Like Tree22Likes
Old 11-07-2010, 12:30 AM
  #3136
Trader Rating: 27 (100%+)
Dlewis your running on a clay track too? So you find those shock oils best for clay? I have 30 35 and 40.. What would you try first?
C_Money is offline
Old 11-07-2010, 12:57 AM
  #3137
Originally Posted by FatBattery
Does anyone have an idea when the 2011 spec might come out?
10 just came out not even a few months ago.
LiL_JaSoN is offline
Old 11-07-2010, 02:02 AM
  #3138
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Yes on clay. My car is extremely dialed
40 weight front, 3 hole pistons, dark green inside on tower outside on arm
30 weight rear, 3 hole, light green, middle tower outside arm
Dlewis4 is offline
Old 11-07-2010, 02:04 AM
  #3139
Dlewis4's Avatar
Originally Posted by Photocycler
Was curious if any of you guys are using expo on your buggy's? If so how much are you using?
Expo is a personal feel thing. I use every bit of steering and turn in I can get so no expo for me
Dlewis4 is offline
Old 11-07-2010, 05:11 AM
  #3140
rraden's Avatar
Trader Rating: 259 (100%+)
Unfortunately, I'm letting go my brand new DEX410R if anyone is interested:
http://www.rctech.net/forum/r-c-item...brand-new.html
rraden is offline
Old 11-07-2010, 05:30 AM
  #3141
Briguy's Avatar
Trader Rating: 125 (100%+)
Originally Posted by BOLISARIO
Thanks. But do you have the thickness measured?
5mm=ID and 8mm =OD?
Once I get my stuff unpacked from racing last night I`ll measure them .
Briguy is offline
Old 11-07-2010, 07:57 AM
  #3142
if you get a chance would you go on youtube and type in prcr rc racing or something, and tell me if that track is similar to the one your on?
C_Money is offline
Old 11-07-2010, 08:04 AM
  #3143
Briguy's Avatar
For the past two weeks I been fighting the rear of the car in the turns as the car has so much steering , even turned down on the radio . I started with Grape`s setp and made a few changes and the car is on rails ! Last night was the first time I got the car to do what I want and is awesome !
I plan on getting the DESC41R as well . Anyone know if they are working on a 2wd buggy ?
Briguy is offline
  #3144
Originally Posted by dangerwr
So, all of a sudden the servo saver issue reappeared again tonight--ruined my race day essentially. Not sure what gives but was so aggravating the car went in the trash at one point. I am not sure why it is only me or maybe the servo saver is just that fragile? TD has to be aware of this issue. How you you develop something for 8 years (or whatever) and know they needed to do something different with the design?? A guy bumped my wheel in practice and you could hear is snag like a tiny twig. By bumping wheels??
Was that guy's company Tresrey, correct? Who makes the aluminum stuff . . .
ive broke that once, but i clipped a wall. maybe try pulling the servo arm off the servo and see if everything is free. if it is still pull it all apart and rebuild it. something isnt put together right. ive been plowed by scales in practice w/ very min. damage. this car is a beast.
cbrociuos is offline
Old 11-07-2010, 08:27 AM
  #3145
DEX210 is in the works, still a prototype.. When we see that then we will see a stadium truck for sure.. and after the stadium truck I think we will see the 2wd SC truck.
C_Money is offline
Old 11-07-2010, 09:29 AM
  #3146
makaluch's Avatar
Trader Rating: 36 (100%+)
For the past two weeks I been fighting the rear of the car in the turns as the car has so much steering... I started with Grape`s setp and made a few changes and the car is on rails ! Last night was the first time I got the car to do what I want and is awesome !
What did you change from Grape's setup to tame the rear?
makaluch is offline
Old 11-07-2010, 09:33 AM
  #3147
Photocycler's Avatar
I run at PRCR and ran my DEX for the first time yesterday. I am still working on dialing it in but its running pretty good just a few kinks to work out. I can share my setup with you if you like. I will be there Tuesday as well
Photocycler is offline
Old 11-07-2010, 09:36 AM
  #3148
Briguy's Avatar
Moved the rear shocks out one hole on the arms , added 3/4 oz of weight under the rear diff housing , and added 1/4 oz of weight on each side of the chassis brace . Added weight for under $5 , not $40 for the weight kit
Briguy is offline
  #3149
makaluch's Avatar
Thanks for the tips Briguy. What did you use for weights if you don't mind me askin?
Sweet! Three Rangos at PRCR You guys running 10.5s? Choosing an electronics setup is my next thing.
makaluch is offline
Old 11-07-2010, 09:48 AM
  #3150
I am running a 10.5, which is plenty for this track...
So all the setup sheets show 3 shock holes and with the 410r shock towers we have 5, so when the setup sheet shows a top mount which is the 3rd hole on a 410 are you mounting in the 3rd hole on the 410r tower or mounting in the top 5th?
