Like Tree22Likes
Old 09-30-2009, 08:44 PM
  #301
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
Originally Posted by trap121
They ship to the US, I just checked
thanks,
done. Hope they last longer than 8mins.
Crazy Carl is offline
Old 10-01-2009, 05:31 AM
  #302
Trader Rating: 19 (100%+)
Originally Posted by Crazy Carl
thanks,
Let us know how they turn out.
trap121 is offline
Old 10-03-2009, 08:20 PM
  #303
Crazy Carl's Avatar
this thread does not deserves to be on page 3 we all waited to long.
P1 kid all day
Old 10-03-2009, 08:54 PM
  #304
ASH93A's Avatar
P1 kid all day
Agree 100%...
But probably wont me much "Durango talk" from Australia (at least Sydney anyway) as we have had constant rain here for the past few days and looks to be continuing for the next week or so. I so much wanted to give mine another run today after various setup changes.
Finally had success in modifying a 81 tooth AE spur to fit the Durango so I can achieve a more suitable FDR with a 17.5 brushless (stock class here in Aus) without using a massive pinion!!
AH
ASH93A is offline
Old 10-04-2009, 12:07 PM
  #305
HVAC25000's Avatar
Originally Posted by ASH93A
Agree 100%...
AH
I've taken a gtb and machined a water cooled heatsink for it to run it in a boat, then encased the esc in silicone, worked great. Same thing for the batts and the motor, encase the connections in silicone, it can easily be cut with a hobby knife and removed when needed. You could do the same and just run it in the water lol. (I know, not practical for cars, meant as more of a joke, unless you live in the UK where it rains 250 days a year ).Myself, I haven't seen rain since I think April.
What did you have to do to the 81t spur to put it on the car? I think I may have one somewhere so I could try and figure it out myself but it will probably take me longer to find it than for you to reply lol. I run a 6.5 and as far as I'm concerned I still have to run massive pinions at 21t. My range is normally 14-19t so I'd like to step down also.
HVAC25000 is offline
Old 10-04-2009, 12:13 PM
  #306
Agree 100%...
AH
I would like to know this also......my durango should be here Tuesday...cant wait.
I will be running a 6.5 rs pro in it. Do you guys have any suggestions on the build?
trap121 is offline
Old 10-04-2009, 04:21 PM
  #307
ASH93A's Avatar
The durango spur has a 8mm center hole and than the AE ones are 4.5mm. My metric drill set I have go up in 0.5mm steps, so I started with the 5mm bit and reamed the center hole to 5mm and then went up by 0.5mm at a time until it was 8mm. I found that using the drill bit by hand (holding the end with bull nose pliers) did the trick, although you need to be very carefull as mine still ended up very slightly off centre... so the mesh with the pinion is not perfect but will do until Durango release there own smaller spur gears.
AH
ASH93A is offline
Old 10-04-2009, 05:46 PM
  #308
ben73's Avatar
Trader Rating: 40 (100%+)
I used a really sharp body reamer on my AE spurs and it worked fine. Its consistent around the whole mesh with pinion.
If done by hand you can go slowly from both sides and you can get a nice tight press fit.
I ran it all weekend at a big race meeting in melbourne with no issues.
ben73 is offline
Old 10-04-2009, 05:49 PM
  #309
Default Gearing
I have plenty of t4 spurs. What gearing should I start with using a Tekin 6.5?
trap121 is offline
Old 10-04-2009, 09:53 PM
  #310
ASH93A's Avatar
Yep, like Ben said the body reamer would be perfect!! I think I will purchase one and a couple more AE spurs...
AH
ASH93A is offline
Old 10-05-2009, 07:24 AM
  #311
tomdav's Avatar
Trader Rating: 44 (100%+)
I was able to drive a Durango Sunday back to back against my B44. Track was indoor clay running Gold barcodes. Durango felt planted with great steering. Where the B44 would slap or get upset if not driven perfectly over jumps the Durango kept on tracking allowing me to get the power down. I only drove about 5 minutes as I did not want to break the car but in that short time I felt comfortable pushing it unlike other 4mods I've tried. Now if I could only find the cash.
tomdav is offline
Old 10-06-2009, 06:46 AM
  #312
Trader Rating: 96 (100%+)
Durangos' site says there are no more kits, anyone have an extra lying around collecting dust?
The Durango and X11 cause me to get all warm and fuzzy on the inside.
K.Copeland is offline
Old 10-06-2009, 10:22 AM
  #313
I just got mine today
looks high quality.....
trap121 is offline
Old 10-06-2009, 11:08 AM
  #314
HVAC25000's Avatar
May be able to get one here, seems to be the only place that might have it in stock
http://theraceplace.co.uk/osCommerce...roducts_id=191
Old 10-06-2009, 11:57 AM
  #315
Default gearing
Does anyone have suggestions on what gearing i should start out with? Iam using a 6.5. I also have T4 spurs I can ream out
trap121 is offline
