is a groove on each side of the case that goes all the way down so you can stick in needle nose pliers to get a grip on it , but these dont have em so how are you gettin em out?
savageboy69 is offline
Old 11-08-2010, 03:29 PM
  #3207
really too loose?... My car never slipped? on power... I usually tighten it as much as I can with my right hand then thats it..... leave it..
Old 11-08-2010, 03:30 PM
  #3208
Dlewis4's Avatar
all of have to say is holy crap.
Dlewis4 is offline
Old 11-08-2010, 03:33 PM
  #3209
if it were too tight you would prolly be missing a few teeth on the spur
Old 11-08-2010, 03:44 PM
  #3210
I can't lock mine. I went to the point of collapsing the spring and it still slipped alittle.
