Like Tree22Likes
Old 11-07-2010, 06:26 PM
  #3181
Has anyone tried boiling the servo saver to see if that helps?
1day is offline
Old 11-07-2010, 06:27 PM
  #3182
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
To soften it up? There's plenty of flex in Durango plastics.
t0p_sh0tta is offline
Old 11-07-2010, 07:57 PM
  #3183
Corey Bernardo's Avatar
another race day came an went and my durango yet again out performed itself!! The car is freaking amazing!!! Only thing I have funny, I find I chew up the metal diff ring gear while running a 5.0T in my car... They must use a cheap metal or something.. Cuz my idler gear stays true, the ring gear gets chipped.... and I have it spaced perfectly.. I guess running a 5.0T and driving hard at 150degrees does that! ahah
Corey Bernardo is offline
Old 11-07-2010, 08:28 PM
  #3184
mdowney's Avatar
Trader Rating: 21 (100%+)
Tell me about it. I was at the track practicing yesterday and nose-dived short on a triple and had the front drive shaft pop out. The nose of the Rango flexes quite a bit. If you hit it just right you can have the same thing happen.
I almost wonder if I left a screw out last time I pulled the front diff out...
mdowney is offline
Old 11-07-2010, 08:29 PM
  #3185
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I have only had that happen once... but I landed square on a pipe and could SEE the car flex.
Dlewis4 is offline
Old 11-07-2010, 09:23 PM
  #3186
Trader Rating: 49 (100%+)
I had the same thing happen, three times with a tekin 13.5 setup. I had to shim the rear diff so tight it felt a bit crunchy between the pinion and spur. There is flex in the rear case or something. Since I over shimmed it I haven't destroyed a gear again.
I added a turnbuckle between the front bulkhead and rear radio tray screw hole. It helps the front driveshaft stay in considerably and still allows torsional flex for traction.
aradaiel is offline
Old 11-08-2010, 06:06 AM
  #3187
R-E-A-P-E-R-'s Avatar
You guys must me running the R version then. I have never had that problem on my Spec Car
R-E-A-P-E-R- is offline
Old 11-08-2010, 06:15 AM
  #3188
+1
cbrociuos is offline
Old 11-08-2010, 06:17 AM
  #3189
Briguy's Avatar
Trader Rating: 125 (100%+)
I run the R version and hadn`t had any issues of the car flexing so much the center CVDs pop out . I`ve has my share of bad landings too .
Briguy is offline
Old 11-08-2010, 06:27 AM
  #3190
t0p_sh0tta's Avatar
Same here, although I haven't run on any large, rough, 1/8th scaleish tracks yet.
Old 11-08-2010, 07:28 AM
  #3191
steam's Avatar
Default What are the size of the ball ends on this car
Looking to replace my ball studs with hex type.
are these ball studs for this car 4.8 mm? I'm using 4.8 mm ball cups
http://www.losipartshouse.com/servle...all-Set/Detail
steam is offline
Old 11-08-2010, 07:54 AM
  #3192
t0p_sh0tta's Avatar
Kyosho's are 4.8mm right??? Too small.
Old 11-08-2010, 08:24 AM
  #3193
grapejuice's Avatar
Trader Rating: 152 (100%+)
Your slipper tight? Possibly too much brake....I have my brake turned down quite a bit.
grapejuice is offline
Old 11-08-2010, 08:28 AM
  #3194
I dont use drag brag at all programmed in my LRP... If anything I am thinking its because I hammer it while the car is flying in the air ahah.. If the slipper was too loose that would cause that no? Yea mine seems tight, it only slips for a half inch if anything lol
Old 11-08-2010, 08:33 AM
  #3195
grapejuice's Avatar
I meant push brake, I have mine on 1 on my sxx and it's turned down on the radio too, drag brake at 0. And running the slipper tight puts A LOT of strain on the drive train especially with a 5.0t. Also, with hammering it in the air and landing on power with a tight slipper w/ a 5.0t....sounds like gear destruction to me
