Like Tree22Likes
Old 11-06-2010, 09:18 PM
  #3121
R-E-A-P-E-R-'s Avatar
I looked at his car. There is nothing out of place that I could see. That's why it's so strange
R-E-A-P-E-R- is offline
Old 11-06-2010, 09:23 PM
  #3122
dangerwr's Avatar
Everybody I can think of has looked at it. Spooky stuff for sure . . .
I should probably just try a different servo for a while?
dangerwr is offline
Old 11-06-2010, 09:27 PM
  #3123
Speaking of servos. Mine isn't centering correctly. It was a nightmare driving it in the main. I am amazed a held onto 3rd place.
Old 11-06-2010, 09:50 PM
  #3124
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Originally Posted by Konich
I switch all my diffs to the Kyosho P5's and no leaks, no need to switch.
Have a race in the AM and NOBODY has those in stock. I have a bag of the Durango o-rings, but if I'm going to have to refill the diffs halfway through a race day, I won't go through the trouble of changing them.
t0p_sh0tta is offline
Old 11-06-2010, 09:52 PM
  #3125
Dlewis4's Avatar
Trader Rating: 148 (100%+)
I have had that problem... ended up being the screws going into the steering posts... they loosened and the whole shaft started moving.
Locktite took care of that
Dlewis4 is offline
Old 11-06-2010, 09:54 PM
  #3126
I'll check that tomorrow for sure.
Old 11-06-2010, 10:02 PM
  #3127
Photocycler's Avatar
Trader Rating: 36 (100%+)
Originally Posted by Dlewis4
try 40 weight in the front, 30 weight in the rear. 3 hole pistons all around.
I have losi 32.5 so maybe I will try that and see if it helps
Photocycler is offline
Old 11-06-2010, 10:05 PM
  #3128
Dlewis4's Avatar
The more pack you have the less its going to want to nose dive.
I went from 35/32.5 to 40/30 and it was a huge difference in drivability
Dlewis4 is offline
Old 11-06-2010, 10:06 PM
  #3129
I figure ill try the 32.5 and if it helps but doesn't fix it I will move up...mind as well try it since I already have it
Old 11-06-2010, 10:12 PM
  #3130
Dlewis4's Avatar
If you dont have the oil... i would put the 2 hole pistons in front too
Dlewis4 is offline
Old 11-06-2010, 10:13 PM
  #3131
So if I got 40wt go with 3 hole but with 32.5 go with 2 hole? whats the benefit of that
Old 11-06-2010, 10:17 PM
  #3132
Dlewis4's Avatar
More pack with the 32.5, less pack with the 40.
Just try the 32.5 with 2 hole.
I personally like the 40 with 3 a lot better
Dlewis4 is offline
Old 11-06-2010, 11:15 PM
  #3133
Was curious if any of you guys are using expo on your buggy's? If so how much are you using?
Old 11-06-2010, 11:43 PM
  #3134
FatBattery's Avatar
Does anyone have an idea when the 2011 spec might come out?
FatBattery is offline
Old 11-06-2010, 11:48 PM
  #3135
What would be the purpose of a 11Spec car???
