Like Tree22Likes
Old 11-05-2010, 05:51 PM
  #3076
Konich's Avatar
Does anyone else's slipper pads work (AE?) with the Durango setup?
I want to build a spare slipper assembly with a 84 spur instead of the 87 and be able to switch them out quickly.
Konich is offline
Old 11-05-2010, 08:45 PM
  #3077
dangerwr's Avatar
Hey, I remember in the Oople article whether or not the "other guys" slippers fit or not. If I recall correctly these are a bit larger--either way they do make note of this in that article. Cheers!
Looks like they will fit:
"The pads are the ubiquitous 'B4' size octagonal shaped design and are clamped either side by intricately machined alloy plate and combined layshaft and plate machined from steel - all heavily lightened, if that's the right way of putting it."
What I was thinking of is the spur itself:
"The spur design looks similar to others but the centre hole diameter is larger than those seen on the likes of the Associated B4 or Tamiya TRF511 and therefore not interchangeable."
dangerwr is offline
Old 11-05-2010, 10:17 PM
  #3078
MaTt 93's Avatar
heya fellow durango owners .... Just got back from my local auto shop and was able to get some o-rings to fit my diffs. They were only 50c aus each (not sure how much that is in USA) and they felt like they sealed a lot better. I haven't ran them yet but they certainly feel alot better.
MaTt 93 is offline
Old 11-06-2010, 02:13 AM
  #3079
Photocycler's Avatar
Trader Rating: 36 (100%+)
anyone running futaba receivers? If so are you running the full antenna coming out through the body or did you find another way to route the antenna so it doesn't stick out of the body?
Photocycler is offline
Old 11-06-2010, 02:41 AM
  #3080
dangerwr's Avatar
I am running the Futaba stuff and just have been sticking it out the body. I am still running a practice body but have formed an antenna to stay under the body when I am ready to run the paint job.
I see that some guys wrap the coax antenna around the Rx once to leave a short lead . . .
dangerwr is offline
Old 11-06-2010, 02:53 AM
  #3081
dont have a antenna. just wrap it up along with the excess servo, esc wire inside the body.
LiL_JaSoN is offline
Old 11-06-2010, 06:34 AM
  #3082
critterracing's Avatar
Default my new ride
really liking this car. rs pro/6.5. Enjoy.
Aldo
durango-13.jpg by aldo3912, on Flickr
durango.jpg by aldo3912, on Flickr
durango-2.jpg by aldo3912, on Flickr
durango-5.jpg by aldo3912, on Flickr
durango-9.jpg by aldo3912, on Flickr
durango-14.jpg by aldo3912, on Flickr
durango-15.jpg by aldo3912, on Flickr
critterracing is offline
Old 11-06-2010, 07:23 AM
  #3083
tedstryker's Avatar
Trader Rating: 88 (100%+)
Aldo
that's bad ass AL...
tedstryker is offline
Old 11-06-2010, 07:25 AM
  #3084
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
I do. I reamed a hole in the windshield and stood it up. I didn't have a lighter with me, but the antenna is short enough to be bent at a 90* angle and stop right before the spur gear assembly. I'll take some pics when I get off.
t0p_sh0tta is offline
Old 11-06-2010, 07:33 AM
  #3085
Briguy's Avatar
Trader Rating: 125 (100%+)
Aldo
That looks killer ! Is that paint or a wrap ?
Briguy is offline
Old 11-06-2010, 08:55 AM
  #3086
Trader Rating: 78 (99%+)
Diff housing are now available. They have new hardened outdrive cup, and washer to hold in oring. I have 4 diff housings available. Also I am making new outdrive cups for the ring gear side. They will have less wear than the original. PM me if interested, or call 203-309-9108.
Raul
Raul Garcia is offline
Old 11-06-2010, 08:56 AM
  #3087
thanks guys. all paint. besides owning the shop i paint all day lol. something like 3000 bodies in the past 9 years.
i haven't been on the track in a couple years but this car has got the excitement going again for me.
Old 11-06-2010, 09:47 AM
  #3088
Trader Rating: 27 (100%+)
I am going to head to the hobby shop on monday for a race and i am gonna pick up a few things for when I get this car..
On ,,y list re p5 o rings
I want to get the gears and diff oil as well but I dont know what I should gear it at.. nor the oil..
So anyway I am gonna be running a RS Pro with a orion 7.5.. Probly no timing or boost cause everyone where I race I think uses 10.5. What do you think for gearing?
Also diff oil.. I am gonna be running a clay track, meduim to high bite, gets watered and does dry but doesnt groove up..
Thanks for the help
C_Money is offline
Old 11-06-2010, 11:13 AM
  #3089
t0p_sh0tta's Avatar
I run a 22 tooth pinion with my 7.5 setup. I run on a smaller track and can't put all of that power down, so I'll be switching to a 13.5 this week.
I too am looking for the P5 o-rings, if you find them in stock anywhre, let me know. lol
Old 11-06-2010, 11:51 AM
  #3090
stock spur?? No heat or anything?
C_Money is offline
